Question about Poulan Electric Pole Saw - PLN1510
Poulan Pln1510 problems
The chain does not move when I turn it on.
5 Suggested Answers
  • 104 Answers
SOURCE: chain will not turn
take it back sounds like you have stripped the drive gear
Posted on May 26, 2009
dontbother10
  • 2220 Answers
SOURCE: The chain is not moving on Poulan 4018 Wild Thing
I think you are saying the centrifugal clutch does not engage. It should not at idle. Did you rev it up a little and it still not engage? There is a clutch face on sprung weights that should expand and turn the clutch drum above idle. Please see the “Handle, Chassis & Bar Assembly” detail for clutch illustrations.
A 2375 has an outboard clutch (the chain is between the engine and clutch drum).
2375 Type 7 (may not be your saw)
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-7/75.2375-Gas-Saw-Type-7.1.59.1.html
Use this as a guide to remove the clutch and inspect the parts:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources,
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
A 4018 has an inboard clutch (only the drive sprocket extends into the clutch cover). Do this first then use the outboard procedure to remove the remaining clutch pieces.
PP4018 Type 2 (may not be your saw)
http://www.ordertree.com/modelinfo/PWE/PP4018-Poulan-Pro-Gas-Saw-Type-2/75.PP4018-Poulan-Pro-Gas-Saw-Type-2.1.59.1.html
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
If these are not your saw it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
You can reply below with questions or if 1 miss understood your problem. HTH
Lou
Posted on Jan 18, 2010
dontbother10
  • 2220 Answers
SOURCE: Chain and sprocket won't move. Poulan P4018WT
Poulan P4018WT Gas Saw Type 2 link below (may not be your saw - 5 to choose from):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
It has an inboard clutch. If this is your saw remove the clutch cover, bar,
chain and inspect the chain brake linkage within. Is the brake band tight against the clutch drum? If yes grasp the forward most upper handle and pull it aft (may require some force at rear extreme) until it clicks (a keeper nests in a detent). Is there a little clearance between the brake band and clutch drum? Can you spin the clutch drum now? If yes reassemble your saw.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If not post back please.
Poulan.com
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 19, 2010
  • 2239 Answers
SOURCE: Runs but the chain won't move? Poulan
This sounds loke the chainbrake has activated, grab the hand guard and pull it fimly fully back to the top handle until it clicks and the brake is of, now try again.
Posted on Aug 28, 2011
How to tighten chain on 4620avx poulan pro
First, RTFM- read the manual. Lost it? No problem, download it from Poulan PRO website page for PP4620avx. Pick a version you like, save and read it. Google is your friend.
Chain Adjustment Part cut and pasted as follows:
Adjusting the tension:
Chain tension is very important. Chain stretches during use. This is especially true during the first few times you use your saw. Always check chain tension each time you use and refuel your saw.
1. Lift lever on bar knob and turn counter-clockwise 1.5-2 turns to loosen clutch cover.
2. Turn adjusting wheel (downward direction) to tension chain until chain solidly contacts bottom of guide bar rail. Lift tip of guide bar while adjusting tension. Tighten chain Adjusting Wheel
3. Use a screwdriver to move chain around guide bar to ensure all links are in bar groove.
4. While lifting tip of guide bar, tighten bar knob securely (clockwise).
Hand tighten only.
Be careful not to destroy the adjustment mechanism. When it breaks, go for a clutch cover with the simple adjuster that needs a "scrench". Longer term, learn how to search this info. Saves time. Now you can work on sharpening chains- very important.
Manual page:
http://www.poulanpro.com/ddoc/PPOO/PPOO2006_USen/PPOO2006_USen_PP4620AVX_952802146.pdf
Jul 21, 2014 | Poulan Pro Chain Saw 46cc 20"
Chain keeps falling off
Check the machine is oiling ok, if there is not enough oil to lub the chain it will stretch causeing it to come off, you should see a good spray of oil from the tip of the bar when the saw is reving.
Jun 02, 2012 | Poulan PLN1510 8 Amp 10-in 2-in-1 Electric...
Poulan 18" PP4218 Pro 952051338 It has fuel
you may need to clean your sparkplug, or replace it
Aug 05, 2011 | Poulan 952051338 18Inch Chain Saw Chain 38
Chain is extremely loose and turning the screw to tighen does not fix the problem
You need to loosen the cover fasteners before the adjuster will do anything. Turn the adjuster CW to tighten the chain--bring the chain up to the bar, but not so tight that you can't move the chain by hand. Recheck the tension after tightening the cover fasteners. Hope this helps!
May 21, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Chain wont turn when running
Check the tensioner screw, it could be too tight. Loosen the slack and the chain should move. And of course do this while its off.
Jul 19, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain will not turn
May 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Chain keeps turning while in the idle position . Poulan Pro 2075 chain saw.
There will be an idle (Low) speed adjustment screw somewhere on the saw (look in your manual). Adjusting this setting lower will prevent the chainsaw chain from turning in the idle throttle position. Basically you want to set it so the chain has just stopped moving... but you need to set this after the chainsaw has warmed up a little.
Mar 13, 2009 | Poulan Garden
Poulan chain saw. After starting, chain drive won't move
If equipped, the chain brake may be engaged. Its the lever just ahead of the fore handle. (pull back on it)
If the clutch assy. were frozen, then the chain would move all the time.
Good luck
Aduz
Mar 07, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Electric Pole Saw - PLN1510 Logo
52 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
