Question about GE Refrigerators
GE Profile TPX21PR
The water from the door has specks in it, as does the ice. Does this freezer have a filter, and if so where is it and how do I replace it?
    Top Expert:
  • GE Master
  • 9,472 Answers
Look on the top rear of the refrigerator section for a filter. It will look like an oil filter from a car.
Posted on Nov 03, 2012
  • 531 Answers
SOURCE: smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Posted on Mar 31, 2009
  • 351 Answers
SOURCE: Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Posted on Apr 19, 2009
  • 311 Answers
SOURCE: ge profile arctica side by side- ice maker and
The water dispenser and the icemaker both operate on different soleniods on the water valve so the chances of a bad valve are slim. I would assume you issue is in your water supply. The easiest thing you could try first would be to check your saddle valve that taps into your main water line to supply the ref. They are known for calcium deposits which obstruct the flow of water. This issue is IDed by very slow water pressure through th door. If its gunked your icemaker fill tube may also be frozen.
Posted on Jan 11, 2010
  • 40 Answers
SOURCE: Ice maker leak in GE refrig.
when the refrig.goes through a defrost cycle the water from the melted ice is supposed to go out a drainline to a pan inthe back.most likely the drain has plugged up and needs cleaning.remoe shelving andtake back panel off drain hole is located below coils,be carefull of coils ,delicate
Posted on Jan 22, 2010
Testimonial: "Thank you, drain is clogged. Problem solved."
DeBruce
  • 145 Answers
SOURCE: Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Posted on Mar 05, 2010
Jan 22, 2010 | Kenmore 53642 / 53644 Side by Side...
Purchased a GE Profile bottom freezer April 08. Has indoor water dispenser. Changed the water filter 60 days ago. Since then the amount of cold water dispensed has slowly decreased to a trickle. There...
Disconnect the water line where it comes out of the water inlet valve and see how the flow is when you try the dispenser. Disconntct the water line at the bottom of the freezer door where it goes into the door. If it flows good here it may be freezing in the door. Open the door till it thaws.
If it's good at the inlet valve and slow at the door, some models have a way to put a plug in and bypass the filter.
Aug 14, 2009 | GE Profile PFSF6PK Bottom Freezer French...
NO DRINKING WATER
common problem the water line inside the freezer door is frolzen up . to fix remove everthing from the freezer door , turn off freezer . open freezer door and put a blanket over the opening to the freezer leaveing the door to room temp for an hour or so to defrost . check if defrosted . remove blanket close door . this will happen with ge , try seyying the freezer control on the next lower number (warmer)
Jan 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge Profile bottom freezer, french door refrig, water filter
Just replace GE's filter with a standard inline filter that hooks to 1/4" water line tubing. Sounds like their filter has no flow rate either...
Here's a popular one:
http://cgi.ebay.com/AICRO-GAC-IN-LINE-FILTER-2-X-10-X-1-4-FNPT-JG-FIT-/390180520853?pt=LH_DefaultDomain_0&var=&hash=item99ab36a9be#ht_500wt_721
Jun 27, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PDS22SIS ice maker problem
on the ice maker press and hold the size selector. This will put the ice maker into a test mode and it should cycle through. If it doesn't work your problem is with your icemaker.
Sgt 48
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
Refrigerators Logo
269 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
