Question about Garmin Rino 530 GPS Receiver
My rino won't charge
After having it connected to the charger for a few hours it still registers 0% on the battery, figured it was bad battery so bought new one. same thing.
    Top Expert:
  • 14,553 Answers
Two things occur to me: possible damage to socket where charger connects to unit------or no voltage from charge source to the battery
A lot of the connectors where the unit connects to power are easily damaged.
Posted on Nov 03, 2012
3 Suggested Answers
SOURCE: Rino is burning through the batteries.
sounds like the battery needs to be replaced, mine last for days. it may have burned a memory into the battery
Posted on Sep 03, 2008
  • 638 Answers
SOURCE: new Garmin Nuvi 660 gps
Page 2 of your manual shows you that the plug goes into the bottom of the GPS unit. Turn it over and you'll see a slot for the plug.
Posted on Apr 21, 2008
My rino 655t wont take a charge
That unit has a special charger and harness.
Very similar to the Motorola
The Rino 650 and 655t includes a rechargeable lithium-ion battery. If the battery is not charging, ensure the battery is secure and the device is connected via the included A/C charger. The battery will not charge when connected via USB cable.
May 02, 2014 | Garmin Rino 655T Topo Gps 2-Way Radio
Battery not charging
Is it loose connection. or any problem with charger or tablet. give it to any service centres
May 24, 2013 | Samsung Tablets & eReaders
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Laptop won't charge?
battery is dead. change the battery.
Aug 12, 2012 | Computers & Internet
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
BATTERY SHOWING CHARGING, BUT SHOWING 0% AVAILABLE
This is an indication that the battery is dead. A dead battery won't accept any charge from a charger. If the laptop will operate when plugged in with or without the battery, it's a bad battery.
Nov 09, 2011 | Computers & Internet
My Samsung Captivate won't take a charge. It works on the both house and car charger but as soon as I take it off the charger it shows zero charge left and quickly shuts down. When I leave it on the...
I want to let you know that the battery of your phone is bad.
Please, replace it with a new battery.
Please, when you want to buy your battery, make sure you buy it from samsung shop because there are many shops selling fake batteries.
Thank you and God bless you for contacting FIXYA.
Sep 02, 2011 | Samsung Captivate Cell Phone
My battery for canon camera 550d flashes orange when charging, its been 4 hours now and it hasnt turned green yet.. I am charging it first time.. is this normal
Okay what happens sometimes is the charger gets into a feed back loop. What to do is remove the battery unplug the charger wait a few seconds (Maybe 20/30) plug the charger back into the outlet and then put the battery back in the charger. It should start to charge again and a few minutes later go to the blinking for full charge green.
It'll happen the other way as well meaning if the battery gets a memory (they say they don't but they do) you need to unplug the battery let is sit till it's cool and put it back on charge again. I've had this problem many times and have put it on charge and back off several times with in 15 minutes before it started to charge as it should.
Also these batteries do have a life span and if it's a three year old battery with many charges it could be failing meaning it just won't take a full charge.
Apr 19, 2011 | Canon Cameras
Plug charger in and will not charge the fan on the charger quits running in a few seconds it will beep with charger pluged in and when you unhook charger it clicks like a dead battery i wonder if charger...
David Are you leaving the power on while you are charging the Chair? If you are try charging with power off at the joystick. The manufacturers of all power batteries do not recommend charging with automotive chargers. I would try to locate a friend or neighbor that also has a chair or scooter and borrowing their charger for a few hours to see if it will charge your chair. If not contact your provider and borrow a charger from them. If the different charger works then yours is bad. You shoud be able to order a charger through your provider or by calling Pride Mobility @ 1-800-800-8586 Hope this helps you PS I didn't say you couldn't use the "other" charger. But I wouldn't want you to think I approved of it
Oct 02, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Garmin Rino 530 GPS Receiver Logo
571 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
