Question about Danby DMW1153 Microwave Oven
Paint worn off inside and metal showing
Is the microwave safe to use? It's only 3 years old and work well, but I am concerned about the bare metal. Thanks
  • Danby Master
  • 9,098 Answers
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Posted on Jan 04, 2009
Was working then made a raspi noise now nothing works
Sounds like you might have a problem with metal in the oven. Look inside the oven including the "ceiling" and see if the finish has worn off, leaving bare metal. If so, wash that area thoroughly, dry, sand lightly. Then apply some appliance paint that comes in tiny bottles and costs about $4.
Nov 16, 2013 | Amana ACM1580AS Microwave Oven
Lg combi multiwave
see the troubleshooting section and follow the steps and fix it.
God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Sep 30, 2013 | Microwave Ovens
Microwave when turn on making a noise and sparks comin from fan area?
follow this steps and fix it. God bless you
Waveguide Cover
Rack Support
Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
The paint in the bottom of my microwave is peeling badly so I scrasped and sanded the loose off. is it still safe and healthy to use
You can apply some ceramic paint on to the worn out portion so as the bare metal is not visible .
Please check up with the paint store for the paint non conductive ceramic paints which can be coated using brush or a spray gun.
Apr 18, 2011 | Emerson Microwave Ovens
Bought daewoo microwave KOR-6L15/ aug 2009 9 mnths use paint pealed exposing bare metal , asda (4944) replaced it like for like , new micro has the same problem paint peeling worse than the old one .my...
Go and talk to them, it's obviously not fit for purpose and in the circumstances they should replace it.
They offer a years guarantee and that's what you have had but you also have rights under the sale of goods act. for the item to be merchantable quality which it is not.
Ask to see the manager, be polite and firm.
good luck
Mar 02, 2011 | Daewoo Microwave Ovens
The paint is coming off the inside of my ge microwave. is it safe to use?
No it is not safe! the white paint is a special type designed for microwave ovens that prevents arcing from the magnetron, because when you get down to bare metal it will cause problems. I would try and contact the GE manufacture or appliance repairman to see if he has the paint available for this kind of work.
Jan 19, 2011 | GE Microwave Ovens
Whirlpool gold GT4175SPS-2 inside door paint is flaking and revealing metal. Is it safe to use?
Scratches, flaking and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord first.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
May 09, 2010 | Microwave Ovens
Paint chipping of the inside of door of my sylvania microwave . There is bare metal under the paint .You can see how this is an issue.The warrenty numbers in the product manual are all disconnected...
well apart from replacing the door if clean the old paint away then you can paint the door with an enamel paint the colour of your door but it must enamel paint or microwave paint gd luck
Oct 06, 2009 | Microwave Ovens
COATING ON INSIDE OF MICROWAVE HAS STARTED TO COME OFF, EXPOSING UNDERNEATH SURFACE, IS IT STILL SAFE TO USE AND EAT FOOD COOKED IN IT?
Nothing special in there. As long as the paint is not flaking into the food you are ok, Be aware that bare metal could begin to arc. There is special microwave paint available but it will not match and look bad unless you redo the entire interior.
Eric
Sep 15, 2009 | Panasonic NN-T990SA Microwave Oven
Bottom of GE interior door microwave is burnt/rusted
just use sand paper to clean the rust then use some high temperature paint (sold in tins) eg spray paint but it must be labeled high temperature and spray 2 to 3 coats . your microwave should be safe again
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Danby DMW1153 Microwave Oven Logo
513 people viewed this question
Top Danby Microwave Ovens Experts
William Miller
William Miller
vince
gbob59
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
