Question about Sears Vacuum Shredder Bagger Replacement Bag.806008
Need bag for craftsman 113796811
My bag has holes in it and the screen portion is ripped in numerous places. I would like to find a proper replacement bag close to the original size. Found one at lawnbagz.com that is 50% larger which will make it more difficult to handle as it fills.
How do I remove and replace the inverted bag filter?
Inverted filter bags can be tough to remove. The best way is to grab the bag closest to the top portion where it attaches to the canister. The bag is locked in place by a metal rings that presses out. You want to grab a portion of the bag (some bags have a holder tab) and pull towards the center. The goal is to make a C shape of the ring that is holding the bag in place. Once the bag collapse into a C shape, the bag can be removed and cleaned or replaced. The same technique is best for re-installing the new or cleaned bag.
Check out our website if you need replacement parts or you have more questions.
NuTone Central Vacuum Systems and Replacement Parts
Don't forget to visit and like our Facebook page https://www.facebook.com/QualityHomeSystems
Nov 05, 2015 | Broan-NuTone CV570 Central Bagless Central...
Craftsman Sears Radial Arm Saw Rip Lock doesn't lock
Is the cam (815671) in place? Is it worn out? Check it.
Feb 28, 2014 | Craftsman Sears Radial Arm Saw Rip Lock...
My craftsman 22" self propelled
Your problem is at other end . Engagement problem is probably due to a loose belt. Make adjustment in that area of mower. GOOD LUCK.
Jun 16, 2011 | Craftsman Garden
How to remove bag
Usually you just lift the bag at the top rear portion of the bag and pull away from the unit. Make sure to also hold the door lever if your unit is supplied with spring loaded door. Ms. Purebred.Good Luck...
Jun 09, 2011 | Craftsman Front Propelled Rear Bag Lawn...
My bissell powersteamer isnt suctioning the water
Please try the following suggestions to see if you can get your machine suctioning properly:
1) Remove the Tank-in-Tank Assembly and place your hand over the motor intake valve. This valve is located next to the Floor Nozzle gasket (at the top of the Floor Nozzle window) and behind the SmartMix Bottle. If you feel vacuum-like suction at this area, your suction power of the unit is working but air is escaping at some point. If there is no suction at the motor intake valve your machine will need to be inspected by an Authorized Service Center Technician.
2) It is possible the Floor Nozzle on your machine is inserted incorrectly. This would directly affect the suction of your machine. Please follow the directions below for removing and replacing the nozzle.
Before starting, please be sure the machine is unplugged and the machine handle is reclined.
To remove the Floor Nozzle window, first detach the Phillips head screws located at the base of the nozzle. Then, remove the Tank-in-Tank Assembly. Next, pull forward at the top of the Floor Nozzle window to release the tabs of this window from the receiving holes of the machine. This window is designed to allow access for cleaning.
When replacing the Floor Nozzle window, please be sure the tabs at the TOP of the nozzle are properly inserted into the receiving holes provided. If you do not have the tabs in place properly, the suction power of the machine could be affected.
Rotate the window down into place and replace the screws.
3) Ensure that the Ready Tools knob (diverter knob) is in the proper setting and the valve opens and closes freely. Ensure the black foam gasket is in place under the valve.
4) Check to ensure the Tank-in-Tank assembly is seated properly and that it is not full of dirty water. (If this tank has a drain cap, make sure it is in place and that it has a black o-ring).
5) Check the float and baffle to ensure they are properly installed on the Tank-in-Tank. The larger square portion of this part should be below the clear baffle of the tank with the red flag portion of the float resting on top of the baffle.
6) Check the Tank-in-Tank and lid for damage. Is the lint screen clogged? Make sure the lint screen is in place on the tank lid and not placed into the motor duct. Also, clear the holes on the lint screen.
7) Check to see if the upholstery hose has suction. If the hose has suction and the floor nozzle does not, check the diverter valve to see if it opens and closes freely. This can be seen through the Floor Nozzle window as you switch the diverter knob from the floor to tools setting.
Nov 05, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Vacumm not working shampoo the rug but does not pick up dirty water
Try the following suggestions to see if you can get your machine suctioning properly:
Aug 04, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
The bissell proheat will not suction
Jun 15, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
No suction
Jun 15, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
My bissell will not **** up water
May 19, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
I have a Craftsman Push Rear Bag Lawn Mower w/ High Wheel it's a 6.50 Briggs & Stratton Engine. I changed the oil by turning over the lawn mower and draining the oil from the dip stick hole. I also...
Your mower should definitely have an air filter whether it is paper or foam, and you should drain the oil from the bottom, not turning it over. turning it over can get oil in places where it shouldn't be and make it smoke or not run at all. It may need carburetor cleaning and spark plug cleaning or replacement, or the flywheel key may be sheared if it runs rough
Sep 27, 2009 | Garden
Sears Vacuum Shredder Bagger Replacement Bag.806008 Logo
81 people viewed this question
Top Sears Heavy Machinery Experts
Roland W VanLue
Roland W VanLue
Matt Olenzek
Matt Olenzek
Are you a Sears Heavy Machinery Expert? Answer questions, earn points and help others
