Question about Clymer Harley-Davidson Dyna FXD Evolution 1991-1998
No spark,no power to ignition module
Changed all the fuses,have power to everything but the ignition
  • Clymer Master
  • 2,963 Answers
Do you have power to the fuse? Sometimes fuses look good, but are actually bad. Check with volt-ohm meter. otherwise bad connections and or wire, corrosion causes a lot of bad behaviors, clean to bright metal for all connections and contacts. Again check with volt-ohm meter, or "indicator" light method.
Posted on Apr 11, 2015
Installed aftermarket stereo and now car want start but everything else works
Switch the wiring harness for the cd player back. t probably disabeled the ignition systime in the car.
May 01, 2014 | Brembo 2007 Dodge Charger - SXT, RWD -...
How to fix - unit sparked and died
It's best to have it checked by a professional technician. Sparks can lead to fire.
Jan 04, 2014 | Panasonic Mc-Ul592 Eco Max - Bagless...
I'm installing a new ignition module on a bc24w weedeater trimmer--the part has 2 screws holding it on-it is apparently adjustable--what gap setting should I use between it and the magnet (armature &...
I usually use a match book cover between it and the magnet. this way the gap is about right and it will not hang on the magnets. put through both sides at once, then push it in and tighten it up. then take out guage. spark plug gap is .025, the armature gap on most small engines is .010,
Aug 20, 2010 | Vacuums
I have changed brushes, everything on my robot and he still stops every few minutes and says change brushes. any help?
if you still have warranty, call iRobot.
if not, look for how to clean the Cleaning Head Module CHM
this is very simple to do but remember you'll need Lithium Grease to complete the job.
Good luck
Apr 07, 2010 | iRobot Roomba 560 Robotic Vacuum
Handle gets very hot on my 5892BVZ vac
i have a 1998 chrysler sebring convertible stop starting by the ignition switch,we changed starter,ignition switch been changed,changed starter relay,trace the wire haven't found a broke are burned place in it,checked igniton fuse its good,didn't see a linkable fuse
Sep 23, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Nilfisk c120 vacuum - no power
The fuse is part of the motor so is not something that can be changed. Make sure that there isn't a break in your power lead at the plug.
Mar 15, 2009 | Vacuums
Clymer Harley-Davidson Dyna FXD Evolution 1991-1998 Logo
43 people viewed this question
Top Clymer Vacuums Experts
cgswift
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Clymer Vacuum Expert? Answer questions, earn points and help others
