Question about Maytag MFF2557HES Stainless Steel French Door Refrigerator
I have maytag mff2557hes fridge that seems to run more often than not. Freezer and fridge cool fine but it seems to run all the time. Is this normal?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Pull the unit out from the wall and check the coils at the compressor for lint and dirt buildup. The coils and fan should be free of any debris to operate correctly.
Posted on Nov 03, 2012
  • Michael Brown Nov 04, 2012
    Don't know if that is the problem but it did need cleaninng.Thanks for the input and I'll keep an eye on the situation and let you know if it did the trick.
  • Richard Roth
    Richard Roth Nov 04, 2012
    OK,keep me posted!
  • 531 Answers
SOURCE: my maytag fridge model number msd2657hes wont cool
you have defrost problem
Posted on Apr 06, 2009
  • 4 Answers
SOURCE: Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Posted on Apr 19, 2009
  • 363 Answers
SOURCE: maytag mff2557hew fridge not cooling. Freezer ok.
Sounds like the Freezer Fan is wearing out or is worn out. This fan problem is very hard to detect. The reason is that when the motor is starting to wear out the fan will spin, but at a much lower rpm. This is enough to keep the freezer cold. but will not ciculate enough air thru the freezer and the refrigerator to prevent freezer from and refrigerator from cooler. The cost to repair/replace this fan is a minimum of $300.00
Posted on Jul 28, 2009
Testimonial: "Your solution was right on the mark! The fan was spinning but not fast enough (according to my repair guy). Thanks again!"
  • 80 Answers
SOURCE: Fridge running hot!
One you can to try and extend the life of the fridge is to vacuum off the compressor and coils. They can be located either behind the toe grill on the bottom front or through an opening on the back of the fridge. It is natural for a fridge to blow warm air.
Posted on Aug 30, 2009
Testimonial: "I vacuum cleaned the coils and compressor. Everything seems OK. I know it is necessary for a fridge to give off heat; but it seemed excessive."
  • 2341 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
Freezer not cooling, but fridge works fine
In most cases the problem you are having is a defective start relay, overload and run capacitor. These parts can wear out or the symptons are caused by a defective fan motor. What is the correct model number? Sea Breeze
Sep 25, 2013 | Maytag MFF2557HES Stainless Steel French...
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
The bottom freezer works but the refrigerator will not get cold. model# MFF2557HES
Sounds like airflow fan needs to be replaced. Most fridges use a small fan that blows air from the freezer to the refridge. If that fan fails you get working freezer and non cool fridge.
May 06, 2011 | Maytag MFF2557HES Stainless Steel French...
The freezer is fine, but the refrigerator seems to be working below normal. What could be the problem?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 26, 2010 | Maytag PTB1953G Top Freezer Refrigerator
My freezer is cold but my fridge is warm.
heatman101
Nov 06, 2010 | Maytag MFF2557HES Stainless Steel French...
The fridge and freezer are both working normally. However, water is leaking out of the freezer compartment. We have checked the hose that feeds the water supply to the ice dispenser and it looks fine. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Maytag Refrigerators
My frige is not cold, just cool, turn the T stat to coldest & no good. The freezer seems fine & I looked in the back & the fan is running. It doesn't seem to be blowing cold air or...
Two thoughts. If the fan is running... and you can here it in the freezer when it is on. Then the fan is fine and it is the mixer control. IF the fan is not working, then fix the fan.
The mixer control is in the top of the fridge where the air comes out on the wall between the fridge and freezer.
I think maytag calls this a cold control / damper.
Basically it controls the air flow rate between the fridge and freezer. When it is opens it allows air from the freezer into the fridge and cools it off.
Hope this helps.
Jun 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
My Refrigerator and Feezer are not cooling. mff2557hes
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
we
Aug 01, 2009 | Maytag MFF2557HES Stainless Steel French...
Maytag side by side slowly getting warmer
I have actually been having the same problem. We have a Maytag MTB2156GEQ and it hasn't been cooling well at all lately. Temp in the fridge is about 52 degrees even on the highest setting. The freezer seems to be fine. I pulled off the back panel and vacuumed out the condensor coil and everything else under there. I then pulled out the control panel on the ceiling of the fridge. The channel between the freezer and fridge was almost completely blocked with ice. I cleaned it out by taking out the back panel of the freezer and pouring hot water down through the hole until it was clear.
that seem fix the issue.
Aug 10, 2008 | Maytag MSD2656G Side by Side Refrigerator
How to examine MFF2557HES evap fan?
Yes, if you're not afraid of removing service panels and replacing parts, then this is something that you can probably replace without too much trouble. Very straightforward, just remove the fan motor assembly & screw a new back into it's place. And yes, that sounds very probable if you've already tried defrosting the machine first.
Aug 04, 2007 | Maytag MFF2557HES Stainless Steel French...
Maytag MFF2557HES Stainless Steel French Door Refrigerator Logo
237 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
