Question about Philips HTS-3555 System
I have a hts3555 and the dvd player isn't working.
It either won't read the discs at all or, when it does, it freezes every minute and a half. it's only about 3 years old.
  • thebrittcrow
    thebrittcrow Nov 03, 2012
    the cd player does the same thing.
5 Suggested Answers
smeago1
  • 136 Answers
SOURCE: trying to play hddvd onhdmi player
i don't think this model plays hddvd you will need a seperate player for these discs.
you can only play normal dvds not HDDVDs
good luck
smeags
Posted on Dec 31, 2007
SOURCE: Dvd tray wont open or close
if the tray is not working, check the belt in the motor, maybe it is lose, or check the limit switches, maybe one of those is malfunctioning. actually they has 3 wires.
Posted on Feb 16, 2009
  • 4234 Answers
SOURCE: 4 DVD players unable to read the disk.
The disc cleaners that can be purchased are little more than brushes that can clean dust only. If you can gain access to the lens of each unit, try cleaning the lens carefully using a cotton swab and alcohol. That should resolve some of the problems. If not, then for some reason you have multiple failed optics assemblies.
Dan
Posted on Feb 17, 2009
dobhan
  • 105 Answers
SOURCE: my home theater system dvd
once the lens of your dvd player is defective it can't read anymore.bring it to a qualifeid technicians and replace the defective....
Posted on Jul 23, 2011
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
My Road view in the vehicle was working fine...2 day's ago..it's saying 'bad disc' the disc's are all clean and new..I unplug it.. and still saying the same thing.
see this causes and fix it. God bless you
If your mini DVD player reads "No Disc" after you've loaded the disc, it means the machine isn't reading the DVD. Take the DVD out again and clean it. It's quite possible that the disc is simply dirty and cleaning it will solve the problem immediately.
However if the problem persist test the following:
  1. Bad connections to one or more buttons or sets of buttons.
  2. Microcontroller failed to reset properly.
  3. Missing/bad voltages from power supply.
  4. Defective microcontroller or other logic.
go to the repair shop FOR fix it.
Oct 15, 2012 | Roadview Rd615 DVD Player
Vizio DVD/bluray player won't work
not clear in the video the detailed problem. ok if dvd player won't read cd tried to insert other cd's which not the same region. if still won't read you can use a disc cleaner to clean the laser lens which too dirty or sticky .
Oct 06, 2012 | Televison & Video
My portable dvd player PET704/05 isn't reading a
Overtime the laser pickup becomes weak until it can no longer play, try cleaning lens with a Q-Tip and rubbing alcohol gently, allow several minutes to dry. if no change! cheaper to replace the player.
Mar 09, 2012 | Philips Televison & Video
Hts3555 will not read disc
Hi
Is it all discs or just one?
Try several discs and see what happens.
If its all discs,try cleaning the lens using DVD lens cleaners.If this doesn't solve the problem,have the lens replaced or if the machine's still on warrant,have its owning company do it for you.
Hope it helps.
Feb 20, 2012 | Televison & Video
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Jul 28, 2011 | Cyberhome CH-LDV1010A Portable DVD Player
Everytime I put a disc in I get an error saying no disc
Does the disc you insert are original..If not is isn't posibbles for your dvd player to not recognize yor disc cause most of the branded dvd players like you have didn't read pirated disc..but if the disc you insert is original. Try to clean your dvd player using a dvd disc cleaner.
Jul 17, 2011 | Philips DVP5982
Philips HTS-3555 System Logo
54 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
