Question about Kenmore Dishwashers
Where is the hi limit thermostat located on a kenmore elite dishwasher
  • 38 Answers
Behind the console panel
Posted on Nov 03, 2012
Kenmore elite oasisst
Yes you can order it! I ORDER STUFF from Amazon or appliance parts pros .com but if you want the part rite away try tribbles appliance parts they have locations all over baltimore and they will definately have a hi limit thermostat kit in stock for you.THe one I go to is on greenspring drive in timonium
Apr 16, 2014 | Dryers
Kenmore elite dishwasher smart wash flashes
This sounds like a door switch that is faulty on your main door so the system gets a signal saying its not closed properly and there for signals fault
Dec 20, 2013 | Dishwashers
Does the Kenmore Series 700 dryer use circuit breakers or a thermal fuse to shutoff the heating element?
All Kenmore Electric Dryers use a thermal cut-off or thermal cut-out, hi-limit thermostat, and a cycling thermostat apart from the motor centrifugal switch as parts of the heating circuit. The thermal cut-off/thermal cut-out and the hi-limit thermostat are located on the heater duct/element duct while the cycling thermostat is located on the blower housing.
The thermal cut-off/cut-out serves as a safety measure and blows open should the dryer overheats or should the hi-limit thermostat fails to cut off power to the heating element. Check the continuity of the thermal cut-off/cut-out and if open, replace it including the hi-limit thermostat.
Aug 22, 2011 | Dryers
Kenmore elite dishwasher will not drain completely
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 02, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Model 110 73932101 kenmore elite. Blew the circuit board replaced it and checked the relays. Wont heat, found the thermal fuse is blown. Checked the high limit thermostat and the thermistor. Thermistor...
there is thermal fuse, Hi limit, and thermistor. the thermistor should have continuity at room temp I don't know what resistence(ohms) it should have. Most units I have seen provide a schematic and trouble shooting guide taped under the control panel for service personal.
Apr 15, 2011 | Kenmore Dryers
No a kenmore 80 series dryer will not heat . if the heating elment is good & fuse is good what else could be the problem
The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Mar 09, 2011 | Kenmore Elite HE3 Steam 8676 Dryer
Model 655-17014401 clean light (green) flashes but dishwasher won't start
This means you have an open heat circuit. It could be either a bad heating element, a bad hi limit thermostat, or a bad control board. The heater and hi limit therm can be tested for continuity with an ohm meter. Most of these units the heater will come with the control board in a kit. Hope this helps.
_MJ_
Dec 15, 2010 | Kenmore Dishwashers
Hi, I have a Kenmore Elite electric dryer model#
If your fuse is blown could be that your operating thermastat is not shuting off as soon as it should. Try replacing the fuse and the operating thermastat. The fuse would probaly blow before the hi limit.
Jul 16, 2010 | Kenmore 62802 Electric Dryer
Hot side wall and staus lights stay on
repl/ hi limit and safety thermostat,, will solve prblems
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore HE4 dryer
repl/ hi limit and safety thermostat should fix problem //
Sep 27, 2008 | Kenmore Elite HE4 Electric Dryer
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
