Question about Bushnell 26-0400 Binocular
They don't turn on
My turn signals don't work and I've checked the bulbs, fuses & flasher.
About all that is left on the list is the turn signal switch.
Do you have power in and out of the switch ?
Feb 04, 2013 | 1995 Buick Skylark
1997 honda civic died on the road wont turn over
Start with the battery unless fairly new & have that tested
Next turn key on & listen for fuel pump
It may run but not have pressure or volume
Check fuel pressure at motor with a gauge
Any light on dash & you checked for codes
didn't you? What are they?
Turning over & Starting are two different things,
don't use them together,different systems there
Oct 03, 2012 | Honda Cars & Trucks
Marshall MG30FX loud tapping sound in time with delay even when no guitar plugged in and effects turned off
Hi J Wade. I'm Dave P. I'm not a guitar amp expert or technician but I've been using amps and effects for 35 years and there are a couple things I can suggest.
That kind of periodic noise/switch noise can be a symptom of having the polarity of the amp reversed. If your amp has a 3-position OFF/ground switch, try reversing the ground. If it doesn't, take the plug and turn it around. Just don't get near a microphone unless you're sure your amp is grounded the same as the P.A. It could fry your lips off.
Dirty switches to that too. You said the noise is in time with the delay's tap time which is set by a foot switch. If tapping that switch the first time generates a pop, the delay may have catch it and is repeating it. Turn off the amp, remove the delay foot switch and turn it back on. Still noisy? If not, give the foot switch a good cleaning.
When you turn the EFFECTS knob up, is it scratchy? Might need the potentiometer cleaned. What happens when you specifically turn the DELAY level down all the way while using the other effects? Noise still there?
That's all I've got. Hopefully, it was helpful. Don't wrack your brain over this too much. There could very well be an internal problem with your amp that will require a trip to the shop. You don't want to open it up yourself. Rock on but be safe.
Dave P.
Aug 22, 2012 | Marshall Amplification Marshall MG30FX...
My turn signals don't work but the hazzards flash
if your hazzards flash, that means your bulbs will be good but, your turn signal fuse is blown. you should check that first, & don't forget to turn off your hazzards before you can see if your turn signals work again. give it a try.
Dec 01, 2011 | 2000 Dodge Caravan
My 2002 Grand Prix sounds fine upon starting. When I get to 45 mph, it starts to sound as if it's working harder. It's like a loud hum starts and gets louder as it goes up to 60 mph. As I decrease...
Front Wheel Bearing Hub
You will have to remove the brake calipers,hang it,&
remove the rotor,then you can turn the hub & feel the
roughness.
ROCK AUTO.com for parts & look at that hub, so you
match it up the same. Don't get in love with one brand
you like, if the hub looks different at the back where the
speed sensor goes in
You also may find your self buying a torx socket or metric
socket driver to get the speed sensor out. Maybe not
If tools are needed,do yourself a favor & step inside a Snap-On
Truck & just buy one item or so. If you don't ,you won't find those
items anywhere
Sep 21, 2011 | 2005 Pontiac Grand Prix
Can't remove lens cover on rear to access burned out bulb. Screws are out but don't want to crack the cover.
it may be possible that you don't have to remove the lens cover to replace the bulb, in most modern vehicles the bulbs come out from inside the trunk by turning the fitting & pulling the bulb out & replace it the same way by putting it back in & turning it in the opposite direction to lock it in place.......hope this helps......cheers.
Sep 04, 2011 | 2002 Mazda Tribute
My camera fell in the sand I don't know if the sand got stuck in it & I don't know if that is what is causing the problem with the lenses not opening
is it notifieing you that there is a lens eror? or does it just not turn on? This type of problem you won't be able to fix yourself, and don't try to either! You will need to contact Kodak and tell them there is a lens eror (don't give details that you shouldn't be giving), hopefully they will be willing to fix it for you or replace with refurb.
Aug 30, 2011 | Kodak EasyShare M1093 IS Digital Camera
The blue remote wire where do i connect it and how? Is the head unit the deck car deck i mean? No power light
The blue remote wire is a wire that you connect to an amp which will turn the amp on when the radio turns on. If you don't have an amp don't connect it, just tape it up
Jul 12, 2011 | Car Audio & Video
Hi! I have a Jensen XA2150 Amplifier, from the speaker output I have connected a Subwoofer Sony 10 inch 1100W. Tha'ts gave me a nice bass sound, but now it's death! The amplifier have a 25A fuse,...
Have you checked the fuses inside the amp?Unscrew the cover and with the amp sitting on its back,remove the cover.You have 2-4 fuses,old round type,in there.
May 21, 2011 | Jensen XA2150 Car Audio Amplifier
Bushnell 26-0400 Binocular Logo
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
