Question about Dishwashers
Dishlex dx300wa starts and runs for about 1 min then stops and the
  • justin briant Nov 03, 2012
    Heeld the eco switch down the let go and eco and wash lights are on
  • 38 Answers
Sounds like the control boars has an issue
Posted on Nov 03, 2012
5 Suggested Answers
SOURCE: looking for a owners manuel
just kept on serching till i found it
Posted on Nov 07, 2008
  • 713 Answers
SOURCE: Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Posted on May 05, 2010
caroldon
  • 17130 Answers
SOURCE: I've just replaced the front
Possible that the door switch is defective and so the entire function is put on HOLD.
So trace the connection to the door switch to check the continuity of the switch . If there is no contact of the switch you need to replace .
If not check the lines to the other sensors to see if there is an error sensing that makes the main circuit to be kept on hold.
Since your main board is a new one , we need to look only on these two issues.
Finally is there any action of the control panel reflecting on the program. If not remove plug keep aside for few minutes and replug with the stop/play button pressed.
Posted on Dec 18, 2010
kdrake84
  • 262 Answers
SOURCE: dishlex dx300wa wont heat water,new thermostat and
First of all how do you know the thermostat and the heater were bad?
Did you check both parts with a volt meter by checking continuity/resistance?
First thing we need to do is if you dont already know, learn how to use a volt meter. It takes all the guessing out of the troubleshooting.
Watch the movie click the link http://www.youtube.com/watch?v=nddAA5IAUik
You will need to check for power at the heating element when in the dry cycle 110vac
let me know about the voltage reading email me kdrake84@yahoo.com
Sounds like it's not being told to turn on.
if no voltage at the heater,you will need to trace the power source back to the control. Which is located behind the control panel where your touch panel is in the front top of the unit.
Posted on Feb 06, 2011
Starts to fill on normal cycle then stops and fast cycle light comes on
If it's like a Dishlex 300, the fast cycle light means there is a blockage in the drain line, somewhere. Check and clean your filters. Also, check your drain hose going to the sink for a blockage.
Nov 04, 2014 | Dishwashers
Electrolux EIFLSI5IIW1 stops at 1 min left in cycle
I have solved same problem with washer Electrolux EWS1066. All cycles stops after starts with 1 min left on display and open inlet water valve. I think that was bad door interlock but it was a defective main controller. No damage visible on board than I heated PCD with heater gun mainly pointed to SMD parts. Now washing machine work good.
Oct 14, 2014 | Washing Machines
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Dado
Sep 03, 2014 | Electrolux Dishwashers
How stop sprinklers from starting over
You only program the first zone to turn on at a specific time. The rest of the zones go in sequence.
Aug 22, 2014 | Orbit 6 Station Indoor Dual Program...
Apr 24, 2010 | Dishwashers
My washer stops with 1 min. left on the cycle. It
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Kenmore Washing Machines
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
Nov 09, 2008 | Whirlpool GHW9400 Front Load Washer
Can you connect a dishlex global 300 dishwasher to the hot water supply?
Hi Devilnz_05
I have a DX300WA global model and the instruction manual actually recommends that you use the hot water outlet for a better cleaning result, but of course it is not mandatory.
May 04, 2008 | Dishwashers
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
