Question about Harmon Kardon Harman Kardon Avr 146 5.1 Channel 40 Watt Receiver
Harmon/Kardon AVR 146 wont stay on when hit power
When I hit the power button to turn unit on it will stay on for roughly 10 seconds and then turns right back off.
    Master:
  • 444 Answers
Probably was damage buy a power surge, Internal damage to (Reciever)
Posted on Nov 03, 2012
  • brandon_g564
    brandon_g564 Nov 03, 2012
    well see that is the thing, it was never plugged in before, we had just taken it out the box and was going to set it up.
  • Rocky Degelman Nov 03, 2012
    It would of been nice if you would of told people that from the start,
Harman Kardon 146 receiver not turning on.
Possible blown fuse inside unit, unplug and remove the top cover
fuse should be near the power board and transformer. replace with exact fuse, "Never remove covers with the unit plugged in" Always wait 4 or 5 minutes after unplugging to remove the cover.Replace cover before plugging unit back in.
Oct 06, 2014 | Harmon Kardon Harman Kardon Avr 146 5.1...
When i turn on my harmon kardon avr 165 it shows ''Protect'' and then it turns off again?? what can i do :)
I would try disconnecting the speakers, then turn it on. If protect still shows with no speakers connected, then it needs to go to the repair shop- Might be a blown power transistor.
Oct 24, 2013 | Harmon Kardon Harman / Kardon AVR 165...
Harmon avr 445. Wont. Turn on
First check power cables and fuse
Jul 08, 2013 | Audio Players & Recorders
Harman Kardon AVR7550 turns itself off.
check to see if there is a reset switch inside on transformer bd. could be dirty. clean with contact cleaner.
Nov 26, 2011 | Harman Kardon Audio Players & Recorders
Hi, I have a Harmon Kardon Model No. AVR 325 that keeps clipping. When I push the power button the display turns off like a second after I push power. Seems like its a easy fix. Nothing if fried visually...
it sounds like Amp burned, but not all burn parts you can see, you have to measure them by DMM. I guess at least one AMP transistor shorted. you can check SPK terminals by DMM DC, it can be easy to find different with other one
Mar 19, 2011 | Harman Kardon AVR 325 Receiver
I have an Harmon Kardon AVR 85 and the power will not come on. The batteries are good in the remote, I have unplugged and plugged the unit back in, but the red light stays on and will not power up. How...
First of all, if you have just been powering up with the remote, try pushing the actual button on the unit. From owning a HK receiver, I found out that if the power switch is out, it will not turn on from the remote. Duh moment when I discovered this.
It also might be an internal fuse or circuit breaker that is shorted or tripped. If there is not an outside breaker or fuse, send this to a repair person. Sometimes there are capacitors in the power amp circuit that can hold a lot of voltage for a good length of time. You could get shocked. So, you might want to let the repairman handle this. Otherwise check for an outside breaker or fuse, and replace if needed.
You can also check Harmon Kardon's site for customer support.
Feb 19, 2011 | Harman Kardon AVR 85
Problems with setting up Harmon Kardon AVR 146????
in what display i need to put reciver when i use the optical digetal
Oct 19, 2009 | Audio Players & Recorders
Audio problems using a Playstation 3
First try ensuring that "OPT 1, 2, or 3" function is selected depending which one you are using on the H/K 146 (see manual for selection instructions). Next please ensure that the PS3 audio out set to "optical" (Settings/sound settings/audio output settings/digital out+DD 5.1). That should help.
Dec 05, 2008 | Harman Kardon AVR 130 Receiver
Harmon Kardon Harman Kardon Avr 146 5.1 Channel 40 Watt Receiver Logo
491 people viewed this question
Top Harmon Kardon Audio Players & Recorders Experts
Steve
 Grubhead
Grubhead
john h
Are you a Harmon Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
