Question about Refrigerators
I have a whirlpool refrigerator, and as i was moving it a sharp edge nicked one of the cord's wires. Made some sparks, and shorted a wall socket. After stripping and splicing the wire together and plugging it in to a different wall socket, it worked just fine... for a little while. Then it stopped cooling. Lights still work fine, no problems with dust, all the connections are good around the cooling unit and everywhere else i can reach. Any ideas? I'm fresh out, short of tearing off the back panel and checking for a fuze (but first i have to open it, and i can't see how). Any help is appretiated
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Check the overload relay.
Posted on Nov 04, 2012
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
  • 10 Answers
SOURCE: Compressor won't turn on. Lights turn on. Won't cool anymore.
Make sure that the defrost timer is not stuck in defrost mode also the compress may be stuck. you can purchase a compressor booster kit from your local appliance parts store for about $15.00.
Posted on Mar 07, 2009
  • 686 Answers
SOURCE: circuit breaker trips when turning unit on. only unit on circuit has triped on several circuits can find no shorts on wiring.
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
Posted on May 01, 2009
  • 30 Answers
SOURCE: Refrigerator not working, freezer is fine
You can get the step by step instructions (lots of pictures of each step) to repair this exact problem at:
www.AnyoneCanFixIt.com (specifically at http://www.anyonecanfixit.com/household.htm scroll down towards the bottom to look for Warm Refrigerator and Cold Freezer repair). It will save you a lot of money to do it yourself!
Posted on May 28, 2009
  • 93 Answers
SOURCE: whirlpool refrigerator ET18GKXHW0 NW power cord ripped out
The refrigerator should have a wiring diagram. Look in the grill on the bottom of the front of the refrig. Pull that grill off and a lot of times they are in there. Sometimes thay are taped to tha back also. You can buy a wiring diagram just like any other part from Whirlpool or sears parts center.
Posted on Sep 12, 2009
We sold our bosch dishwasher, working perfectly. New owners transported it on its back. Now it won't start, or even show that it is getting power, though the outlet works. What has happened?
Hello KT;
My name is Peter. I am a retired field service appliance technician.
Transporting the dishwasher on its back should not have been a problem. It is only with refrigerators and freezers that need to be transported up right, to prevent compressor oil getting into the refrigerant sealed system.
You may have a power cord problem. You have a 3 or 4 wire power cord. If you have a 3 wire power cord you need a 15 amp circuit breaker. If you have a 4 wired power cord you need a 30 amp circuit breaker.
The wall socket that you are plugged into my not have a ground.
You need to check the wall socket and the wire connects at the dishwasher. Send me a model number so I can see what you have. If you have a 4 wire connection you can chance the cord to a 3 wire. On a three wire you have a neutral and two hot with a small green ground wire. On a 4 wire you have a neutral two hot wires and a neutral in the center with a ground wire.
I would put my money on the wall socket not having a ground.
Send me a model number and I will help you.
Feb 07, 2015 | Bosch Dishwashers
No power to icemaker
There is a bundle of wiring coming out of the ice maker and the black wire has a fuse in that bundle. If the fuse has blown it would indicate a defective ice maker motor or a short circuit somewhere inside of the ice maker. You can find a service manual, tech sheet and a Whirlpool Ice Maker Troubleshooting Service manual on this page=> Leaking Refrigerators I will be here should you have questions, Thanks Sea Breeze
The MFD2560HES uses a D7824706Q Ice Maker Assembly
another source=> D7824706Q Ice Maker Assembly
May 02, 2013 | Maytag MFD2560HES Bottom Freezer French...
Skilsaw 5150 7 1/4'' stopped working, I think it overheated?
Yes, it overheated. Not worth fixing, replace it. What happens is that with a very heavy load the saw tries to run a lot of current through the little coil wires that are only insulated with varnish. They heat up, the varnish melts, and a few of them short out together, which increases the current further, causing more heat and more melting until enough shorting in the coils that it won't do anything except trip a breaker. To avoid this in the future-- always use a heavy-enough extension cord and always use a sharp blade. You need a heavy enough cord so that it can supply full voltage instead of more current. The nick in the cord could have contributed to this.
Feb 13, 2013 | Skilsaw "5150" Circular 7 And 1/4 Inch
Why would my dryer cord burn in two
Well, it didn't just happen.
Here we go.
Someone, (You'll do nicely) needs to find a test meter and begin checking electrical things.
A volt-ohm meter or a multi-meter is what you are looking for.
You will want to unplug the machine, and start with the wall or floor socket, whatever.
If you have a 3 pronged plug, the two slanted straight slots should each show 110 volts.
The "L" shaped hole should show a ground.
If either of these does not read right, there is a problem between the plug and the house/apartment power source.
If you have a 4 pronged plug, the round lug on the plug is also a ground, and it should show ground on the meter.
It is VERY important that each hole in the plug reads correctly.
otherwise a fire could happen.
If all shows good, inspect the dryer where the wire hooks to it.
There are 3 screws with nuts on them in a row.
The center nut/screw should be grounded, the two outside nut/screws should be 110volts each.
If there is a 4th wire, it should go to the green ground wire.
NOTE: Very often older dryers or dryers that have been moved from their new installation can have the "holder" missing.
The holder is a metal clamp that holds the dryer wire from rubbing on the sharp metal edge where it goes into the attachment area of the dryer.
A hardware store can show you what they look like.
I can say they are usually metal, they have a hole in them for the dryer cord, and they have a clamping device with two screws to pinch the cord and hold it from moving.
I hope this helps.
Be blessed
Feb 09, 2013 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Where is the reset button on a ED25SM Whirlpool refrigerator
refrigerators do not have a dedicated reset button, but you can, however, reset your refrigerator in the event of a technical problem.
resetting the main unit
  • 1 Turn the refrigerator's temperature control switch to "Off."
  • 2 Unplug the power cord.
  • 3 Plug the power cord back into the wall.
  • 4 Turn the control knob to adjust it to the temperature you want. leave cord unplugged for about 30 seconds. hope this helps ! good-day !
Dec 03, 2011 | Whirlpool Refrigerators
Thanks for taking my question. Model Info: Whirlpool Accubake system electric range Super Capacity 465...... my wife moved the range to clean behind and it sparked at the plug and blew the breaker. ...
try fitting a new plug. if you do cut back the cord back at least 3 inches try it again. before you do check socket with another appliance.let me know if that fixed it or not
Jul 26, 2011 | Microwave Ovens
I have a Whirlpool ET8GTMXK000. The refrigerator was hit accidently on the side, and it quit working. On the very bottom corner on the left back side there is a black spot where it looks as if an...
You are correct, it sounds like an electrical short happened. I am guessing when it was hit, it caused the cord to get pinched in the metal casing. The pinching must have broken the insulation on the cord and the casing is grounded...therefore, instant short. The unit probably wasn't hurt but will need to have a new cord. If you follow the now unplugged cord to the refrigerators electrical connection, it is probably either held on by crimped connectors. Cut those connectors off as close to the connectors as you can (on the opposite side of the power cord). Follow the path of the old cord and remove it from the unit. A new cord can be obtained from a local appliance store or ordered online from places like applianceparts.com. Put the new cord back in the same path the old cord was removed from. Make sure there is no sharp metal to puncture the new cord where the old cord was pinched.
Hope this helps
Jan 21, 2011 | Refrigerators
Kenmore refrig: when I plug power cord t wall socket, it triggers the ckt breaker
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Hi, There is a shorted wire or the compressor is shorted out...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 08, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Infinite switch sparking!!!!
You have a short somewhere between the switch and the burner connector. Probably a wire's insulation has worn away or melted and is allowing the wire to contact the metal housing somewhere. You will see arc marks wherever the short is located. Look carefully where the wire passes through any holes or where sharp turns are encountered.
Aug 12, 2009 | Jenn-Air SVE47100 Slide-In Electric...
My whirlpool refrigerator trips the main power
Pankaj, Do you have a ohm meter? Sounds like you have something shorting back. First take the meter to the cord. On the end of the cord, you should show no continuity from each male prong to the ground prong on the cord itself. If you show continuity, you have something shorting back. Then I would start with the compressor, Unplug the wires going to the overload and relay, make sure the units unpluged and meter the cord again. If it's ok, then the problem is in the overload and relay. Start there and let me know, if it still showing a short, then we will have to go to the controls, heater, and repeat the process until you find the culprit. Catriver.
Jun 09, 2008 | Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
