Sounds like a board issue. It was something that happened on the Saeco Magic Deluxe's enough to be noticed. The board is not available for magic deluxe's with oval buttons.
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Puddle under the machine means the boiler has broken. Whatever you do do not use the machine any more as the boiler could spray the pc board. If that happens your s.o.l. as saeco does not carry the board any longer.
You can send it to a service center and have the boiler replaced. Lowest charge i've seen is $180.00 usd plus shipping and service charge.
The boiler always breaks due to hard water and calcium buildup threw the machine and not descaling it. Also happens when machine is left on 24/7.
If you have the boiler replaced, use only bottle water and turn off the machine when not in use. Also the machine MUST be descaled bi monthly.
Sound like descaling warning light, need to run descaling solution through the machine (follow instructions, you can download a manual on saeco's website) this light can be turned off by pressing and holding the steam button for 5 seconds.
Not sure which light you are refering to because the far right light shuld be temp ready light. The one you describe slunds like the descale light but that shouold be second to from the left. In which case it is telling you to descale. I can't attach a manual here so do a search for saeco repair and an authorized repair center should be able to get you one.
