Question about Generac 5606 XP Series XP8000E 12,000 Watt 410cc OHV Portable Gas Powered G
Reset change oil message on generac xp8000e
I just changed the oil in my generac xp8000e generator but the change oil message is still flashing.
    Problem Solver:
  • 5 Answers
There is no way to reset it manually. It resets automatically after you run it a few hours.
Posted on Nov 10, 2013
3 Suggested Answers
  • 26 Answers
SOURCE: how do i flash my generac 5000 power plus generator
its the rotor ,the stater ,voltage regulateor or control board. i fix these everyday. it also just be the brushes.
Posted on Jul 14, 2009
  • 111 Answers
SOURCE: Where can i get a new battery for my generac
Well, check your farm supply/hardware stores... some larger hardware chains may carry this battery and even the auto parts stores, some will carry these smaller batteries. Take down the make and model of the generator, or even better, take the battery along and they can fit you up with an alternative brand that will fit the space and provide the proper voltage to crank the generator.
:o)
Posted on Jan 04, 2011
Generac XP8000E how do you replace the battery charger fuse 1.5 all I can find out is you have to remove the control panel. No manual and can't find any info
Roger,
1st check the voltage going into the Battery Charging Rectifier from the alternator. You should get between 12 Volts DC to 16 Volt DC with the engine running.
If you get these results next check the battery. You should get max 13v dc going to the battery. If your battery is not charging on this unit or gets under 12x dc, you need to replace the battery charging rectifier.
http://www.generatorguru.com/battery-charging-rectifier-99302775/
If you need other parts you can find them on this page.
http://www.generatorguru.com/xp8000e/
Hope this is of assistance to you!
Dec 19, 2016 | Generac Electrical Supplies
What kind of oil do you use
Judy, Generac portable generator oil recommendations. Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.generac.com/service-support/faqs/portable-generator-faqs
http://www.generac.com/service-support/faqs/home-backup-faqs
Best oil for Generac generator Lawn Mower and Small Engine Bob Is The Oil...
Generac Generator Oil Change
Apr 18, 2016 | Generac Electrical Supplies
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
How to change the fuel filter on guardian quietpact rv generator
Dec 05, 2015 | Generac Electrical Supplies
On our 20 generac a notice came up tat it needed a oiland filter chnge we did thisbut the message is still there hodo we get his message off andmke thhe light on the side go off thanks
The yellow LED is a maintenance reminder light. To reset a maintenance reminder, press the Enter key on the control panel. The reminders will be displayed at the following intervals.
"Inspect Battery" 1 Year
"Change Oil & Filter" 200 hours or 2 years, 100 hours or 2 years on 20kW models
"Inspect Air Filter" 220 Hours or 2 years
"Change Air Filter" 200 Hours Or 2 years
"Inspect Spark Plugs" 220 Hours or 2 years
"Change spark Plugs" 400 hours or 10 years
Here are a couple of links
5875 Resetting maintenance reminder light question Ziller Electric Inc...
Dec 31, 2014 | Generac Standby Generator - Residential -...
Xp8000e wont start. sound like a dead battery, nor will pull start turn engine over.
have you tried removing the spark plug and see if possibly there's a hydro lock from gas or oil in the piston area of the machine,this will remove any pressure off the starter and also pull rope mechanism,then you can visually look into the cylinder and see whats going on,then if this doesn't help then you may have a locked up engine from lack of oil lubrication and the rod bearings in the sump may be bad resulting in the need for a complete rebuild of the engine,if the engine checks out o.k. then you may have a locked up generator head,you may need to split the two components to find out which is locked up
Feb 03, 2011 | Generac 5606 XP Series XP8000E 12,000 Watt...
Where can i get a new battery for my generac xp8000e?
:o)
Jan 04, 2011 | Generac 5606 XP Series XP8000E 12,000 Watt...
Have XP 8000e Generac -5 months old, Tires are supposed to be solid but have gone about completly flat on bottom, don.t seem solid like ones in store but no place to air up ...cb
These tires are made of a hard plastic with thick sidewalls to hold the generator up. They are not repairable once the sidewalls break down and collapse. The only option is to replace them. If you're still under warranty you can get them replaced under that. Only problem is you'll get the same kind of tires, unless Generac has updated them, and have the same problem in another five to six months. Your best bet is to do some research and find some truly pneumatic or solid/foam filled tires for your generator.
Dec 23, 2010 | Generac 5606 XP Series XP8000E 12,000 Watt...
I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
May 08, 2009 | Electrical Supplies
Generac 5606 XP Series XP8000E 12,000 Watt 410cc OHV Portable Gas Powered G Logo
662 people viewed this question
Top Generac Measuring Tools & Sensors Experts
deton8 von Splosion
David Ellis Rhea
Lucy Angela
Lucy Angela
Are you a Generac Measuring Tool and Sensor Expert? Answer questions, earn points and help others
