Question about Samsung RB1955 Bottom Freezer Refrigerator
Samsung fridge model rb1955sw keeps beeping
Every 5 minutes it beeps, it is working great, but the beeping is coming from behind the fridge and is driving me crazy, can anyone help, thanks
SOURCE: Samsung Fridge can't get temp down
it is probably the door switch. I just pulled the switch from a rb2055 and disassembled the switch. one of the contacts is broken.
If you unplug the fridge and plug it back in, the light should work. push in on the switch button with the door open. If the light does not go out, switch is bad.
pry the switch gently out with screwdriver, unplug it and get a replacement.
If you are watching this I can also probably tell you how to jerry-rig it to run while waiting for replacement swicth.
Posted on Jan 03, 2009
tborn6
  • 700 Answers
SOURCE: beeping
basically its telling you that it's not maintaining the temperature that you have it set for. if indeed you do have this particular model number contact me and i have the service manual for it.
Posted on Feb 04, 2009
odiebugs
  • 949 Answers
SOURCE: Beeping from refrigerator about once a minute.
If this is listed under the right model, then the only thing it could be is some models have a
door alarm,that will beep if the door is not closed. You could check and clean the gasket.
Or it the switch that tells the fridg that the door is closed. Check if there is a top door adjustment to bring the door closer to the fridge where the door hinge is. This might apply or push on the switch more.
Posted on Mar 29, 2009
SOURCE: refridgerator beeps and upper section not working
First, the Samsung Refrigerator is the only fridge that has one compressor, but two different evaporators to operate the freezer and the refrigerator separately. Thus, you can have the bottom freezer working fine, while the fridge part will not.
The reason your fridge is not working is probably a faulty door switch in the refrigerator. The switch is malfunctioning, telling the computer that the door is open. Therefore you hear the door alarm go off in intervals, even though the door is actually closed. If the computer registers an open door, it will not pump cool air into the refrigerator, as that would be a waste of energy. All you need to do is replace the door switch. Until you get a new one, you can temporarily fix your fridge by simply removing the old switch altogether. You will not have any light in the fridge, however, it will cool again just fine until you are able to install the new switch (a simple plug-in contraption, by the way).
Hope this helps.
Posted on Jul 30, 2009
  • 10 Answers
SOURCE: My freezer degree keeps flashing and a beeping
Your icemaker sensor is out of its place. unplug the unit . check bottom of your icemake, the sensor looks like a little ***** , insert it back. turn unit on, and reset the board, Hold power freez, Power Cool for about 10 seconds.
Posted on Oct 31, 2009
I have a samsung side by side fridge freezer model SRS539HW, the alarm keeps beeping every minute to say the doors are open however they are closed. If I manually pust the door closer button it will...
Solved beeping problem.........Samsung SRS539HW . Have one of these and it is 6 years old. I had to replace the bottom hinge on the fridge side(right). Easy job but now constant beeping as if door is open, and light is intermittent. Found that there is considerable wear on the cable through top hinge of door and one of the wires from a magnetic reed switch in door had broken. I discovered this by shorting the two fine wires (white and pink/white) going to internals of fridge.No more beeping due to door opening and light now working correctly. Of course I no longer get a beep for a valid door open to long but cheaper than getting a refridgerator expert in.
Jan 13, 2012 | Refrigerators
Frigidaire alarm for fridge keeps beeping
I would try switching the breaker. That will probably work.
May 15, 2017 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
Refridgerator beeps and upper section not working
Hope this helps.
May 28, 2009 | Samsung RB2155SH Bottom Freezer...
Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Apr 01, 2009 | Refrigerators
Mar 29, 2009 | Samsung RF265AA Bottom Freezer French Door...
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Samsung SR-L39 fridge freezer switching off
replace the thermostat of the freezer
Sep 16, 2007 | Refrigerators
Samsung RB1955 Bottom Freezer Refrigerator Logo
110 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
