My tv is not turning on at all, i unplugged it for like how many days now...what do you think is the problem?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The place to get started is follow power cord inside the set and check the fuse---a brand and model number would be helpful.....
Posted on Nov 03, 2012
Unable to turn tv off
These days its just not cost effective to have a engineer look at a tv,even though i could just be a component costing a few pence thats failed.I would think the tv would come back on if you unplug it.I would then buy a remote power saver 5 socket plug which you can use that remote to turn off the tv and then problem solved.hope this helps.
Jan 10, 2014 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Tv will not turn on leave unpluged a few days plug
The DM power supply board,probobally have those dying leakages gases about to be dead parts call capacitors.U have tools and know basic soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,to replaced those dying capacitors belong in the DM power supply board.
Jul 19, 2010 | RCA Televison & Video
47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Jun 16, 2009 | Vizio VO47L 47 in. LCD TV
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
Apr 23, 2009 | Televison & Video
Picture goes off
A temporary solution is to unplug the TV for a few minutes, remove static from the glass with your hand. It is important to unplug rather than turn off. If you have a degauss button you can also press that before unplugging. Wait several minutes or an hour. Then plug it back in. If you have Picture in Picture it may be an issue with that and to permanently solve may need a repair person. The unplugging may get you by for a few days at a time. That's at least better than an hour.
Mar 13, 2009 | Fisher PC-32S90 TV
TP61H95 Toshiba Cinema Series 61" The Image rolls
defintly the convergance.if the con is on a small board ,maybe 130 big board 250&up.if u know how to solder 35$ each STK and u need 2. and check each internal fuse with a ohm meter with tv power unplugged
Mar 12, 2009 | Toshiba TP61H95 61" Rear Projection...
Sony Grand Wego - Sound but No Picture
Before I commit myself, I need a little more info. First, what is the model number? Second, in the front there should be a standby light. does it blink at all? It should blink in a repeating pattern. If so, please post that too.
Thanks,
Dan
Sep 23, 2008 | Televison & Video
Tv won't turn on
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
Jul 08, 2008 | Televison & Video
TV turns on & off
Hi there!
Exterior equipment attached to a standard tv cannot cause the set to switch on/off by itself.
I think you may have a power supply fault or else loose solder connections on the board, hence the "warming up" intro before the fault shows itself.
My suggestion would be a service technician if you are not familiar with electronics or TV's. Regards, JUS004
Mar 23, 2008 | RCA TruFlat 27F520T 27" TV
60in. rca rear projection tv
1) Reset will not help
2) Older RCA projection tv's usually produce a good pix,
so you could fix it....
3) light box chassis pulls out to go to shop for repair...
4) For more info = provide service # and chassis # off back..
Please rate this solution...............
Nov 13, 2007 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
