Question about GN Netcom GN 8110-USB (706487000020) Audio Input
Gn 8110 usb - GN Netcom GN 8110-USB (706487000020) Audio Input
3 Suggested Answers
portland1970
  • 145 Answers
SOURCE: I have Vista as OS,
so far i have not found a single driver or program package for this device. the reason for this is the device was specifically designed for windows xp and running it in compatibility mode might fix it temporarily, but might cause issues elsewhere. if you choose to do so, you can :
  • Assuming you have the Installation program on the desktop(if it is on the CD then you will need to copy the contents of the CD to a folder on the desktop. create a new folder and drag and drop the files ito it.), right click on the program setup and select properties. in the properties tab there is a compatibility tab.
  • On the compatibility tab select the check-box for run this program in compatibility mode for Windows XP (Service Pack 3). then make sure the check boxes for disable windows themes and run this program as an administrator are checked.
  • click apply and then click ok. run the program now
this should work, but if not.........
the alternative is to buy the updated version. i have found several on the internet for really inexpensive prices to include this one: http://cgi.ebay.com/JABRA-GN-NETCOM-6299-829-105-BIZ-620-DUO-USB-HEADSET-/180542469641?pt=LH_DefaultDomain_0&hash=item2a092b7609#ht_1531wt_905
this is the update for your model. i would suggest this one because windows vista/windows 7 supports it.
If you have any problems let me know and please leave positive feedback for me.
Jethro
Posted on Feb 01, 2011
SOURCE: Hi i am using windows 7 and GN Netcom GN 8110-USB
According to a Jabra Rep, there is a hardware update available that needs to be run on an XP machine, prior to installing the headset on Windows 7.
You can get the link by calling the Jabra Technical Support Team at (866) 697-8757.
Posted on Mar 13, 2012
In my computer gn com is not working
Is the headset showing as your default for sound?
Jan 16, 2013 | GN Netcom GN 2000 STEREO USB HEADSET...
How to make a GN 9350 unit work with Windows 7?
Skip dealing with it. You don't need the $110 BS "upgrade" as this is a driver issue. Jabra could very well have provided a downloadable and install-able driver for the GN 9350 that would work perfectly, and tell windows not to use the unsigned USB driver in the headset firmware.
Fortunately there is a quick-fix workaround... it is only a little bit of a pain (and proof that their $110 firmware upgrade is not necessary).
When you want to use the jabra with Win7:
1. Plug it into your computer via USB.
2. Go to your playback devices menu (right-click the speaker icon in the system-tray)
3. Set the GN 9350 as the default device for recording and playback.
(right-click, and test, should error (couln't play test tone)
4. unplug the power to the reciever/base.
5. wait 10 seconds.
6. plug it back in.
7. may need to set it as the default again, but you should be good for a while, just don't switch back and forth too much between computer and phone.
Oct 03, 2011 | GN Netcom GN 9350 Wireless Headset
Hi i am using windows 7 and GN Netcom GN 8110-USB drivers are not getting installed
Mar 23, 2011 | GN Netcom GN 8110-USB (706487000020) Audio...
I updated to windows 7 and now i need a driver for my headset
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
don
Feb 21, 2011 | GN Netcom GN 8110-USB (706487000020) Audio...
I have Vista as OS, when I plug in the GN 8110 USB. There is an installation process started, but in the set-up there is no audio device to be seen.
Jethro
Feb 01, 2011 | GN Netcom GN 8110-USB (706487000020) Audio...
Hi I need the device driver for GN8110 USB digital audio adapter
I think you can use this: http://www.nec.com.au/sp30/driver.htm
In case it does not work, try a driver finder program:
http://www.driverfinderpro.com/
Feb 21, 2010 | GN Netcom GN 8110-USB (706487000020) Audio...
Accessing barcode AS-8110 CCD Barcode Scanner
if you have the Keyboard Wedge - no drivers needed
, USB and RS-232 drivers are needed for windows and your software must support this type.
here is a site I googled with drivers
http://www.usb-port.com/downloads.html
Jan 30, 2008 | Office Equipment & Supplies
GN Netcom GN 8110-USB (706487000020) Audio Input Logo
41 people viewed this question
Top GN Netcom Televison & Video Experts
Electro Med Services...
Are you a GN Netcom Televison and Video Expert? Answer questions, earn points and help others
