Question about Emerson Televison & Video
How do we get channels set up on our TV - Emerson Televison & Video
    Top Expert:
  • Emerson Master
  • 14,553 Answers
It depends on what you are using for signal and how it is connected to this set (no model listed here).
Posted on Nov 03, 2012
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
I lost the remote to my Toshiba cz27t31. I bought an RCA universal remote. The RCA manual says the tv should be set to channel 1. But I can't change the channel without the remote. So I am SOL! How...
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Toshiba CZ27T31 27" TV
Just bought an RCL3210 TV. The odd thing is that the Channel up/down key on the remote control does not change the channel. Also, the up/down channel key on the TV itself also does not respond. When you...
You need to find how to CLEAR the auto channel settings. Sounds like the TV is set to SKIP all channels. Look for a MENU and then look for an AUTO setting that will walk through all channels and set those where you have reception as the "list" that the remote and the Up/Down buttons on the tv will choose.
PS: GREAT writeup on your problem and the things you have tried.
May 08, 2017 | RCA Televison & Video
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
Could you tell me why the tv insignia channels swich fron 2 to 3 channel, and the tv value is going up and down by itself? Because I"m not able to watch my programs. Can You help with this?
if you have set top box ,go to main menu ,check on restore factory settings ,put in default password 0000 and press ok,restarting the set top box automatically,waiting for some minutes.
restarting starts scanning all channels one by one and put them on their respective location in channel store.
now ,enjoy with all channels.
same process is done with tv if u have't any set top box ,only RF input from ur cable operator.
Nov 29, 2009 | Insignia IS 20" TV040919 TV
TRutech 15" LCD does not pick up all channels
Check your TV settings and make sure your tuning is set for cable (may say "cable" or "CATV"). Right now you'll probably find it set for "air". If the TV is set to tune off-the-air, cable channels 2 through 13 work normally, but above that they aren't detected. Once you set the tuning mode to cable, rescan channels and you should have them all.
Apr 01, 2009 | TruTech PLV1615T 15 in. LCD Television
Get channel 3 on tv with autoprogramming
When you select channels, the one that comes in the channel number will be green and if you manually select 03 it will probably be red. Hit menu and add channel 03
Jan 16, 2009 | GE 32GT740 32" TV
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
Channel set
Apparently your TV is set to the "standard TV" position. Before you auto program your set, set it to the cable mode and then do the autoprogramming. In the standard TV setting, you just get off the air channels 2-13 vhf and 14-83 uhf.where as in the cable mode you get vhf channels 2-13 plus your cable channels. Stargazer
Mar 17, 2007 | Daewoo DTQ-13P2FC 13" TV
Televison & Video Logo
21 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
