Question about Toshiba TZ50V51 50" Rear Projection Television
No information is displayed
Can watch tv but no display for channel or menu appears
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Based on the model number about the only easy thing to try is unplug the set from power for a while and plug back to see if a reboot will happen.
Posted on Nov 03, 2012
  • 3 more comments
  • mike polaniec Nov 03, 2012
    The tv has been in storage for a month and I'm not sure if it was happening before that. Thank you
  • SD Tech
    SD Tech Nov 03, 2012
    Nothing easy on this model will cause loss of OSD (on screen display) but if set got moved a lot I would at least peek inside looking for a cable or plug that came loose or off--would be on main chassis on one of the boards.
  • mike polaniec Nov 07, 2012
    All the connectors look tight and there is only one 6 pin connector that has nothing attached. II don't see any connector that should hook up to it. all the wires inside are connected
    Could it be a fuse or fusabnle link? Could the one of the boards be toast? Is there any way to adjust the convergence with out seeing the actual menu 'cause it looks like an old school 3d picture with the red and blue shadows?
    Got into the convergence menu but can't adjust colors left and right only up and down.
How to unlock a jcv s1465 screen
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Feb 26, 2013 | Insignia Televison & Video
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Lost pass code for v-chip
If you wish to know more, check this link.
Jan 17, 2013 | JVC AV-32F485 32" TV
Password for jvc tv v-chip
Jan 17, 2013 | Televison & Video
How to turn off clock on jvc tv
Sep 06, 2012 | JVC Televison & Video
Sep 06, 2012 | JVC AV-32260 32" TV
Remove the prerental block on a jvc tv
Apr 03, 2012 | JVC Televison & Video
There. Is a channel lock on my tv. So I can't change the channels. How do I take it off?? Help!
Hello
you have to unlock your jvc set, and reset the V-Chip settings. There are two ways to unlock JVC TVs, you have to find out which proceedings frome below mentioned will work with your TV.
[1]
[2]
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
May 10, 2011 | JVC AV-27020 TV
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
Cant change ''favourite'' channels or get ''menu''
Make sure the batteries are fresh in the remote control ( I am assuming you are using a remote control to access the on screen display) If you have a universal remote and replaced the batteries you most likely will have to enter the code for the specific TV that you have.
Jun 14, 2009 | Televison & Video
Toshiba TZ50V51 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
