Why my portable dvd playing won't play when i put a dvd dics in?
DVD won't play. I connected the power cord to the outlet and still won't play.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If it takes and accepts the disc but will not play it is either a mechanical issue (table not spinning the disc) or if not reading disc it is likely a dirty or bad optical pickup in the unit---
Posted on Nov 03, 2012
SOURCE: solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
Posted on May 19, 2009
silly girl
  • 513 Answers
SOURCE: reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
Posted on Jan 30, 2006
SOURCE: DVD player reloads after 5 minutes into the movie
I have a K715 that was having the same problem. The "line select" had been switched from "in" instead of "out". Once I switched it back to "out", the player worked normal.
Posted on May 12, 2008
  • 111 Answers
SOURCE: Dvd wont play
Maybe the laser is broken. You should send it back for repair.
is it an original dvd?
Posted on Apr 22, 2010
tvtek
  • 1284 Answers
SOURCE: No matter what DVD I load in the player, it
The first thing to try is to clean the laser itself by using a cleaning disc. If that fails then most likely the pickup laser is no longer any good. This is usually obvious if you place an audio CD in the unit and it plays fine : )
Posted on Jul 27, 2011
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
Dvd-l200
It depends how you burn movies (for example). If you burned as data disc, it's probably won't play it. Make sure you burn movies as DVD format.
May 19, 2012 | Samsung portable dvd player DVD-L200 User...
After one DVD movie was run several dozen times, the player would no longer
If you are talking about it won't play, the laser pickup is the issue, have you tried other dics? if no change! buy a DVD cleaning kit and follow instructions, this will clean the laser lens and perhaps get it running.
Mar 17, 2012 | Philips DVP3560 DVD Player
Sony portable DVD player dvp-fx970 won't play dvd
Use lens cleaner TDK or wash dvd disks with hot tap water then block off the water drops.
Feb 08, 2012 | Sony Televison & Video
I have a durabrand portable dvd player and I can not get the battery to recharge. I have unplugged it from the DC in jack and the cord from the wall. Reinserted the battery, then inserted the AC adaptor...
If your portable DVD player work with the AC power adapter in the wall outlet.100% the litium battery doesn't take any more holding charges.The litium battery should last u about 2 years with minium usages 2-3 hours a day.But that the DVD player and the litium battery must keep in very well conditon and wheather wise.Not in the heat or cold and the humitnity well shorten the lituim battey life very quickly and also could damages the portable DVD player too dosen't matter how much u used it.Tries webites like Amazon.com,Partstore.com,Ebay.com to buy a new litium battery or a compatible one.
Aug 25, 2011 | Durabrand PDV-709
Says no disc when i put in a dvd. dvd is new and clean, still won't work.
Hello
Put a video CD and see whether it reads and plays. If it also does not plays, or if video CD only plays and not DVD; in both cases; the Laser Pickup Unit is faulty and should be replaced with same type and number. OK.
Jun 10, 2011 | Coby TF-DVD7107 Portable DVD Player
My DRC6309 RCA portable DVD player will not play disc. It says "loading" and then says "no disc". I have tried different outlets and different discs. Any suggestions? Is there a...
Hello
Either your DVD players Laser Pickup Unit is dirty or defective or its 'sled' motor has damaged. Sled motor is one, which spins the disc inside. if it does not spins, the main system IC won't get any signal that the disc is "IN", and will show the messege "No Disc". The same will happen if the laser pickup unit is defective or dirty. Insert a Head Cleaning Disc into the system, and play it for atleast 3 times. If there is any dirt or dust, this will solve your DVD's problem. If not, it should be serviced by any skilled technician. It is not a user reparable item, as you have to take out its loading mechanism completly out of it for repair. OK.
Jun 02, 2011 | RCA DRC6309 9 in. Portable DVD Player with...
When we put a disc in to play it, the player just continues loading and never actually plays the disc. what could be the problem? It is plugged into a wall outlet when we are trying & we have tried...
Check DVD discs for cracks,big scratches,dirts and grims?All DVD dics are original discs like comercial movies or materials discs?Most DVD players have problems,reading and playing copy discs,because of it finaling codes of the DVD copy recoders players used it to coping it.
Feb 25, 2011 | Sylvania SDVD8732 Player
Won't play DVD's but will play CDs
I suggests to try another dvd dics maybe it is not compatible to your player. try universal dvd dics...
Apr 16, 2009 | Televison & Video
Portable dvd player will not play off outlet or car charger
There must be something wrong with the amount of power the power supply is providing. I would try and purchase another power supply, and see if it still happens. Another thing it could be is the port where you plug in the power cord, is the port loose or can you move it? If this is the case, it might not be receiving clean power.
Jan 23, 2009 | Protron PDV-288 7" LCD Portable DVD Player
Televison & Video Logo
234 people viewed this question
Top Televison & Video Experts
Electro Med Services...
