Liteon HDD/DVD LVW5055GDL I have a lite on LVW5055GDL hard disk video recorder that is about 2 years old. It does not recognise any DVD blank discs. When I try to copy anything from Hard drive, it instructs me to change the disk or it opens the tray without any instructions. I have cleaned the lens many a times with cleaner discs bought from Comet " 2-Way DVD Lens Cleaner". It still does not solve my problem. I was looking for a replacement drive but can not find equivelant product. Anyone else had this problem? Can anyone help me to locate the drive or tell me how to overcome this problem. B Visrolia
  • 3 more comments
  • balvant81 Jan 04, 2009
    It is not possible to use spray can.
    I do not want to buy a new unit. I want my current problem to solve.
    "Liteon HDD/DVD LVW5055GDL I have a lite on LVW5055GDL hard disk video recorder that is about 2 years old. It does not recognise any DVD blank discs. When I try to copy anything from Hard drive, it instructs me to change the disk or it opens the tray without any instructions. I have cleaned the lens many a times with cleaner discs bought from Comet " 2-Way DVD Lens Cleaner". It still does not solve my problem. I was looking for a replacement drive but can not find equivelant product. Anyone else had this problem? Can anyone help me to locate the drive or tell me how to overcome this problem. B Visrolia"
    I did try firmware. It did not solve this problem This weas suggested by Liton themselves. I ahve also try to use different makes of blank DVds but to no avail.
    thanks, I will try all that has been suggested.
    Thanks again
    Thanks,
    Thanks a million
    Genius:
  • 1,239 Answers
HI
I've found that once a disk is formatted in certain formats with a pc it prevents the HDD from reading it.  Format it again in the HDD (if you can!) or use the pc to format it using the UDF1.5 setting in a pc (which sort of resets it so the HDD can at least see it as an unused disc again).
All in all I have found my RH19991H really confusing as far as disk initialization and formatting and finalizing is concerned.  Sometimes you can select to finalize a +-rw dvd and sometimes not (the latter is the the case according to the manual) and sometimes I can select the format mode and sometimes not.  Sometimes the machine auto finalizes the dvd+-rw (the way it should be says the manual) and sometimes it does not and then I cannot use it in the pc.  I have also created some disks with DivX files and was able to play them in the HDD and then using the same pc, same type of discs, same video editing software and same settings created other DivX files I could not play on the HDD.  It seems the software on the machine needs some work...
Posted on Jan 04, 2009
  • 1,879 Answers
Hard to locate a replacement optical drive.
another way to get the data out of the HDD - connect the HDD to a computer (taking it out of the player and use a HDD enclosure).
    Genius:
  • 3,422 Answers
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image i have attached.
  • 679 Answers
Did you try to go online and upgrade the firmware? sometimes these things are corrected as time goes on they write new firmware for their equiptment. Go to their website and see if there is an updated firmware. If so install it. Other than that from personal experience, some dvd players simply dont like certain media, some like maxell and won't plat TDK or Sony. It is not unusual to see that happen, my sony dvdrw won't burn and cdrw's its more the norm than the exception, and I get better results wit -R than +R, so if you are able to pick up several types and brands, that may be the answer, it isn't a great answer but like i mentioned it's not unusual. First try the firmware upgrade look here,http://www.us.liteon.com/, good luck, and thanks for using FixYa
    President:
  • 2,110 Answers
    Sergeant:
  • 366 Answers
With compressed air can try removing dust from inside the tray.
  • 19,396 Answers
If it t does not recognise any DVD blank discs, then it is the lens, at list it is lens 9 to 1.
To fix the problem , the unit must be tken apart, and the lens cleaned using q tips and isopropyl alcohol.
If that does not work replace the lens pickup.
  • Ginko
    Ginko Jan 04, 2009
    Also ensure that you tried different brands blank DVDs, and that you tried both +R and -R DVDs, even if many models are supposed to read both formats, you often get problems in recording either + or - R DVDs.
    The Drive is the DVD reader unit, and can be replaced (this is more expensive, but fix the problem). This is one of the most common problems on this unit, and is usually related to lens.
    If the unit recognise that there is no disk, it is always the lens, as belt is in place, motor working, unit is operating, and a logical fault of this kind is rather unlikely.
    When a cleaner DVD is not enough, the lens must be accessed direcly and cleaned.
    The repair must be done by a qualified technician.
LITE ON HD-A740GX ONLY HAVE DIGITAL SIGNAL HOW DO I TUNE IN CAN I TUNE IN
You must connect a digital TV box between your arial and your Liteon, so the arial cable goes into the digital box, and use a SCART cable from the digital box to the Liteon. Then record using the SCART input on the Liteon. Another SCART cable can be connected from the Liteon to your TV, so you can view what you have recorded.
Apr 30, 2012 | Lite On HD-A760GX DVD Recorder / HDD...
Liteon dvd recorder won't play or record from disk or cable tv
You should be able to connect with the AV input, Y, Video R, W. Audio, they go to same color on DVD & TV.
Feb 18, 2010 | Lite On LVW-5005 DVD Recorder
Where can I get repaired in India LiteOn DVD Recorder ?
There is no ,LiteOn authorised repair centre in India. You can get in touch with a local repair technician for the same . Alternatively you send Liteon support people an email. Incase they have a tieup with an indian service & repair company.They would let you know.Find the link below
http://www.liteonit.com/global/index.php?option=com_wrapper&Itemid=70
Thanks for using fixya
Proton
Sep 05, 2009 | Electronics - Others
Liteon HDD/DVD recorder/player
lite-on dvdrw in model HD-A760GX will not recognise dvd disc. KEEPS STATING TO INSERT BLANK
Jan 26, 2009 | Lite On SOHD - 16P9S Internal DVD Drive
Liteon 5045 problem in playing normal movie DVD's
The DVD drives are very unreliable and just get more temperamental with age. I replaced mine with a Lite-On SOHW-1213S. The DVD is too big to fit in the old ones place so it sits on top of the unit with the cable going through the slot, but it works brilliantly.
Nov 04, 2008 | Lite On LVW-5045 DVD Recorder
Not recognized
Go into your BIOS and see if you can get it to autodetect the drive. You should be able to this but I can't tell you how to because all BIOS setups are different.
Then save your BIOS and reboot.
The drive should then be recognised as the right thing.
Hope this helps
Mowcius
May 16, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Will not record onto blank DVD's from HDD on LVW-5045 HDD-DVD 160 gb
Hi Barry - I too have a Lite-on and was initially over the moon with it. For the last year or so I have been unable to "read" disks and was just using it for the hard drive for recording - but this weekend my father in law had the exact same problem occur to his Lite-on and he bought a dvd cleaner (£5) - used it and it solved it - So I tried it and presto mine is reading and writing fine again - I was so chuffed - need to share this simple info just in case its a simple "dust" problem for anyone else that is having reading problems. DVD cleaner not just a CD cleaner as DVD cleaners have two brushes on it.
Jan 02, 2008 | Lite On LVW-5045 DVD Recorder
Can this copy DVDs to blank DVD?
Copy content from your DVD to the HDD (hard drive) - then copy content from HDD back to a blank disk. Will not copy protected DVD's. You can also download another intruction booklet for it from the Lite0n website.
Dec 31, 2007 | Lite On LVW-5045 DVD Recorder
Can't read blank DVD for recording / can't transfer film from HD to dvd
I presume at this stage you have tried a different type of dvd disc and not just the one type and you are using the correct format dvdr for your machine.If you have tried all this it could be the laser,but make sure you try everthing else before replacing optic assy.
May 12, 2007 | Lite On LVW-5045 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
