Question about Canon PC-980 Color Copier
Black streak down side of paper mod.pc-980 - Canon PC-980 Color Copier
3 Suggested Answers
wheatlandsvc
  • 1110 Answers
SOURCE: I have a PC 25 copier. I am getting black streaks
Run a copy and shut the machine off when the copy is half way through. Open the machine up and remove the toner cartridge. Turn it over and slide open the flap that covers the drum. If you see toner streaks on the drum surface similar to what you see on the page you have a defective toner cartridge. Most likely the toner you bought is remanufactured as this machine is very old. Maybe you can return it for another.
Posted on Oct 18, 2009
Testimonial: "Thanks. Fortunately I kept the receipt for the cartridge - just bought it in August."
  • 51 Answers
SOURCE: I have a Canon iR1024A that is leaving black
If you have changed the drum then probably your fixing film was torn. Check if the black streaks on paper is erasable (not fixed on the paper). Check also for signs of film (gray on one side and brown on the other very thin plastic-like material) falling out from your fixing assembly (if you open the left side cover with caution sign the hot portion area).
Posted on Oct 05, 2010
Black streaks
Black streaks down left side of paper. Solution: Replace drum.
Oct 27, 2013 | Xerox Office Equipment & Supplies
We have a Brother intellifax 4750e. When we send a fax, there is a black streak down the right hand side of the paper. When we receive a fax, the streak is not there. The streak is about 1" wide. ...
Try cleaning the rollers with rubbing alcohol using a good quality paper towels, I find there is a buildup on the rollers causing streaking on the paper. If that fails the print head must be suspect.
Dec 30, 2010 | Brother Office Equipment & Supplies
Black ink streak on left side of paper on hp 1012, just put in new toner
Run a half test.
Put paper in the manual feed tray(tray 1).
Send a print job to printer. When the paper gets 3/4 of the way into the printer, open the cover. Pull out the toner cartridge, look down at the sheet inside the printer. Does it have the streak on the left side? If yes...your toner cartridge is bad. If no...replace the fuser.
Oct 21, 2010 | HP LaserJet 1012 Printer
I have a Canon iR1024A that is leaving black streaks down side of paper... I have changed the toner.. cleaned out where the toner goes... and changed the drum... nothing changed.. can you help me
Sep 22, 2010 | Canon ImageRUNNER 1670F Copier
Black streak down right side of outgoing received fax
clean the scanner, it may have white out or some other obstruction blocking it
Jun 02, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Black streaking down one side
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 10, 2010 | Brother IntelliFax-4100e Fax
I'm getting black streaks down the left side of the paper. There is plenty of toner left in the cartridge. We've vacuumed out the printer, cleaned the drum - nothing helps.
black streaks the toner cartridge is leaking from the left side which is easy to check pull the tone and look at the gears on the left side to see if toner is present. if these gears have toner on them the cartridge is leaking replace it. check the fuser for wear marks on the hot roller which is the top roller when these get worn through the outer coating they will create black streaks
Dec 05, 2009 | Lexmark E238 Laser Printer
Clp-500. toner streaking the paper.
I have the same streaks problem. Any solutions?
Nov 14, 2009 | Samsung CLP-500 Laser Printer
Printer prints a black streak down the reverse side
You have a build up of ink inside the printer. I had a Canon that did this. I had to take the ink & print head out, and tear a paper towel strip 1 " wide and 13" long or however long the paper towel is. I folded it in half down the length so it was 1/2x13. Then used a plastic strip to shove it under the part the print head sits in. Once I got the towel to the other side, I grabbed it with my hand. I removed the plastic strip used to shove the paper towel under. So now the paper towel sticks out both sides underneath the print head cradle. I gently pull the paper towel back and forth so the paper towel can clean off the ink build up. Hope this helps.
Mar 29, 2009 | Office Equipment & Supplies
The fax streaks
Open the lower part of the number panel by pulling up 1 inch. and clean the small scanner glass.....hard to see.
Mar 02, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Canon PC-980 Color Copier Logo
43 people viewed this question
old marine
old marine
