Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
Dell 1703ft (17" UltraSharp LCD) powers on, but no picture
I have a Dell 1703ft 17" UltraSharp LCD with an *intermittant* problem. The monitor appears to be getting power, and the light on the power button correctly displays orange or green when it should. However, when it's turned on (to a computer with a video signal), or when it's woken from sleep (as in turning on the computer), the screen displays neither the video it should, nor any test pattern. Changing inputs also doesn't produce any text on the screen, or any test pattern. Rather, the screen flashes once very briefly, then goes completely black as if it's not on at all. I can't get any OSD to appear, or any other messages. This LCD has been plugged into several different computers, and repeated the same problem. It always flashes once, and then nothing. The same computers have been tested with other monitors, and work fine. The VGA and power cables have been swapped for different cables, and the same result occurs. The problem is most definitely in the LCD itself... I'm comfortable with all areas of repairing computers and other electronics, (including using DMMs and soldering), but I can't find a repair manual for this LCD, or any other troubleshooting guide that goes past determining whether the problem is in the monitor or elsewhere. The problem is in the monitor. Where do I go from here? Is this a common problem for which I can check just a couple of internal components, like a fuse or a capacitor? Also, I suspect that the problem shows up when the monitor goes into a sleep mode. It'll work for days on end without fail, then I'll come home one night and it's asleep and has this problem. Leaving it disconnected from everything for a while has allowed it to work again when reconnected, but I have no idea how long it has to be disconnected, or if I might just need to ground it or discharge something. Any suggestions would be greatly appreciated. Thanks in advance! :)
Hi
I have dell E172FPb model LCD monitor , the first problem was it blink yellow led and the screen was blank . I open the monitor and i got the two transistors c5707 was shorted , then after i changed the failed component it worked good for a month and so , but after one month the same components have failed again , I tried to find the other components that might cause the failure of the transistors on the inverter board but i didn't get any, then I changed the failed transistors .now the new problem is the power button is blinks green but no image on the screen
is there any help
Abebe
Posted on Feb 15, 2008
  • Dell Master
  • 12,061 Answers
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps. Try this and see if it helps. All too often it is these Electro's.. GL.
Posted on Jul 24, 2007
Disassembily of a dell, ultrasharp monitor
See pictures here:
http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%201704FPT/
Be REAL CAREFULL on the ribbon cable attached to the front bezel and a loose spring on the push button for releasing the stand from the monitor.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 21, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell LCD power up issue
I suggets you try your Monitor with another pc and see if its behaving the same if the same then the monitor is bad
Now if there is change ie its showing on the other PC then your pc VGA card is faulty or is not seated correctly on its slot pls check this,
Also swap VGA cards this how you will know its status .
Last get another VGA card
Good luck
Nov 13, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
I have a Dell 17" flat screen ultrasharp monitor. It suddenly went dark and will not power up. Can it be repaired?
With the dropping price of monitors today; can get a good 22 inch lcd for less than $200 in most stores, it would probably cost more to have the old monitor repaired than just replace with a new monitor. Hope this helps.
Jul 17, 2009 | Dell E173FP 17" LCD Monitor
Black screen on monitor when plugged in., no picture at all
When you plug in the monitor no lights come on at all green, orange nothing ?
Try
1. Using a new power cord ( maybe something is wrong with it)
2. Plugging it into a new socket on the wall.
If you can't get power to the monitor at all you may be in for buying a new one.
Jan 04, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1702FP 17" shows nothing after Radeon HD 2600 put in.
Is the card plugged into the (PCI/AGP) slot correctly? Did you disable the onboard video in the bios? Also be sure to check in windows device manager and check for the graphics card to appear there.
Dec 24, 2008 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell UltraSharp 1704FPT 17 in
Remove the stand, look along the bottom edge - you will see two small slots, one either side. Poke something in the slots and wiggle slighly, the corner will come apart - then just pull until all the clips undo.
Sep 07, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1704FPT Display Problem
It is your inverter/power supply board. Costs around $62.00 with shipping. Not a hard replacement if you have electronic maintenance experience.
Jan 22, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
555 people viewed this question
Alun Cox
