Question about Spark Plugs BR4HS Plug 10/BX #3322
1999 grand am distribitor rotor - Spark Plugs BR4HS Plug 10/BX #3322
    Problem Solver:
  • 30 Answers
There is no distributor on the grand am it has a coil pack
Posted on Apr 14, 2014
New coil ,new distribitor, not just cap and rotor the full distribitor. no spark at plug,wont start
Have tou checked your fuse box? Crank position sensor check engine light, suggest you imclude car and model.
Nov 03, 2015 | Cars & Trucks
How to fix distribitor timing problems
Remove number, one spark plug , turn engine over till compression is felt, turn engine over till TDC marks on crank pulley and timing cover marks line up, fit distributor to motor with rotor pointing to number one distributor cap tower, start and set final timing with timing light.
Sep 21, 2015 | 1999 GMC Jimmy
Having trouble setting the timing on a 2000 jeep 4.0 with out a dis or rotor
it sets like a distribitor tdc engine the sensor has marks to allign it with
Oct 25, 2013 | 2000 Jeep Grand Cherokee
How do put my 1991 Chevy C1500 truck with 4.3 back n time on motor and distribitor
PULL THE SPARKPLUG OUT OF THE #1 CYLINDER ROTATE ENGINE OVER TO FIND TOP DEAD CENTER ON COMPRESSION STROKE REMOVE DIST. CAP AND SEE WHERE THE ROTOR IS POINTING AND ADJUST SO THE
#1 WIRE IS LINED UP WITH IT
Nov 20, 2012 | Cars & Trucks
1999 surburban won't start getting gas and fire. put new coil and check fuel pressure from fuel pump. what can it be,
my 1999 chevy suburban will start with starter fluid bbut wont stay running already replaced coil,rotor on distribitor,and oil pump cant seem to figure it out any ideas
Jan 17, 2011 | 1999 GMC Suburban
4.0 engine swap limititations
Hi, The earlier engines had a distribitor for the spark plugs, but later engines for the 1999-2004 cars, have a coil on top of each spark plug controlled by th PCM (or ECU). It may be possible to modify an older engine by using all the ignition gear from your later unit, but I haven't tried. Maybe ask at a Jeep used parts supplier, who may have done a similar job.
May 19, 2009 | 1999 Jeep Grand Cherokee
Distribitor timing
the timing was disturbed while reinstalling dist. or it is not installed in the right position normally you would make a mark that will line up when reinstalling also make sure you don't disturb the position of the place where it goes.
Apr 11, 2009 | 2001 Jeep Grand Cherokee
Grand am Gt 1999( Disc's )
did you mean brake rotors?
if yes you have to remove your calipers and pads the remove caliper holder brakets then you can remove the rotors out..
Feb 28, 2009 | 1999 Pontiac Grand Am GT
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
15 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
steve morris
steve morris
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
