Question about Cooktops
Bosch 500 Glass Cooktop discoloration
I just bought this and used it twice but there are spots where I set the pan on it that look like discoloration. I have flat bottom SS caphelon pans. What is damaging it? can i buy a replacement top? what pans should I use?
    Scholar:
  • 145 Answers
DeBruce Polish will remove the discoloringin the cook top, also use it on pans to remove any deposits that may transfer to cook top. debrucepolish.com
Posted on Feb 24, 2009
Kenmore glass cooktop discoloured
I use a straight edged razor blade on mine and it finally got clean
Nov 15, 2012 | Kenmore Frigidaire Glass Cook Top...
Purchased the cooktop from Sears over a year ago. Something fell on the edge of the cooktop and it broke. The burners all work but looks ugly.would like to fix or replace it. What are my options? Shoul I g...
Is what broken and lools ugly the glass for the cooktop? if that is the case you should know the cost just for the glass is $470.00 plus the service call and labor it's going to be at least $600 to replace the glass
Gene
Aug 05, 2011 | Bosch NET8654UC 37 in Electric Cooktop
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
I was cooking popcorn on my glass cooktop and the pan appears to have scratched to surface.
You may have melted the bottom of the pan you were using into the glass. Copper bottom and alum pans sholdnot be used at high temps on a glass top. (never use porclin or glass pots)High temps can etch(mark or discolor) the glass.
Oct 30, 2009 | KitchenAid 30 in. KECC506R Electric...
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
The stainless steel rings on my cooktop are already getting burn stains. How do I clean them without discoloring the rings?
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jun 17, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Stain on burners
Use DeBruce Polish on ceramic cook tops, go to debrucepolish.com
Feb 06, 2009 | Jenn-Air JED8430 Electric Cooktop
Discoloration of cooking surface (darkened) on Bosch stove
I'm Bruce of DeBruce Polish, our new polish is non-toxic and odorless and non abrasive, should take care of your problem. We designed it for stainless steel, and have faboulous results on ceramic stove tops, and chrome and many other uses. Even removes permanent magic marker. web site will be up soon debrucepolish.com. Phone 612-220-2236.
Jan 02, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Broken glass for 5 burners electric Bosch cooktop
If you can give me the model number I can give you 3 places and there prices. The model number should be located on the bottom of the unit.
Dec 03, 2008 | Bosch 36 in. NIT8653UC Electric Cooktop
Glass cooktop keeps cracking in same area
The cooktop box has a metal flange. Make sure the cooktop when dropped into the countertop is resting on ther metal flange and not the glass edge by itself. If it rests on the glass alone the weight will cause the glass to crack at some point in time.
Dec 20, 2007 | Cooktops
Cooktops Logo
693 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
