Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Dark Wavy Linew on Panny 47
Thanks for your response.
We are on the same page I think.
I am going to replace all the caps in the RC circuit around the convergence IC's.
I bought a "manual" on line, I GOT RIPPED OFF.
My manual has a shematic that is impossible to read
and the part #'s don't match the schematic.
Parts list has 3 digit ref #, the drawings have 4 digit ref #'s.
I think I found C7036 but cannot find c7054 on the schematic's that I have, but my drawings could be BS.
If you would please send me the A-board schematics and the parts list I WOULD BE MOST GRATEFUL.
Thanks in advance
Lonny
l_miller111@comcast.net
  • 90 Answers
The capacitors you seek are sitting right beside each other and are the same value. They are surface mounted caps, but I usually just cut the legs down on some pc mount caps and solder them right on top. This way, I don't even have to pull the board out.
Posted on Jan 07, 2009
Screen goes dark when the picture has a lot of black or dark color in it
The electrolytic caps need change on the power supply module, or replace the power supply module.
Mar 24, 2011 | Vizio VO47L 47 in. LCD TV
Picutre looks dark
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Oct 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
The picture shows up as a 4 inch wavy line across the middle of the screen. what part needs replacing? It used to do this and then snap into a full picture but it doesn't anymore. Is this replaceable?
Replace capacitor [location 2455] it is a 25 volt 47 MF cap. Use a high temp cap at 105 degrees. And resolder Q7461 and Q 7463. Find someone who works electronics and they can repair using this info! You will have a TV as good as new....I promise!
Mar 06, 2010 | Philips 27PT543S 27" TV
PT-47WX49E just shut off
maybe the convergence resistors? sometimes when the ics blow a resistor or a few blow
Jan 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Wavy dark lines
Are the lines fine diagional across the screen and are they black in color.
Jan 01, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba 50H82 with wavy lines at the top when in HD mode
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
http://myworld.ebay.com/kcarrigan/
I have the same problem and will probably send mine after the holidays.
Dec 03, 2008 | Toshiba 50H82 50" Rear Projection...
PT47WX49E wavy lines
That unit has a history of bad caps throughout the convergence and other circuits. Personally I believe it was an error in the design.... Check and/or replace the following::: C2451, C3007, C7022, C4613, C2507, C7060 all 100uf/16v and C7127, C7128, C7103, C7154, C7136, C3010, C3008, C3002 all 47uf/16v... You can use a higher voltage rated caps such as 35v or 50v for greater reliability.
Bill
Nov 01, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Power board circuit for L20V34S
I WORK FOR A HOSPITAL HAS SOME 70 L20V34S. THEY HAVE STATRED ALL GO DOWN. CAN SOMEONE HELP ME WITH THE CAUSE OR PART NUMBER FOR POWER SUPPLY OR WHAT EVER THE PROBLEM. THANKS HCC
Oct 12, 2008 | Televison & Video
Hitachi 53sbx59b horizontal wave lines
I would check the main power supply for a bad filter cap. That could cause the wavy lines. The different colors are probably a problem with the convergence circuit. Try resoldering the convergence ICs first. If that does not resolve it replace the ICs. Also check for low valued resistors in that same circuit or pico fuses.
Dan
Sep 13, 2008 | Televison & Video
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
