Question about Motorola Mobility RAZR V3
Display like lightning and phone draining battery
Phone will only work when connected to charger. Something is draining battery and display looks like it is being shocked! Flickers like lightning
  • mcapanna Jan 05, 2009
    I wish it were that simple. You should see the displayl It flashes like firworks! Can't get an upgrade until July, so I am kinda stuck.
  • mcapanna Jan 07, 2009
    thanks. You are right about the razr v3.
    Problem Solver:
  • 5 Answers
You have the bluetooth connection on and it will drain your battery, go into settings an turn off the bluetooth page 25 of your manual
Posted on Jan 04, 2009
  • sandrakdmoon Jan 06, 2009
    Sorry I thought I'd give it a go & try to help. The Razr v3 isn't what it was made out to be thats for sure. Wish I could have helped.
How do I change the display to make it brighter on my Uniden D1361 cordless phone?
There is a bulb behind the display it is for backlighting the lcd, likely it is burnt out or bad connection from the board
Dec 05, 2014 | Uniden Cordless Phone
Iphone won't charge if on
Hello My Dear::::::\
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 12, 2013 | Apple iPhone 3GS Black (16 GB)
Okay. When i plug in my charger to my phone, it will not charge for anything! It may be a possibility that i spilled some yogurt on it also /: but there is nothing wrong with the phone itself.. Like it...
Did spill the yogurt on the phone, or on the charger?
What happend when you plugged in the charger, specifically? Did your phone turn off, if not, were there any changes on the display, did the battery bars blink?
Also, if this is your AC charger for inside your home, do you have a car charger and have you tried it? If your car charger works, or if you are able to borrow someone's charger and IT works, then YOUR charger needs to be replaced. Best Buy, Wal Mart Electronic dept,or Staples, Office Depot, all these retail outlets sell replacement AC and DC ( 12v battery ) chargers. Cellphone chargers are notoriously easy to break, its not unusual to have to replace it during the life of any given phone.
You could try wiggling the connector, and watching the display to see if you have intermittent contact. Most of the ones I've had to replace were like that. They would only work if I pushed in the connector, or held it a certain way. If I just hooked it up and left it, it would not make a connection to the juice. Watch the display closely as your wiggling. You are looking to see if the display light up, or the battery bars to blink. If you can see it connect, even intermittently, you know your phone, and its ability to charge is okay,
Feb 01, 2011 | Cell Phones
Does not work, we tired a new battery, but no help.
Instructions
    Technical Difficulties
  1. If the phone doesn't turn on, make sure battery is charged and fully plugged into phone. Remove battery from phone and use rag to brush away dirt that may interfere with connection. Reconnect and try again. If using cigarette-lighter adapter, make sure it's properly plugged in. Make sure charger is properly plugged into outlet and into battery.
  2. When the battery doesn't charge, plug lamp or other electrical device into outlet to verify that outlet works. Borrow friend's charger to see if charger or battery is problem. Replace charger or battery if necessary.
  3. In case the phone gets wet, remove the battery from the phone and allow both to dry thoroughly. If rust or corrosion develops, wipe it off with a stiff brush. If phone still does not work, replace it.
  4. Should the display not be working, try getting it to room temperature, extremely cold or warm conditions may affect display functions.
  5. If the keys don't work, look for a display of a symbol that looks like a lock. The keypad may be locked. The display often tells you how to unlock it. If not, check owner's manual.
Jan 24, 2011 | Lands Phones
Phone was working fine, battery lasted a long time...
Maybe the port changer on your phone was crashed!
May 21, 2010 | Lands Phones
I accidentalluy put my cell phone into my dryer for 20 minutes with my (dry) coat. the battery detached itself from the phone in the dryer so that when i took it out i had to put the battery back on. a...
Intense heat will damage or destroy the Battery. Also, heat will damage or destroy the Liquid Crystal Display (LCD) by melting the crystal.
Try the phone with battery charger connected. With Charger connected and powering the phone, try to turn on. The Back light is usually driven by LED s which are robust and can sustain the Dryer heat.
If the phone back light comes on, the the phone electronics is probably OK and will still work as a phone.
The Battery can be replaced, but there is no easy way to replace a bad display.
So, Power with Charger, look for light, try dialing without display.
  • If above suggestions fails , then its better to approach an authorized service center
Hope this helps.
Mar 15, 2010 | AT&T Cell Phones
I accidentally put my cell phone in the dryer for 20 minutes with my coat (my coat was dry). the battery was wasn't connected when i retreived my phone but when i attached it the phone wasn't working. is...
  • If above suggestions fails then ,please approach an authorized dealer / service center .
Hope this helps.
Mar 15, 2010 | Lenmar Lithium-Ion Battery for Select LG...
Comp will not turn on also see lightning bolt display
Hi All,
This happens because of static energy storing in the motherboard components.
We can try power drain to resolve this issue.
Try doing power drain by taking out the battery & keep holding down the power button for complete one minute to drain out the power from the computer components. Restart the computer after putting the battery in.
Try restarting the computer only with the AC power, without the battery & vice-versa.
That should resolve the issue, if the issue persists, then you have to contact service center.
Hope that information helped you!!
Apr 16, 2008 | HP Compaq Presario C500t Notebook
SIM not recognized
I had the same problem with charging, I found that my car charger and via USB charged the phone but not my home charger. Give that a try, if it works with either one of them you will have to send it to Motoservice center and they will fix the internal connection problem. (save your money on buying new batteries and chargers) Make sure that the phone is not locked to a network, or make sure that the SIM has not expired and has plenty of credit.
Jun 13, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
46 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
