Hitachi Model HTA-3F AM FM stereo tuner amplifier
SOURCE: Hitachi FT-5500 Mark 11 AM/FM
Send me a copy of a manual and I tell which part to replace to fix this problem.
Regards
wojtektl@yahoo.com
Posted on Mar 19, 2009
dunnbiker
  • 8546 Answers
SOURCE: Kenwood Stereo
I presume you realize none of these things produces speaker amplification. A receiver would do that and facilitate graceful and simultaneous interconnections. But it's not a necessity for selective interconnective between them, just not all at the same time.
I can't find any details on anything you named except the Tuner.
Typically, the tuner would use an RCA pair to go to a receiver AUX, TUNER or other Line Level input for source selection and amplification. Lacking a receiver, run it to the Tape Deck inputs for recording.
Ditto for the CD changer, but you'll probably have to disconnect the tuner.
Posted on Jan 27, 2010
SOURCE: Hello, I have found a Sansui
Hi!
I have the same deck. Did it come with rammophone or are you using your own grammophone?
I have it with original grammophone and I don't need a remote control, I don't even have it. You just turn on your grammophone and it is automatic, just place the needle on record and it should switch and play automatically. That is if you have connected the wires right (two wires for sound, one for automation, all in the same area).
If you have separate grammophone, I am assuming you just need to place two wires into the separate phono channels and it should work. There is just no automatic detection, so you have to swithc to mono manually: There is a button on the right, beside Volume control "tape to CD" or something.
To play the tape, just simply push the play button on the bottom, should work, or you could try tape to cd button off and see if it detects automatically when tape is inserted.
Currently I have it taken apart and there is tape detection system apparent. Its quite automated reciever, which sucks, because all kinds of problems appear and it is difficult to fix.
On my Sansui, the tape player starts winding slowly when pressed play button. And the tape motor seems to be on always, even when the tape is not used, and the motor is really loud. --Need to find a solution to this problem. And I hate it switch to radio/FM every time the record stops. Plus the original grammophone doesn't work correctly, it is supposed to take off the needle when record reaches an end, but it just pushes the neelde to the holder... over the record..... "screeeeech".
Posted on Dec 08, 2010
dunnbiker
  • 8546 Answers
SOURCE: i need manuals for hooking
I can't even find a reliable picture of the amp but it's not rocket science.
The Tuner output goes to, say, FM or Aux on the am, anything BUT Phono, which is ONLY for a turntable.
The EQ output goes to the first available Tape In; Input Comes from the same Tape Out. Select that tape function to engage it in line with any source and the downstream electronics (second tape, tone, volume, speakers).
The tape deck output goes to Tape In; Input comes from Tape Out. If there is not a second tape loop on the amp, nest the Tape Deck into the EQ's Tape loop. They always have at least one to replace the one they use. Select THAT tape function to engage it in line with any source and the downstream electronics.
Posted on Mar 13, 2011
  • 5468 Answers
SOURCE: I don't have the manual
The manual for the Fisher amp is available for sale here: http://www.pacparts.com/model.cfm?mfg=fisher&model_id=CA9435&action=list_part&CFID=5770938&CFTOKEN=29240565&back=0&mode=auto . Scroll down to the Owner's Manual for $15 and the inst. manual for $10.55. It's near the bottom of the site. Both will take an estimated 2-3 days to prepare and ship.
For the tape deck, see: http://www.pacparts.com/model.cfm?mfg=fisher&model_id=CRW9435&action=list_part&mode=auto&back=0 . Again scroll down; it's $15.
I can't find any sites that have the manual for the tuner FM-9435. PacParts does list some parts for the unit: http://www.pacparts.com/model.cfm?model_id=FM9435&mfg=FISHER&back=0&action=list_part&CFID=7029891&CFTOKEN=fbf7dc69955d9dc0-DE1BB9D8-D8E3-74C7-55438E00EAE8FEEB .
None of the manuals are available online as pdfs.
I hope this helps.
Posted on Jun 30, 2011
I own a hitachi av surround reciever model No. HTA-DD3W. It has recently developed a problem in that it does not play in any other mode than stereo, ie no surround sound, multi stereo etc. please help
Hi amstok
Sounds like it may have a DSP failure. Straight stereo signals bypass the DSP stages. Could be an expensive fix. I suggest you take it to a Hitachi agent for a quote. Not something that can be easily fixed on the kitchen table I am afraid.
regards
Graeme
Mar 08, 2008 | Audio Players & Recorders
Where to attach external antenna on model hta-25f
For the Hitachi HTA-25F, the balanced wire antenna connections are the row of terminal screws on the bottom - inside the blue highlighted box. If using a 75 Ohm coax (unbalanced) wire connection - use the connector in the top right corner of the blue highlighted box instead.
Jul 27, 2015 | Audio Players & Recorders
Amplifier - TA-AX380; CD Player - CDP-C40; AM/FM Tuner - ST-JX380; FM Stereo/FM-AM Receiver - STR-AV570X, and Stereo Cassette Deck - TC-W380.....all Sony. Very old system, do not have the manuals, they...
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 22, 2011 | Audio Players & Recorders
I have a Sony Amplifier [model TA-AX380] and other components of CD player [model DCP-C40], AM/FM Tuner [model ST-JX380], FM Stereo/FM-AM Receiver [model STR-AV570X], and Stereo Cassette Deck [model...
http://www.servicemanuals.net/ServiceManual/SONY/TAAX380/148547/detail.aspx
http://www.hifiengine.com/manuals/sony/str-av570x.shtml
Hi above are links for manuals, these may help..
When one wires up anything it is all usually color to color output to input... usually RED & WHITE stereo audio.
Now we would start with our Tuner this the CD player, & Cassette deck, will wire into the Amp's INPUTs , red - red & white - white, these go into the Stereo INPUTs on the AMP... 1, 2 & 3 and be selected via the input selector on the AMP.
Now after all these in's and out's are wired we need to wire our speakers, this too is simple, locate the outputs on the Amp, and wire accordingly, Plus to Plus and Negative to Negative... each speaker has two wires a Plus, + & a Negative -
All will/should be clearly marked and it will be easy to do. You will need patch leads, one set each for each unit, these will be a pair of cables, usually Red & White with RCA jacks on each end, as related these go color to color from the RCA OUTPUTs Sockets, of the signal suppliers, ie: Tuner, FM stereo & Cassette deck... these ALL will wire into the Main Amplifiers INPUTS, usually at rear of unit, and clearly marked, after this is all done, then as related again now connect the Speakers, again the OUTPUT on the Amp will be clearly marked, as output and + & -, + & - (two sets), one for each channel.
Now each INPUT is selected ON the AMP, and it's output will then be directed to the speakers attached to the Amp..... Just wire and test one at a time, and i am sure you will prevail.
Hope this helps.
Jun 20, 2011 | Sony Audio Players & Recorders
I have a hatachi model #hta-3000 and the problem I am having is when I try to use the tuner the light comes on for AM but no music comes out and when I switch to fm the light turns off and no music just...
make sure you have the am and fm ones in the right ports but more importantly you will have to program the receiver for the correct channels i.e 104.1 fm etc. also there could be interference make sure the antenna is up on a wall close to the window. hope this helps
Mar 14, 2011 | Audio Players & Recorders
Akai Stereo Tuner Amplifier(AA-1125).with faulty tuner
It could be that IC's that control the AM/FM radio have failed and need replacing. On the circuit diagram it has two numbered LA1240 and LA1230. Though it's unlikely both would fail at the same time. Unless you were not using the AM radio and that failed first and then the FM one went. However there is a 7 pin device which is called the Front End. This is located connected to the tuning gang. The metal thing with flanges that in-twine. Both the AM and FM aerial leads go into this before reaching the IC's. It contains a FET and some transistors. It has 12 volts on pin 4. And there is a 300ohm output on pin 3, where both FM and AM signals come out. So you can check that out. If it's not showing 12 volts on that pin there is something wrong or the 300 ohms on 3.
You could at one time get a replacement Front End, but after all this time it's unlikely they are still made. But with a lot of work it should be possible to get inside the Front End and replace the faulty parts.
The service manual is free and online. Just type the model number and service manual into google and you will see the free PDF of it. Parts numbers for the Front End are mentioned, just in case somebody still stocks it!
Jul 02, 2017 | Audio Players & Recorders
Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Jul 06, 2009 | Audio Players & Recorders
225 people viewed this question
 Grubhead
Grubhead
