Question about Jensen VM9410 Car DVD Player
RTS202 RCA DVD SOUND BAR
WAS WORKING FINE UNTIL THE OTHER DAY. THERE IS NO POWER NOW AND IT WON'T TURN ON. I'V TRIED OTHER PLUGS INS, ETC.
    Problem Solver:
  • 7 Answers
Check you fuse
Posted on Jan 06, 2009
I powered up a RCA RTS202 DVD home theater system then press the open button for DVD and the power keep turning off what's wrong with it and when open it up there was a disk suck but after taken it out the...
try this unplug the system leave it for 30 minutes to an hour with no power that should do a complete reset. Plug it in and see that doesn't fix it.
Nov 15, 2014 | Audio Players & Recorders
RCA RTS202 POWERBAR SHUT OFF
There are many issues that may be at play here. Most likely, you are experiencing DC Offset(meaning you have a damaged amplifier). For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 20, 2013 | RCA RTS202E 200W Home Theater Sound Bar...
Can i sync my rts 202 sound bar to a comcast remote
Download the user manual for Comcast remote model you have. It will have all details.
Jun 04, 2012 | RCA Rts202 Dvd Home Theater System
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
My manavox tv dvd/vhs unit is hooked up to a converter box. All I had to do was turn on the converter box and then the tv. It was working just fine untill I cut if off one day, instead of leaving it on...
  1. Try unplugging the converter box from the power, and RCA or Coax connector. Reconnect the power and RCA or Coax connector. Try turning it on.
  2. Look for a reset button. May be a small hole with a button inside, if you find one use a paperclip or similar to press it.
  3. Try the converter box with a different TV.
  4. If this doesn't fix the problem, replace the converter box.
Feb 22, 2011 | Philips Magnavox 20MC4304 20 in....
Problem with eyeclops video projector...after
unplug all rca cables from your eyeclops, then try all three colors one at a time, into the yellow colored hole on the side of your eyeclops, until you get a picture, and you have to have the dvd player on and playing a dvd, otherwise the light won't come on your projector, then plug in the audio sources, the yellow and white. When I got my eyeclops mini projector, it wouldn't work at all when I plugged the yellow rca cable in the yellow hole on the side of the eyeclops, the red into the red, and the white into white. Only when I placed the red rca cable into the yellow hole on the eyeclops, the yellow into the red hole, and the white rca cable into the white hole did it finally work. That was for my dvd player. With the video game function, I plugged each color Rca cable into their same colored holes on the eyeclops and it worked fine, but again, you have to have your device, whether it be a dvd player or game system on and running before your eyeclops led lights will turn on. Not sure I had to switch colors when I played my dvd player, but that's how it works on my mini projector, anyways.
Jan 17, 2010 | JAKKS Pacific Eyeclops Bionic Eye Tv...
RCA 5.1 surround sound system, The system was working fine until one day it decided not to power on. The light turns on when you plug it in, but when you press the power button it doesn't turn on.
power supply problem.
you mean, stand by ok.not power up right.?
ok it can be happen something wrong with its power supply ,standby circuit,system control cct problem, or loose connection on the printed board and loose connection on the connector in the pcb can happen.
some times it can be the power on off switch. anyway open the cower and clean it with compressed air or clean it with small brush then try to turn on again and please comeback with result.
Dec 26, 2009 | RCA RT2250 System
DVD player not working properly
I have a DVD player, a VCR player, a TV set all hook into an RCA RT2250 Audio/Video receiver. Everything was working fine until 2 days ago. Now the DVD player gives me a great pix but no sound. The VCR,and TV are just fine and I have checked everything out, speaker connections, mute buttons, etc. and nothing seems to be wrong. I am thinking that some thing in the receiver got fried. Is it repairable?
Dec 13, 2008 | Electronics - Others
DVD Player does not work
General Problems
Player won’t work (locks up)
• Try unplugging the AC power cord and plugging it back in.
• Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON button while you press and hold the STOP button—wait at least 3 seconds
before you release both of the buttons. You’ll need to set up your menu preferences because this Reset Procedure returns the DVD/VCR’s menus to the
factory default settings and also erases the contents of the Disc Library.
Mar 15, 2008 | Televison & Video
Jensen VM9410 Car DVD Player Logo
158 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
