Question about Philips BDL4231C 42 LCD TV
Need power board fo BDL4231C please help - Philips BDL4231C 42 LCD TV
    Top Expert:
  • Philips Master
  • 74,496 Answers
Contact the nearest authorized service center for Philips. This board cannot bought locally.
Posted on Nov 03, 2012
Testimonial: "thanks for you heelp "
Keeps shutting off with fo code
The F0 error code indicates that the control board detects a stuck key on the control keypad. This is often caused by a bad control keypad but it can sometimes be caused by a failed electronic control board in the oven console. A technician will normally determine which component is causing the problem by
shutting off the breaker
and unplugging the ribbon wire cable for the control keypad from the electronic oven control board in the console. The oven would then be powered back up to see if the F0 error code returns with this ribbon wire cable disconnected. If it does, then the problem is with the electronic oven control board. If it does not return, then the control key panel will need to be replaced. I normally recommend that you have a service technician repair this type of problem. Here is a link for the Sears Service website:
Sears Home Services
Mar 24, 2016 | Sharp Heating & Cooling
Every couple of minites the tv shut off have to unplug tv and it good for another couple of minites
Power supply board have the problems and the causes.That the board,where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board fo the replacement.
Apr 13, 2011 | Toshiba Televison & Video
The led light is blinking, no picture and a strange noise every so often. What could it be?
Transformer's it shorted,that where the noise is comming from.The power supply board is dead.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board fo the replacement.
Aug 11, 2010 | JVC HD-52G787 52" Projection Television
I Have a Sharp FO-4450, there is an error reading as follow's "High Voltage Reading", can you help?
Most likely you will need a high voltage power board. Or a drum or toner contact was damaged. Call a sharp dealership.
Nov 16, 2009 | Sharp FO 4450 Laser Fax
I have an Amana Range #artc8621cc ti displays a FO
HI. this code represents an error within the adapter board(aka: relay board). The safety signal is non-existent. This board will need to be replaced asap. Once replaced, the code will reset, and the range will regain its normal status.
This board is mounted on the inside of the oven, towards the rear on the electric retainer plate, inside of the cabinet.
Oct 20, 2009 | Kitchen Ranges
The oven controls are not working. then FO shows
If your appliance is newer than 1996 F0 error code is a stuck key pad .
To verify turn off power and access the control panel and remove the ribbon connector that goes from key pad to control board .
Now restore power.
If the F0 code goes away you'll have to replace the key pad .
If it stays it means the control board is bad.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 11, 2009 | GE 30" Built-In Single Electric Convection...
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
Philips BDL4231C 42 LCD TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
