Question about Cycling
Does anyone know if I might have damaged the computer screen by putting it on its side?
    Problem Solver:
  • 16 Answers
Not likely. What is it that you are seeing that is making you concerned?
I'll need more info to answer completely: Brand and model, approx age, and what you're seeing that has you asking.
Thanks.
Posted on Nov 03, 2012
  • Joy savage Nov 03, 2012
    Schwann 203a 2008 .. Never used! Worked fine when I bought it but after bringing it home there is no power!
Replaced cracked screen and seen LCD has slight crack,but phone worked perfectly before I put new screen on.Black screen now,and nothing shows up.Can anyone help please !
You need to change it again, because some screen and lcd are not function perfectly, maybe the flix of the lcd has a damage or a broken connection, because some supplier are still selling it,even that they know are defected
Sep 13, 2015 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
I have a nasty virus that did much damage to my Inspiron 531 desktop. I am no loner able to restore to previous date and the disks that came with it do have have the operating system on them. How do I...
Put the first disk in that will say operating System.
Turn the computer on and immediately keep tapping F12. This will show a boot menu. Select the CD/DVD Drive.
If prompted 'Press and key to boot from CD/DVD...' press any key.
This will load into the recovery disk follow the on screen instructions to recover the computer.
Apr 26, 2011 | Dell Inspiron 531s Desktop Computer
DOES ANYONE KNOW THE VOLTAGE OUTPUT FOR FLAT SCREEN FLOURECENTS
sean7587, The only thing I can tell you is that the lamp side voltage will be anywhere from 600 to 1200 volts ac You might want to visit some sites that sell or manufacture CCFL replacement bulbs and try to find out the electrical characteristics of CCFL's Please note that trying to make a voltage measurment with just a DVM, DMM meter is NOT advisable!!! Could damage meter beyond repair!! You may also want to ask if the operating voltage is in RMS volts or PEAK or PEAK to PEAK volts. 12fixlouie
Jan 19, 2010 | Computers & Internet
Can turning steering wheel side to side to full lock about 15-20
chk your fluid levels make sure they are all up to par.
Oct 24, 2009 | Honda CR-V Cars & Trucks
Blue screen appears on start up and has no icons on screen cannot do anything does anyone know what this is
What is your operating system if it is XP then press the F8 key repeatedly when you switch the machine on.
This should put you into safe mode
If you can achieve that then go to Start,Programs, Accessories System Tools, System Restore and try to restore it back a week or so.
Blue Screen is a memory crash so it could also be a problem with the Ram or a conflict
May 21, 2009 | Asus Eee Pc 701Sd Notebook
I have a JVC 56" TV,and I want to clean the inside screens and lamps,when the teck guy did it he unscrewed a few screws and wiped the inside out and was done. Does anyone know how to do this ????
You need to unscrew the base first. There's three screws on the back edge on either side that need to be removed (standard Phillips screwdriver will do). Then gently pull the front cover off. It's clipped in place along the top edge (just below the screen) in two places on either side of the power button; gently pulling the side back will release it.
When that's off there's several screws along the sides & top of the upper front bezel that need to be removed as well, just like with the lower section. The difference is that there's also some screws around the power button panel that need to be removed as well. These are smaller, and if I remember correctly, there's either five or six of them. Removing these also means the that power button panel will be loose. The screen will come off in one piece, but be careful... The two bottom corners fit over some support rods, so you'll need to pull it further out before you try to lift it up or sideways.
And be doubly careful about that screen. There's three sheets that make it up; the outer, glossy protective screen, the middle, grey lenticular screen and the inner screen. The inner screen is the most easily damaged. I know - I damaged mine and now need a replacement. This inner screen has extremely small circular groves on the front-facing side and horizontal grooves on the rear-facing, or now-exposed, side. Use a very soft cloth - microfiber preferably - and wipe from side to side to avoid damaging the fine grooves. You'll probably want to do this with the screen vertical so no new fresh dust falls on it before you put it back on. I'd also recommend removing any jewelry or wrist watches, or anything else that could pose even a remote scratch hazard; the grooves on this screen are extremely delicate.
Replacing the screen is just a simple matter of reversing the steps above.
He Who Really Likes This Model, But Wants To Go Bigger Now.
May 05, 2009 | JVC AV-56WP30 56" Rear Projection...
Replacing the protective tv screen.....
alot of thees tv , you have to lift up on the front to un hook the screen, others you have to slide it to 1 side or the other to unhook it
Jan 09, 2009 | Panasonic PT-53WX54 53" Rear Projection...
I have a Toshiba Satellite series laptop that was dropped and the screen was damaged. I've gotten a replacement but I don't want to mess anything up by changing it myself. Anyone have suggestions? I've...
you'll need to pry the screen gently forward(away from the plastic casing)...along the side s of the screen will be the hinge brackets.....4 screws (2 either side) hold the screen in place...undo these screws and the screen will be free....the only thing connecting screen to computer will be the video ribbon cable which connects to the back of the screen via a plastic pressure clip...release the clip and your done.....remember to be very careful when installing the new screen as its easy to overtighten the screws and damage the screen
Jan 07, 2009 | Toshiba (225EXTR5)
JBL spot series speaker not working.
I know this is old but just incase anyone has the same problem. Its proabably the connection from back panel to the internal amp (Inside the sub enclosure). The ribbon cable has the + for the left speaker right at the edge with quite a bit of tension. Over time and with the vibrations from the sub this will bend/pull out slightly and needs to be pushed back on and some hot glue put around the connection to hold it in place.
Thats how I fixed mine anyway.
Jul 12, 2008 | JBL Spyro Computer Speakers
T61 Screen Problem
If the line runs top to bottom and is perfectly straight then it is the panel beginning to fail.
The LCD that you see connects to a driver board behind it with a very fragile plastic ribbon strip. Any even slight damage to the connection on either side and you begin toget the problem you have.
It could have been caused by a few things.. Excess pressure opening the lid will cause it, as will closing the lid quickly too often.
Flexing the screen (opening the lid only using one hand on one side).
As you see it's more a pressure related issue then anything.
The normal "repair" is to replace the screen. To have the original driver tabs corrected can be a very expensive exercise.
If the line is feint enough, then adjusting the brightness and contrast may make it useable long enough until it is retired or a replacement screen can be found.
Apr 30, 2008 | Lenovo ThinkPad T61 Notebook
Cycling Logo
14 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
