Question about Watches
How to shorten the breclet on a invicta eta g10,21a watch
3 Suggested Answers
  • 2501 Answers
SOURCE: shorten my invicta watch band
I have found some instructions on the Fossil website and since most watches are very similar you can try the method described there.
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care", and then look under "Product Info" on the left and you will see "watch instructions"
Go down the list to the bottom and under "Phillipe Stark" there is an item "bracelet instructions".
Posted on Feb 14, 2010
escapement
  • 2334 Answers
SOURCE: how to shorten my invicta (mens pro diver 8932)
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Aug 05, 2010
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
Every time i look at my brand new invicta drivers watch , it looks like cloudy, where is the nearest accredited repair shop here in the phils.
  1. Customer Service - Invicta
    invictawatch.com/customer-serviceThe Invicta Customer Service Team is here to help. ... If you are not completely satisfied with an online purchase from an Invicta Watch Company website, you ...
Jul 11, 2015 | Invicta Diver Watches
I am looking for a new watch band for my Invicta Pop Lupah 2397 (turquoise). Where can I order one ? Julie
Visit the Invicta site. Their posted price list has prices for what I would expect is replacing the original watch band .
http://www.invictawatch.com/invicta/price_list
If you do not have a local delaer whom you can visit to onbtain a new watch band information on how to ship your watch to Invicata can be found here:
http://www.invictawatch.com/invicta/shipping
Mar 30, 2011 | Invicta Lupah POP 2397 Wrist Watch
The invicta 4048 is an atomic watch with 4 buttons only. I need to know how to set this watch. Previous experts have refered me to the standard Invicta instructions PDF. The atomic watch is not covered...
The Invicta Atomic 4048 is "discontinued", and Invicta is not very helpful. They do NOT offer an instruction manual for the 4048, because it's discontinued. You can call Invicta at 800-327-7682 then you have to ask for "Melvin" who only works until 1PM eastern time. OR you can do the following:
Hold down the 8 0'clock button until it flashes, select 12hour or 24hour preference, use the button at 4 o'clock to select your time zone (GMT) The watch should reset itself to your GMT time.
Mar 01, 2011 | Invicta Atomic Collection Autotech Analog...
How do I shorten the mtal band on the Casio 4334. The back of the band has direction arrows but I cannot understand how to move the links. Can you supply me with directions and an illustration to assist...
Push the pin through, in the direction of the arrow. I used a thin paper clip and a pair of pliers. Poke it through by about 3mm and then grab it and pull it out.
Oct 25, 2010 | Invicta Pro Diver 9321 Wrist Watch
How do you set the watch
Go to http://www.invictawatch.com/new/product/search.php?CAT_REF_NBR=7&prn=2095#2095 (this should be part of the "collections".
Click on the tab maked "manual" and you should find the information you need.
May 25, 2010 | Invicta Lupah Dragon 2095 : Eta 1/60...
Shorten my invicta watch band
Feb 14, 2010 | Watches
How do i shorten a metal watch band i have a casio 708
Look for removable pins in the band to allow removing one link at a time until it fits ok.
Dec 06, 2009 | Invicta Pro Diver 9321 Wrist Watch
Invicta pro diver strap length
ur supose to leave that one open and the rest u can tightin
Jun 10, 2008 | Invicta Pro Diver 9321 Wrist Watch
Watches Logo
47 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
