Question about Chevrolet 1988 Chevrolet S10/s15/sonoma Radio
88 chevy s10 2.8 runs good no power
Sitting still runs good when you drive no power at all 1st gear maybe 5mph has 12psi fuel pressure new plugs,cap,rotor checked egr valve with vac pump holds open till u release pressure /tried used throttle body,est,coil,ecm with same part # coolant temp sensor,timing chain removed all rockers checked push rods & adjusted all valves set timing to 10 & dont know what its called elc. vac box mounted on bracket with coil can any buddy give me any input
SOURCE: falls on it's face when
Slimsoul, a bad fuel pressure regulator would cause a problem similar to this. You may already know this but a fuel pressure regulator kinda works backwards from the way you would think. When your car is at idle it produces the most amount of vacuum which power things like brakes. As your RPM's increase your vacuum drops. When a fuel pressure regulator recieves 0 vacuum it fully opens and allows the most amount fuel to flow through. So, you mash on the gas from idle and the car stumbles from lack of fuel. A common cause of this is because the regulator diaphram has a hole in it, which causes it to open slowly. There is a very simple test for this that, yes, even you can try at home. I'm assuming your corvette is a C4 (84-96). Open the hood, stand on the passengers side, and stare towards the back of the plenum just in front of the distributor. Now look underneath the upper plenum, and attatched to the lower manifold at an approximate 45 deg angle is a round piece that kinda resembles a top hat. This is your regulator. There should be a hard black plastic vacuum line attatched to the regulator. Now for the tricky part, unplug it and crank the car. If the regulator is in fact the problem, this should at least improve if not eliminate your problem. If it does not, my next step would be to check your fuel pressure with a fuel pressure gauge available at Autozone for around $40. A TPI motor needs at least 40 psi to operate properly. Back to the regulator, if it is in fact the problem your going to have to replace the diaphram in the regulator which is somewhat of a pain. You have to pull off the throttle body and upper plenum to get to it. Additionally the FPR is secured with special security torx bits, I believe its a T5. The plenum runner gaskets and throttle body gaskets will need to be replaced if they're original. If you're not somewhat handy I would suggest taking it to a shop to do the job.
Posted on Oct 27, 2008
  • 4669 Answers
SOURCE: 87 chevy truck with TBI idles too fast
Spray the intake with carb cleaner to find the vacuum leak. Check where the EGR mounts and the throttle body gasket sense you had both off.
Posted on May 10, 2009
  • 4088 Answers
SOURCE: 1987 chevy s10 2.5l tbi will not start. changed
That eliminates the crankshaft and camshaft position sensors. Have you checked the fuel injector itself for an open winding or stuck valve plunger? There should not be a steady 12 volts to the injector--if good injector, it would be spraying fuel steadily into the throttle body. But at least the engine should try to run if poorly. Take the injector out, dry it off with air, and intermittently apply 12 volts to one terminal while grounding the other. You should hear a click from inside every time you touch 12 volts. If not, replace it. If it does, it may be plugged with debris. Try blowing through it in reverse with compressed air.
Posted on Jul 17, 2009
  • 5 Answers
SOURCE: 1987 chevy engine problem
you have to reset base idle see manual at library for procedure
Posted on Jul 19, 2009
  • 5 Answers
SOURCE: 1987 Chevrolet S-10 Pickup1987 chevy s10 2.5l tbi
Check the trottle body postioning sensor...
What would cause you to lose fuel pressure while driving.
Chevrolet S-10 Questions - Fuel System Loses Pressure ... > Questions > Chevrolet > S-10
CarGurusJul 28, 2012 - Fuel System Loses Pressure - I have a 2003 Chevy S-10 Pick Up with the 4 ... car a few times, what essentially you are doing is priming the fuel pressure. ... A dirty fuel filter will not cause the lines to lose pressure after the engine is shut off. ... I have a 98 s10 2.2 liter and it was driving fine all day then when ...
Chevrolet S-10 Questions - My 2001 S10 has a hard starting ... > Questions > Chevrolet > S-10
CarGurusSep 16, 2012 - My 2001 S10 has a hard starting problem if the truck sits between 1 ... Vacuum leak, have you checked fuel pressure while it sits? ... Would the spider alsocause a misfire at low rpms? .... at an idle, or squeaking while driving and it gets faster as you go? ..... 1994 Chevrolet S-10 2 Dr STD Standard Cab LB.
Chevy S-10 Won't Start - Repalced Fuel Pump and Pressure ...
Chevrolet S-10 pickup won't run and has no fire unless I jumper the fuel pump relay. ... Once the truck starts and is running you can remove the jumper to the fuel pump ... Iwould get the fuel pressure checked to start with, because that's where the ... 93 gmc 4.3l FI runs but dies out loss of power after 5 mins of running then ...
Stalling S10: I Have a 1994 Chevy S10 2.2l It Stalls After 35 ...
Dec 10, 2015 | 1994 Chevrolet S-10
1996 chevy 1500 4wd pu. cuts out on accel. and hesitates, hard to shift, and poor gas mileage. any help?
Check the TPS, (throttle position sensor), and the fuel pressure. If it is a TBI model the fuel pressure should be 6-12psi. If it is a MPI injection system the pressure should be about 55-65psi.
Oct 29, 2013 | Chevrolet C1500 Cars & Trucks
88 chevy sprint just dies taking hard left turn & wont restart for 25+ mins.
hav u replaced the fuel pump--some cars with old pumps are sensitive to turns--git a fuel pressure test done to confirm
Jun 03, 2013 | Cars & Trucks
1990 chev K2500 5.7 TBI driving down highway and just quit like i turned it off. pulled over will idle fine but off idle tries to die. after shutoff for a few minutes starts an has throttle respose for a...
Fuel injection needs 20-30 pound pressure to fire the injectors. Try to check pressure before filter. If its low your pump is no good. If its ok then you have pressure drop after the filter. Filter on backwards or clogged.
Nov 25, 2010 | 1990 Chevrolet K2500
After sitting hard to start turns over good acts
Put fuel pressure gauge on it and go for a drive, gauge taped to windshield. Fuel filter old? Fuel pressure regulator?
Mar 11, 2010 | 1998 Oldsmobile 88
1993 Chevy S10 Blazer engine hesitation with smoke from exhaust
Had a 94 Olds Bravada that did a similar thing and it was EGR valve on the front of the intake. It' s easy to take off and clean with WD 40 and if you have an air compressor blow it out good.
Dec 19, 2009 | 1993 Chevrolet S-10 Blazer
88 chevy truck 5.7 engine not firing
Nov 27, 2009 | Chevrolet Silverado 1500 Cars & Trucks
1998 Chevy tahoe Hard to start when cold
replace your MAP sensor(manifold absolute pressure) the map sensor is the computer for your fuel pressure regulator telling how much pressure. Unless your tahoe runs like **** going up hill than it inevitably your fuel pump
Feb 17, 2009 | 1999 Chevrolet C/K 2500
1999 chevy blazer fuel problem
probably not fuel filter . probably going to have to remove the upper intake and replace the fuel injector spider(fuel inj assebly) if it is droping fuel pressure it is leaking into the upper manifold
Nov 29, 2008 | 1999 Chevrolet Blazer
Chevrolet 1988 Chevrolet S10/s15/sonoma Radio Logo
64 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Lawrence Oravetz
Glenn Smart
Glenn Smart
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
