Question about Water Heaters
I hv water in my gas - Water Heaters
  • Water Heaters Master
  • 5,089 Answers
Water will stop gas control valves from operating correctly, usually triggering safety shut off.
Ask question on pro water heater forum, which has response for bleeding air.
http://www.thetankatwaterheaterrescue.com/forums/forum3/1340.html
Could be utility-company problem:
http://www.denverpost.com/news/ci_21631409/water-gas-lines-stumps-xcel-frustrates-mayfair-residents
Posted on Nov 03, 2012
GE SmartWater Hot water tank. Water heater will not stop heating.
Hello Anita:
1) For gas water heater: Turn off gas to heater:
http://waterheatertimer.org/images/Gas-water-heater-89-valve-2.jpg
2) For electric water heater: Turn off circuit breaker.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#veryhot
3) For gas: Copy following link to identify gas control valve thermostat, and troubleshoot by type of gas control.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
4) For gas: Gas control valve thermostat has probably gone bad.
5) Add comment and give clear description of water heater.
6) Call plumber.
Feb 17, 2013 | Water Heaters
GE Smart Water Hot water heater 40 gal will not stop heating water.
1) For gas: Turn off gas to heater:
2) For electric: Turn off circuit breaker.
6) Call plumber.
Feb 17, 2013 | General Electric GE SmartWater Household...
Need gas control unit& burner for water heater 40 gallon
Reliance is AO Smith.
Each gas control has identifying information on side of gas control valve. Make sure you order for NG natural gas or LP propane gas, since these are two different gas control valves.
Google search the gas control number and results will show.
Copy following links for more help:
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 03, 2012 | Reliance Water Heaters
Came down stairs water heater off and pan filled with water
Copy following link for troubleshooting leaking water heater.
http://waterheatertimer.org/Leaking-water-heater.html
You posted question under propane gas heater.
Propane is heavier and air, and this type gas water heater should not be installed in basement (below grade) since gas leak can fill basement with explosive gas.
Water leak does not cause gas leak, so water leak is separate problem.
Recommended for propane safety: install gas detector close to floor near gas water heater
Regular Natural Gas heater, install gas detector higher on wall since NG is lighter than air and will rise.
Aug 04, 2012 | Whirlpool 40-Gallon 6-Year Gas Water...
Lighting instructions
More information is needed.
You posted under electric water heater.
Are you trying to light a gas water heater?
Each water heater is different depending on gas control valve.
Instructions for each gas water heater are printed on front of water heater at gas valve.
Add a comment and describe the gas valve, describe what the instructions say, and describe what general problem you are having for possible asistance.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 06, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Just purchast and installed everything hooked up push the sparker looking through window I see nothing
You posted under Reliance gas water heater
You installed a new gas water heater and are trying to light water heater using the piezo igniter.
Not clear is what steps you have taken so far, and which gas control valve is on the new water heater, and what lighting instructions say on side of water heater.
Also unknown if you bled air out of gas line, or if gas shut-off handle is rotated so handle is parallel with gas line.
Read instructions written on side of tank, open link below to double-check installation, and then add a comment with steps you have taken so far, and describe the type of gas control valve on water heater.
Jul 03, 2011 | Reliance Natural Gas Water Heater Control
I have a reliance 501 propane gas water heater how do i change a thermostate
To change a gas hot water heater thermostat you will need to first buy a new gas valve for your hot water heater. The gas vaive and the thermostat are integrated into one unit.
To replace the thermostat on a gas hot water heater you must follow these procedures....
1. Turn off the incoming water and drain the water heater.
2. remove the pilot tube, the burner gas tube and the thermocouple from the gas valve. Turn off the gas line and remove from the gas valve.
3. get a pump pliers or a wrench in behind the gas valve and turn the whole assembly CCW to remove it from the tank.
4. After appliying pipe dope or tape to the new gas valve threads, turn the new gas valve into the tank by turning in a CW direction. Be careful not to damage the small wires to the ECO. They are the little red wires on the back. If you break them the assembly is irreparably damaged.
5. reinstall the gas line, thermocouple, burner tube, and the pilot tube to the gas valve.
6. Fill tank with water. Make sure to open a hot water faucet and purge all air from the tank.
7. Check for leaks where the gas line hooks up with soapy water.
8. Relight pilot light and check operation.
9. Set the new temperature setting to a medium setting and then adjust the temperature to your likeing from there and adequate time for heating completely.
heatman101
Feb 23, 2011 | RELIANCE ELECTRIC WATER HEATER
Water Heaters Logo
140 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
