Question about Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE PTS Router (RTP300-NA)
Want to know how to connect another pc
My primary PC is connected to the internet and I want to know how to set up my other pc (thats in another part of the house). can It be wireless or does it have to have a cable?
Your specific model router RTP300-NA, doesn't have wireless capability- you'll need to run a cat5 or cat 6 cable to connect your pc. You may be able to share the connection from the primary pc using two wireless adapters, but it would be easier and cheaper to get a different router with wireless.
Hope that helps!
Posted on Jan 04, 2009
Won't load webpages
assign these static DNS address for your internet connection...
primary dns 8.8.8.8
secondary dns 4.2.2.3
Jul 25, 2010 | Dell Inspiron 9300 PC Notebook
Tip
Set-up your I-mate Jama 101 into a Wireless Modem
Your i-mate™ JAMA 101 can be configured to act as a modem for your PC, allowing you to have a connection to the internet for your PC while you are out of the office or away from home. Your PC can be connected to your i-mate using Bluetooth® or a USB cable.
Although setting the device up for Internet sharing the first time may take some minutes, you only need to do these actions once per PC. Subsequent connections are quick and are explained at the end of each configuration.
Before you start, you must ensure ActiveSync 4.2 or later version is installed on your PC. You can find this program on the Getting Started CD that came with your device. You cannot run this function with earlier versions of ActiveSync. These instructions show how to set up your PC for connection over GPRS, please contact the customer support team if you wish to connect over a circuit switched connection. If you are running Windows Vista on your computer, you do not need to install Activesync. Windows Mobile Device Center software comes pre-installed with your operating system.
Getting Started
1. On your i-mate go to Start > Programs > Internet Sharing
2. You will be presented with the main screen of the Internet Sharing program
You now need to define the Web connection that your device will use to access the internet. If you have already defined an internet access connection in your device, you may select it from the dropdown menu in the ‘Network Connection’ list, and you are ready to connect to the internet. You can go straight to the section ‘Connecting over USB’ or ‘Connecting over Bluetooth’. If you have not yet defined an internet connection, you must define it now.
3. To set up the connection from inside Internet Sharing, go to Menu > Connection Settings
If your cellular subscription includes a GPRS subscription to the internet, then choose the GPRS option. In the bottom right, click “Next”.
4. Now fill in the details for your cellular provider’s access to the internet. You should contact your cellular provider for these details.
For the description field, you can type in any name you wish. For the “Connects To” field, choose “The Internet”. The “Access Point Name” field must be filled in with the details provided by your network operator.
Also enter the user name and password provided by your mobile operator, and any other details they provide, such as Primary DNS, Secondary DNS and IP address. If your mobile operator does not provide these to you, then leave the fields blank.
Once complete, press Done, then Done on the next page, and then Done on the next page to return you to the Internet Sharing application.
on Mar 30, 2009 | i-mate Jama 101 Smartphone
I think that the wires to the disk driver are in the wrong place, whats the right way they go in
Primary IDE Connector with Hard-Disk Drive To connect the PC-DVD drive to the primary IDE connector with the hard disk, perform the following steps:
  1. Back up the files on your hard-disk drive before you proceed.
  2. Set the jumpers on the PC-DVD drive as slave and the jumpers on the hard-disk drive as master (see Figure 11).
  3. Connect the power cable and IDE data cable to your hard-disk drive as shown in Figure 13.
Figure 13. Connecting the PC-DVD Drive to a Primary IDE Connector with Hard-Disk Drive
May 23, 2010 | E-Machines T2042 PC Desktop
Have a mini laptop, appears it has wireless connection but i cant get on the internet
If it shows the Wifi is connected then check the connection settings of your Primary Browser (Internet Explorer), see if there is any Proxy settings has been imposed or not.
Also check for Firewall restrictions.
May 06, 2010 | ASUS Eee PC 900HD Netbook
Error code 8002ad23
Hi Giles
You probably have your router connected to your modem, and a PC connected wired/wireless, and the ps3 connected wired/wireless.
1. First you need to start your ps3 system. Go to your network settings and select information. Write down your IP, Subnet mask, Standard Gateway, and the primary DNS.
2. Start your PC and go to your networks settings. Right click your network adapter, click properties. Select "Internet Protocol version 4 (TCP/IPv4). Click properties and type in manually the IP adress, Subnet mask, Standard gateway and DNS.
Then you click "Advanced" and then you click "WINS" then "Activate NetBIOS over TCP/IP". Save your settings and connect the ps3 to your network (should not make a difference if you do it wired or wirelessly)
Let me know if this helped and please do rate my solution.
Regards
KreativeGeek
Feb 06, 2010 | Sony Playstation 3 (PS3) Console
I have a advent milano w7 when try to connect to the internet via wireless router. connecting to router but not to the internet when running diagnostic report it comes back saying that it may be the afw...
In you r network adpater setting;Set the router IP address as your Default Gateway IP address
and In the primary DNS setting put the DNS address your Service provider.
It will work
Dec 25, 2009 | Advent Netbook
Dlink WBR 2310 cannot connec to internet
Try to bypass the router and connect to your modem. Make sure you have Internet connection.
>If you have Internet connection. connect back your modem to the router.
>access the configuration page of your router.
>If you are given a specific IP by your Internet Service Provider, use that one.
>Login to your Dlink (type in on the address bar 192.168.0.1)
>Click Setup and Internet > Click on Manual Configure
>My Internet connection would be Static IP
>Type in your IP address, Subnet Mask, Default Gateway, Primary and Alternate DNS
>Click on Save Setting on top.
but if your Internet Service Provider did not provide you those informations
> Under My Internet connection Type choose DYNAMIC IP
>Click on Clone Your PC MAC address
>Click on Save Settings
>If it ask you to reboot, click on Reboot.
>At the very top click on Status
>Under Status look for WAN
>Under WAN look for IP address
>If you have values beside from zero it means you have Internet connection otherwise, call your dlink manufacturer for manual configuring your router for Internet connection.
Jan 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Help installing
The thing you don't say, is that you already have a high speed network connection by either DSL or cable. You already have a modem/router that you plug into for your internet. This one is an extra one you would like to use as an access point for your home wireless network.
You will need to set it up as a router not a gateway in the configuration. You should turn off the DHCP for the wireless router and just let it perform pass thru to the primary router to assign IP addresses. Set up the wireless router to have an IP address in the same subnet as the primary. If primary is 192.168.1.1 set the wireless routers IP to be 192.168.1.2 or 192.168.1.3, etc. Then set up the configuration for the wireless settings and test the wireless connections with a laptop or PC. Plug the Wan connector on the wireless router to one of the ports on the primary router and you should be good to go.
Oct 30, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Still can't connect
make sure theres no firewall running on your pc, sometimes the firewall blocks connects to the internet..
Aug 22, 2008 | NetGear WGT624 Wireless Router
Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE PTS Router (RTP300-NA) Logo
52 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
