Admiral Capacity Plus Washer agitator is loose. How do I fix this?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 03, 2012
  • 12 Answers
SOURCE: My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Posted on Oct 26, 2008
SOURCE: won't agitate
Ours did this and it was because the bearings had busted. I called a local repair guy and he told me over the phone just by listening to the sound. Maybe you could do the same. I do know this, if it is your bearings, buy a new washer. It's not worth the repair...trust me.
Posted on Aug 04, 2008
Yozzer6821
  • 116 Answers
SOURCE: Agitator sounds as if it's stripped
The agitator and drive gearbox are all one part and are not serviceable (sealed), if it is the gearbox the machine is possibly scrap as the part is more expensive than a new machine. Will need further investigation.
Is the spin OK (quiet) the motor rotates one way to agitate and the other way in fast to spin, the belt may be removed at the middle pulley (Below) rotated in each direction to test. try the machine without the belt and listen to motor.
Posted on Jan 05, 2010
Testimonial: "Great feedback. Will try suggestions. Thanks."
blueextc3221
  • 15935 Answers
SOURCE: How do I remove front panel of my Admiral Capacity Plus washer?
The front panel does not come off.
To access the inside - there are a few screw on the back - then the shroud is removed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
richroth
  • 9472 Answers
SOURCE: admiral capacity plus washer model #LNC 6766B71
Here is a diagram to show you how the agitator goes together.
Posted on Nov 28, 2010
I have a Admiral Capacity Plus washer LNC6267B71. Washer makes loud grinding noise when agitating & spin cycles. Machine does fill, drain, agitate & spin. Only noise is concern.
Hello. Your symptom describes damaged bearings and/or a damaged transmission. This is a MAJOR, INVOLVED repair requiring special tools to prevent serious injury during dis-assembly and re-assembly. I strongly suggest acquiring outside service to repair this machine if cost effective. There are many parts that have to be removed and then replaced--if you've never done this--don't attempt it. There is a brake spring with 200lbs of torque on it that has to have a special tool mounted to relieve the tension during removal and then re-compress it during replacement for example. Sorry to be so dramatic but I don't want you to get hurt needlessly. I hope I helped you!
Nov 05, 2015 | Admiral Washing Machines
There is cloth stuck under the aggitator on my Capacity plus Admiral washing machine. Model #lnc6766B71 how do I remove the aggitator
As a general rule Admiral is a VERY inexpensive machine, so you may be better off with a new one if the parts prove expensive. MAKE SURE TO UNPLUG MACHINE.. Be careful the agitator doesn't come loose suddenly when you are removing it, I have seen more than one bruise on the face from this.. hold your head to the side when pulling it off. http://www.rakerappliancerepair.com/NephewClub/Diagnostics/Washers/Maytag/Maytag%20TL%20Bulletin%20TDL-0086-B.pdf
Jul 06, 2015 | Admiral Washing Machines
Agitator comes off during cycle in my admiral capacity plus washer. How do I fix it?
If the bolt is still on top. it was probably screwed too tight and wore through. then you need a new agitator
Sep 22, 2011 | Admiral 32 cu. ft. Washer
Washer won't agitate or spin
i believe this is what we call a direct drive system 2 things it could be is the drive coupler located under unit between the transmission and motor .it is a plastic piece with 3 prongs on each side and a black rubber bushing that goes in between each side to connect ..it is somewhat like a shear pin on a tractor it is designed to break when to much pressure... before you check this make sure the unit is making some sort of noise when it is suppose to agitate or spin..you should hear the motor running just won't spin the tub... if you are not hearing anything then i would suspect you have a bad lid switch on the unit... the lid switch is like a safety switch while running if the lid is raised the unit will stop power supply to motor ...you can check the lid switch byby passing it temporarily and see if it works .... one of the 2 may be your issue.... good luck to you
Feb 11, 2011 | Admiral 32 cu. ft. Washer
Nov 25, 2009 | Admiral AW22 Top Load Washer
Oct 26, 2008 | Washing Machines
Won't agitate
Jul 24, 2008 | Admiral AW22 Top Load Washer
Admiral Washer model #LNC6757 will not agitate
Possibly a loose agitator, try lifting the agitator, if it lifts then it is un secure, remove the softener cap and down inside the agitator you will see the fixing bolt,
You will need to lift out the agitator to retrieve the bolt if it has come fully un done, refit the agitator and secure using a socket and long extension bar.
Apr 15, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
