Question about Crosley CRFF16 15.9 Cu. Ft. Frost-Free Refrigerator with Recessed Coils in Stainless Steel
Loose wire underneath
There is a two prong wire underneath that is unhooked. Where does it go ?
    Top Expert:
  • Crosley Master
  • 9,472 Answers
What is the model number listed on the unit?
Posted on Nov 03, 2012
How to remove the ignition switch
take ruber boot off ignition unscrew nut a little unhook wire hud under dash remove nut take out or the other type uses prongs to hold in sqeeze prongs and push out switch done
Aug 25, 2014 | Garden
Tip
Chevrolet Blazer 4.3 Alternator removal
Unhook the battery terminals. Loosen the tensioner pulley and remove the belt from the pulley (if there's no belt routing 2_bing.gifdiagram under the hood, draw one first). * Unplug the 4 pronged black wire that goes into the back. Unscrew the 10mm bolt that holds on the positive lead cable to the alternator. Take out the upper and lower bolts on the alternator. Check the back and see if it still has the black support rod bolted onto it. If it does, then remove that bolt also. GENTLY pry the alternator loose under the lower mount (be careful these alternator brackets have a tendency to break if forced too much).
* Sometimes it's easier to remove the wires after the unit is unbolted and loose, just a matter of ease and preference.
If this pertained to your vehicle, please take the time to rate it, as I took the time to write it. Thank you.
on Feb 28, 2010 | Chevrolet S 10 Cars & Trucks
How to remove headlight housing 2001 FLSTC
To remove the headlamp housing assembly disconnect the wiring harness and then remove the bolt underneath the housing and ligt the housing off the mount.
To change headlamp bulbs:
2001 FXSTD, FXSTS and FLSTS Models
Remove the trim ring screw and then the trim ring, pull the wiring connector block off from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to
unhook them from the notches in the headlamp assembly, pivot the wire retaining clip away from the bulb, replace the bulb and re-assemble all.
2001 FXST and FXSTB Models
Loosen the trim ring screw and remove the trim ring, pull the wiring connector block off from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to
FLSTC and FLSTF Models
Except for HDI motorcycles which have a Halogen bulb similar to FXST the FLSTC and FLSTF motorcycles have a sealed beam type headlamp. HDI headlamps also contain a position lamp bulb that is found under the headlamp assembly's rubber boot.
Remove the trim ring screw and then the trim ring, being careful not to bend the two tabs that hold the
top of the trim ring in place, pull the wiring connector block off from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to
May 17, 2014 | 2000 Harley Davidson FLSTC Heritage...
Just moved into an older home with a 3 prong dryer receptacle. My whirlpool duet dryer model: GEW9250PL1 currently has a 4 prong cord. I have purchased the 3 prong cord and am ready to install. Very...
Hi, White, green green/white striped they are all the same....only thing you really have to worry about is that you have the red and black in the proper places...
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jul 13, 2011 | Dryers
What do I have to remove to remove the alternator, (hoses,wire harness, hoses)?
Unhook the battery terminals.Loosen the tensioner pulley and remove the belt from the pulley (if there's no belt routing diagram under the hood, draw one first). * Unplug the 4 pronged black wire that goes into the back. Unscrew the 10mm bolt that holds on the positive lead cable to the alternator. Take out the upper and lower bolts on the alternator. Check the back and see if it still has the black support rod bolted onto it. If it does, then remove that bolt also. GENTLY pry the alternator loose under the lower mount (be careful these alternator brackets have a tendency to break if forced too much).
Feb 26, 2010 | 1996 Chevrolet Blazer
I am changing out the dryer cord on my Whirlpool electric dryer from a 3 prong to a 4. there is a green wire with a yellow strip coming from the dryer and grounded on the side of the dryer like a grounding...
Hello. Now that you are upgrading to the four prong you should unhook the green wire with yellow strip coming from the dryer and instead attach the extra green ground cord on the 4 prong to the screw on the side of the dryer. Regards, Joe.
If you prefer to see this in picture form, check this link: http://www.appliance411.com/links/jump.cgi?ID=466
Nov 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I HAVE A HEIL HEATPUMP.CONDESING FAN MOTOR WENT OUT, WHEN I WENT TO UNHOOK IT I NOTICED A BURNED CONNECTION ATABIG CAP. GOT THE CAP AND MOTOR NOW THE BLOWER MOTOR DOESNT COME ON. THE GUY SOLD ME A TWO...
a commom wire comes from the top of the contacter , attactch this wire to two prong cap, then attatch what is usually a brown wire to the other side of the cap , find coommon wire from fan motor and attatch it to the same side you attatched the common from the contacter ,caps are not polarity sensitive just make sure brown fan wire is opposite common
Sep 29, 2009 | Heating & Cooling
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Crosley CRFF16 15.9 Cu. Ft. Frost-Free Refrigerator with Recessed Coils in Stainless Steel Logo
Top Crosley Refrigerators Experts
Colin Stickland
Colin Stickland
fta777
ray gallant
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
