Question about Hitachi Televison & Video
Front panel locked and remote broken is there a way to unlock front panel controls
Model 57F520
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
Not manually and to my knowledge this model does not have a lock there---remotes for these are widely available.
I would Google for the owner manual and then the remote if no help in the manual----you can always call Hitachi customer service........
Posted on Nov 03, 2012
4 Suggested Answers
  • 41 Answers
SOURCE: RCA TV LOCK OUT
Try unplugging the set for 4+ hours. That will cause a hard reset back to factory default settings.
Posted on Feb 29, 2008
SOURCE: tv keypad on front is locked and can't find remote
after reading a similar issue on fixya about another person having a similar problem and holding down the setup button for 10 seconds, I tried it on my television (although I don't have a setup only a menu button) and it worked. Thanks.
Posted on Jan 14, 2009
SOURCE: The front controls are locked
Hi, go into the menu via remote control and select special in the options. select child lock and untick it if it has a tick next to it.
This should re-enable the front control panel.
Hope it helps.
Posted on Oct 14, 2007
Front panel unlock
To release panel lock, you must have its original remote control.
Apr 26, 2013 | Televison & Video
I have a Honda Odyssey 2001. The car's front passanger door can not be opened from outside. Remote control lock and unlock function is ok and the door can be opened from inside. Can you suggest wh
you have to take off the door panel and look. most often the linkage comes off of the outside handle; sometimes something is broken. It will be a mystery no more when you remove the door panel and look.
Mar 03, 2013 | 2001 Honda Odyssey
Locked out front control panel while in menu. Now I can't unlock front control panel and I don't have original remote control or owners Manual. Help me please. The front panel is all I use for DVD pla
Hi there, if you know what model it is you can do a google search for the owners manual. There should be a sequence of buttons you can push or hold to reset to factory/default settings.
Jan 25, 2013 | Televison & Video
I locked my front panel by accident and have no remote for my rca 20F514TD..how do I unlock?
Hello
To open front panel control function you must have its Origitnal Remote control. If you have lost it, try to borrow it from your friends or relatives; who owns the same model of TV as you have; just to unlock the front panel lock.
[1] From the PARENTAL CONTROL menu, press the up or down arrow to highlight
Lock Fr. Panel.
[2] Press the right or left arrow to turn on (box has check mark) or off (box doesn't
have check mark) front panel lock.
OK.
Jun 02, 2011 | RCA Televison & Video
The remote and control panel are locked on my 52" LED LCD tv.
Hello
To unlock the remote control function do the following.
On the front pane touch control pad
1 Press MENU to display the MENU screen, and then
press VOL[--/+] to select "System Options".
2 Press CH [UP/DOWN] to select "Operation Lock Out", and
then press INPUT.
3 Press CH UP/DOWN] to select "Off", and then press INPUT
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
OK.
Feb 16, 2011 | Sharp LC52LE810UN 52 in LCD TV
Locked tv set model f19421
These are the instructions on locking and unlocking the control panel for your TV: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 12, 2010 | RCA F19421 19" TV
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Unlock my tv
i have problem on my tv i dont know how unlock
Nov 11, 2007 | RCA 32F531T 32" TV
Hope it helps.
Aug 16, 2007 | LG RU-52SZ51D 52" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
