Question about Hitachi 53UDX10B 53" Rear Projection Television
Do I need a converter box for a Hitachi 53uwx10ba TV?
I can't seem to tune in any channels. Just bought the tv used.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
Check to see what input the set is on--set in menu to catv or cable and connect with set on three if using a box---if not then auto program for channels.
If set on catv you should with the remote be able to direct enter a channel to see if tuner in set works or hook a dvd etc to a rear input to set to see if it works that way.
Posted on Nov 03, 2012
  • 103 Answers
SOURCE: Picture Problems with Hitachi 53" Projection TV
most tv shop's will replace convergence ic's,which your tv needs.Thepart number is stk392-180 very common You need 2 plus poss resistors,3 bucks apiece
Posted on Mar 22, 2007
yankeegurl
  • 121 Answers
SOURCE: PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Posted on Apr 13, 2008
TOM2-TOM2
  • 110 Answers
SOURCE: Hitachi 53UDX10B HD Converter
In the USA, "HD Ready" refers to any display that is capable of accepting and displaying a high-definition signal at either 720p, 1080i or 1080p using a component video or digital input, and does not have a built-in HD-capable tuner.
With that said your unit can display HD but does not have a HD-capable turner. You will have to have a converter box to obtain this for over the air channels. If you have any other source that can give you a HD singal (cable some DVD's, blu ray)your unit can display it. Hope this info help's.
# NOTE - If this info was helpful to anyone please click on yes!
Posted on Jun 09, 2009
  • 668 Answers
SOURCE: cant attain digital channel scan on hitachi rear projection tv
Do you have the tuner locked out for use of HDMI input only?
Most of the time when a selection is not able to be hi-lited it is
because a feature that is activated locks out other selections.
Hope this helps,
Skyassoc
Posted on Jun 17, 2009
SD Tech
  • 14553 Answers
SOURCE: Hitachi 53UWX10BA dynamic convergence works but blue is blurry
I know this set very well---you are saying convergence adjusts ok everywhere? If you understand that the blue is usually de-focused a little----there are only two ways to adjust the focus of each tube-----
1.) Behind the front speaker grill there is an inspection plate---with it removed you will see a small black plastic block with 6 controls on it; it is the MASTER SCREEN/ FOCUS BLOCK
2.) THREE of the controls left to right are Screen controls(red, green and blue) and the other 3 are FOCUS--IT IS ALL black and you need to look close to identify which is focus and which is screen---you are looking for the BLUE focus control(one of the 6)
3.) With the convergence grid on screen cover the RED and GREEN lens in the set and try to adjust the focus of the blue(I presume you know how to put the set into the Convergence mode?
4.) The only other way to adjust the Blue focus is from the back of the set---with the Red and Green lens covered up place a blanket over the top of the set that covers the whole screen--from the back of the set you will note that all three of the black focal lens have a wing nut---with the convergence grid up and only blue lines present(Green and Red lens covered with a cloth) look from behind the set at the grid---loosen the wing nut on the blue lens and slowly slide the lens left or right until the blue has the best focus possible----if it will not adjust with the focal lens or the front focus control you have a circuit problem.
I do this here for free and if this information helps you take a minute and give me a vote here. If you have any questions or need advice reply to this posting here and I will assist you.
SD TECH
Posted on Sep 15, 2009
Testimonial: "Thank You! Much better quality now! Your advice was dead on. I did not think it was convergence problem....One more Q, where do I send the beer?"
Trying to hook up digital converter box but cant get reception
This seems related to the TUNER and the IF section as the sound- audio and picture- Y signal does not process with the correct alignment.
Dec 06, 2011 | Audiovox VE727 7 in. Under Cabinet TV
Cant seem to tune in after digital switch over not got any chanels
If your TV is an older variety that wasnt set up for digital signal you will need a set top converter box.
Jun 22, 2011 | Toshiba Televison & Video
How do I tune my hitachi tv. I got it as second hand.
Make sure the cable is plugged into it, or if you're using antenna, make sure the antenna is plugged in. Go to your T.V. menu and there should be an option for channels or programming. After you get into one of those you should have the option to program channels from cable or antenna/air. Also, depending on what model it is and if you're not using digital cable or satellite, then you may need a digital converter box. If you have the model number I can tell you if you need a digital tuner.
May 03, 2011 | Televison & Video
I am attaching a digital set top box to this TV Model C21F200 and have a video/dvd player to attach as well. I can't seem to get both working. Can I tune the video to the TV with the set top box attached?
If your TV has AV inputs available, you can connect the video player there and switch to that input to watch it. I don't think your model does, though; I think it has only an antenna input connector. This means your set-top box will connect there but you have no place to connect the video player. In fact, most new video players only have AV outputs, and don't have an RF (radio frequency - a channel 3 or 4 TV signal) output connector, and you'd have problems connecting it anyway.
All is not lost, although you'll need some extra parts to hook everything up. I'm assuming the set-top box (STB) is going to your TV on channel 3 or 4, using a cable from the box to the TV antenna connector. If your video player does indeed have an RF output, the simple thing to do is get a splitter. They look like this:
Normally, a splitter is used to break one input signal (into the single connector) into two outputs (the connectors on the other side). But you can also use one backwards to combine two sources. So you can connect the RF cable from the STB to one output jack, connect the video player RF cable to the other, and connect the "input" side of the splitter to your TV antenna jack. If your STB is set for channel 3 output, set the video player for channel 4 so they won't interfere. Then you can tune the TV to channel 3 for TV signals from your STB, and to channel 4 for videos. I know, it sounds confusing.
If your video player doesn't have RF output, but just video and audio outputs, you need an RF converter. This device takes the AV output from the player and generates a channel 3 or 4 RF signal the TV can tune in. A typical converter looks like this:
Connect the AV outputs from the player to the jacks on the converter. The output cable from the STB will go to one of the round antenna connectors on the right, and the cable from the other one goes to your TV. When you aren't playing a DVD or tape, the converter passes the signal from the STB through to the TV. When you turn on the video player, the converter switches and you'll see the picture from the player. Most converters switch automatically, but on some you might have to flip a switch. RF converters are available from retailers who sell TVs or online.
I'm sorry if this seems unnecessarily complicated, but most TV sets today have plenty of inputs for all these things, and usually you just plug in the connecting cables and go. But with older sets or sets that don't offer the inputs, you need to go through these shenanigans. But once you have the parts hooked up, it's not too bad.
Hope this helps, and thanks for using Fixya!
Jan 01, 2011 | Hitachi C21-F200 21" TV
Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
Apr 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Manual tuning of Hitachi cle-942 tv
Select the channel to tune & press "CH" this is the key to the right of zero on the CLE-942 remote, Now you can tune the selected channel. You also need this key to sort/move channels after running auto tune.
Aug 20, 2009 | Hitachi HL01453 Remote Control
Hitachi projection tv digital channel problem
yes i have same tv it has no digital tuner >( you must get a converter box
Jan 30, 2009 | Hitachi 57F500 57" Rear Projection...
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
Insignia Digital to analog converter menu doesn't come up
When my Menu did not come up, I found it on the AUX channel (one below channel 3). I was able to go through the set up, but found only one digital channel available. Hope this helps!
Nov 10, 2008 | Televison & Video
Is my tv digital already or do I need a converter?
Your TV does have a digital tuner in it already. Also a converter box is only needed if you use an Antenna to recieve TV. So if you have Cable or Satillite, you will not need a box at all.
Jun 04, 2008 | Hitachi 51G500 51" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
