Question about 3Com SuperStack 3 4400 (3C17204-US) 48x10/100 Mbps Networking Switch
Ss3 update a s3m6_13p01s.bin - 3Com SuperStack 3 4400 (3C17204-US) 48x10/100 Mbps Networking Switch
What does tcs sw off means
Toba, Transmission control switch(tcs sw) or Traction control switch. it's telling you there is a problem in transmission that needs diagnosed.
Mar 10, 2016 | 1998 Ford Windstar
Model du-ss3 need some start up instructions
Contact the manufacturer and talk to their support center.
May 06, 2012 | Washing Machines
Router now works intermittently, will disconnect from internet and i have to unplug it and plug it back.reloaded software, try to update firmware but i get a .bin file and all i can do save it what else...
Try resetting the router. If it does not work then you will have to update the firmware of the router. To do that you have to download the firmware file of the router ( it will have an extension of .bin). Save the file in your pc and go to the router's page and update it. It will look for a .bin file. Browse to the location where you downloaded the firmware and update.
Apr 06, 2011 | Belkin (F5D8235-4) Wireless Router
Not shutdown
i think you do not now how to flash the bios.
first you need the program "wbflash.exe" also you need the xxx.bin file (thad are the bios data) in the program you have to select the xxx.bin file for update the bios if you have done the program screen wil checq the bios and ask for saving old bios if you say yes than thad wil be done after thad you can update the bios with the new one (xxx.bin)if this are done you computer wil restart and the yob are fixed.
NOTE LOOK OUT !!!! if you do not have the right or rong bin file and you update your bios with it the computer wil restat and wil not turn on than you have a bigger problem and it are not reversebile .
only update the bios if you have problems with the computer other wise leave it.
Dec 13, 2009 | Sony VAIO VGN-SZ740N5 PC Notebook
Need manual for IR ss3-e compressor
I have worked on many IR compressors with the SS3 pump. A parts list can be faxed to you from grainger, use part #1WF72 for the pump only. Or try this address : http://www.capsaust.com.au/Uploads/Downloads/ss3-parts-breakdown.pdf
Order pump parts from grainger. The other parts can be replaced with generic grainger parts such as the pressure switch, check valve, capacitors etc. for the motor. If you are having a specific issue with your unit please detail the problem on your next post or email me. I will be glad to work thru the problem or modification. Good Luck!
Feb 20, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
.bin file missing
you can find the file from administrator fplder from c drive. or search for .bin. .Again problem exisisiting re install the os.
Aug 16, 2008 | Computers & Internet
1997 Ford Taurus reading code P0761
The reason your gas milage went down is because you are not going into 4th gear or overdrive the most likely problem is shift solenoid 3 but it could be a wiring or pcm concern.I would test ss3 and go from there.Canging of SS3 is fairly involved and you would need a decent mechanical ability to perform this task.
Jim
Aug 09, 2008 | 1997 Ford Taurus
Open Questions:
Random reboot of 3com 4400 stack Can you help, please? I have a 3Com 4400 stack running the latest version v6.13S. The stack sometimes reboots randomly. The logs showed the following: Unit 1 Watchdog handler is RESET The History Log Id No S/W Rel Reason UpTime SysErr 42 42 6.13s S/W Watchdog (r) 17 Hrs 42 Mins 52 Secs Uptime Hours 16828 Reset 41 43 43 6.13s S/W Watchdog (r) 0 Hrs 51 Mins 14 Secs Uptime Hours 16828 Reset 42 44 44 6.13s S/W Watchdog (r) 0 Hrs 47 Mins 54 Secs Uptime Hours 16828 Reset 43 45 45 6.13s S/W Watchdog (r) 0 Hrs 32 Mins 15 Secs Uptime Hours 16828 Reset 44 46 46 6.13s S/W Watchdog (r) 0 Hrs 18 Mins 48 Secs Uptime Hours 16828 Reset 45 47 47 6.13s S/W Watchdog (r) 0 Hrs 33 Mins 59 Secs Uptime Hours 16828 Reset 46 48 48 6.13s S/W Watchdog (r) 1 Hrs 9 Mins 57 Secs Uptime Hours 16829 Reset 47 49 49 6.13s S/W Watchdog (r) 0 Hrs 59 Mins 28 Secs Uptime Hours 16829 Reset 48 50 50 6.13s S/W Watchdog (r) 0 Hrs 42 Mins 37 Secs Uptime Hours 16829 Reset 49 51 51 6.13s S/W Watchdog (r) 20 Hrs 17 Mins 57 Secs Uptime Hours 16849 Reset 50 52 52 6.13s S/W Watchdog (r) 0 Hrs 5 Mins 19 Secs Uptime Hours 16849 Reset 51 53 53 6.13s S/W Watchdog (r) 0 Hrs 55 Mins 15 Secs Uptime Hours 16849 Reset 52 54 54 6.13s S/W Watchdog (r) 0 Hrs 37 Mins 23 Secs Uptime Hours 16849 Reset 53 55 55 6.13s S/W Watchdog (r) 1 Hrs 26 Mins 17 Secs Uptime Hours 16850 Reset 54 56 56 6.13s S/W Watchdog (r) 1 Hrs 42 Mins 12 Secs Uptime Hours 16851 Reset 55 57 57 6.13s S/W Watchdog (r) 17 Hrs 26 Mins 34 Secs Uptime Hours 16868 Reset 56 Assertions : Id S/W Rel File Name Line 5 3.00 agg_sma.c 1215 6 3.00 agg_sma.c 1215 7 3.00 agg_sma.c 1215 8 3.00 agg_sma.c 1215 9 3.00 agg_sma.c 1215 10 3.00 agg_sma.c 1215 14 3.00 agg_sma.c 1215 Last System Error Data: ID (57) S/W Rel (6.13s) Reason (S/W Watchdog) Unit 2 Watchdog handler is RESET The History Log Id No S/W Rel Reason UpTime SysErr 236 236 6.13s S/W Watchdog (r) 0 Hrs 10 Mins 55 Secs Uptime Hours 48145 Reset 235 237 237 6.13s S/W Watchdog (r) 2 Hrs 2 Mins 20 Secs Uptime Hours 48147 Reset 236 238 238 6.13s S/W Watchdog (r) 0 Hrs 29 Mins 15 Secs Uptime Hours 48147 Reset 237 239 239 6.13s Power (r) 2 Hrs 0 Mins 0 Secs Uptime Hours 48149 Reset 238 240 240 6.13s S/W Watchdog (r) 17 Hrs 5 Mins 9 Secs Uptime Hours 48166 Reset 239 241 241 6.13s S/W Watchdog (r) 2 Hrs 55 Mins 1 Secs Uptime Hours 48168 Reset 240 242 242 6.13s Power (r) 3 Hrs 0 Mins 0 Secs Uptime Hours 48171 Reset 241 243 243 6.13s S/W Watchdog (r) 91 Hrs 47 Mins 28 Secs Uptime Hours 48262 Reset 242 244 244 6.13s S/W Watchdog (r) 45 Hrs 25 Mins 25 Secs Uptime Hours 48307 Reset 243 245 245 6.13s S/W Watchdog (r) 4 Hrs 29 Mins 38 Secs Uptime Hours 48311 Reset 244 246 246 6.13s S/W Watchdog (r) 117 Hrs 3 Mins 10 Secs Uptime Hours 48428 Reset 245 247 247 6.13s S/W Watchdog (r) 0 Hrs 32 Mins 9 Secs Uptime Hours 48428 Reset 246 248 248 6.13s S/W Watchdog (r) 3 Hrs 11 Mins 54 Secs Uptime Hours 48431 Reset 247 249 249 6.13s S/W Watchdog (r) 20 Hrs 52 Mins 50 Secs Uptime Hours 48451 Reset 248 250 250 6.13s S/W Watchdog (r) 3 Hrs 5 Mins 37 Secs Uptime Hours 48454 Reset 249 251 251 6.13s S/W Watchdog (r) 1 Hrs 42 Mins 13 Secs Uptime Hours 48455 Reset 250 Assertions : Id S/W Rel File Name Line 129 6.10s lazy_ack.c 890 137 6.10s poller.cc 1104 138 6.10s poller.cc 1104 152 6.10s lazy_ack.c 890 158 6.10s lazy_ack.c 890 159 6.10s lazy_ack.c 890 169 6.10s lazy_ack.c 890 170 6.10s lazy_ack.c 890 173 6.10s lazy_ack.c 890 175 6.10s lazy_ack.c 890 187 6.10s lazy_ack.c 890 191 6.10s lazy_ack.c 890 199 6.10s lazy_ack.c 890 208 6.13s lazy_ack.c 890 209 6.13s lazy_ack.c 890 225 6.13s lazy_ack.c 890 Last System Error Data: ID (251) S/W Rel (6.13s) Reason (S/W Watchdog)
May 14, 2009 | 3Com SuperStack 3 4400 (3C17204-US)...
3Com SuperStack 3 4400 (3C17204-US) 48x10/100 Mbps Networking Switch Logo
134 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
