How many tons my ruud model # UALB-048JAZ is?
  • matt lyall Nov 03, 2012
    the seer rating is just the efficiency rating 11 seer is an older model i
    is there a problem or you just needed to know tonnage?
  • 38 Answers
4 ton unit 13seer
Posted on Nov 03, 2012
  • 1 more comment
  • volts753
    volts753 Nov 03, 2012
    thanks, but the unit outside said" 11 seer" so....? whats that mean , either is 13 seer like you said or 11 seer?
  • volts753
    also that model # that I find out is the compresor model# . it will make any difference
  • matt lyall Nov 04, 2012
    well they should be close look at the condensor number should be 48 but could be higher because the higher the seer the lower the compressor could go with the larger coil size
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: What is the ton of
The "048" in the model number means that it is a 4 ton unit...12,000 btu /ton... it is a 48,000 btu unit, so it is a 4 ton unit...
heatman101
Posted on May 02, 2011
  • 41 Answers
SOURCE: ruud uamc-048jaz
I would strongly suggest you contact the Manufacturer DIRECT on this issue and let them provide you the information.
Ruud
Customer Service, Warranty and Parts
Phone: 1-800-621-5622
Available between 7:30AM - 5PM Central Standard Time (CST) Weekdays
or
Technical Service
Phone: 1-800-432-8373
Available between 7AM - 7PM Central Standard Time (CST) Weekdays
Posted on Sep 20, 2012
I NEED A RELAY
Check grainger.com or repairclinic.com
Aug 03, 2014 | Ruud Central System Air Conditioner
Uamb-048jaz ruud a/c stopped working what should i check
is outside fan running tells you if contactor is made if so change capacitors on compressor. if not running check transformer,& thermostat.
Sep 01, 2013 | Ruud Heating & Cooling
Ac blower motor attic
that is a model number for the outside condensing unit. to find the motor size for the inside unit, you will need the model off of the inside unit, gas furnace or electric air handler.
Aug 15, 2013 | Ruud UAKA048 Air Conditioner
What is the ton of my Ruud model # uaka-048jaz Serial # 543w m0603 11165 ?
heatman101
May 02, 2011 | Ruud UAKA048 Air Conditioner
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
Compressor will not start.
sounds like the compressor is shorted out, or froze up. the 1 second buzz you hear is the compressors internal overload protector kickin in and shutting the comp. down. its a self resetting circuit breaker. for the most part, the compressor is out and needs replaced.
Sep 02, 2009 | Ruud Heating & Cooling
Ruud uamc-048jaz
What do you need to know? That is a 4 ton 12 seer straight cool system, with 11 kw heat strip. You may go to ari.org to search perfomance data.
Dec 03, 2007 | Ruud Central System Air Conditioner
Heating & Cooling Logo
246 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
