Hi i have a washer machine Whirlpool cabrio. It started to do noise when it spin's. Just like that there was a bearing friction. Do you think it can be repaired and if so what should i do. Thank y
  • 38 Answers
Yes it can be fixed.
could be snubber or rotor and stator depending on sound
Posted on Nov 03, 2012
4 Suggested Answers
  • 39 Answers
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Posted on Jul 04, 2009
Daniel S
  • 4323 Answers
SOURCE: Hi, I have a Whirlpool AWM5080
Hi
It could be due to suspension springs, the outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation. If your machine is making a rumbling noise as the drum turns then you most likely have an issue with the drum bearings. It's possible that normal use can allow water to get to the bearings. Also check the spiders, when you look inside the washing machine you will notice a metal panel in the back that has three arms. This is the spider and it holds the drum in place. Loud noises can also come from spider becoming loose. Hope this helps... Please post back if you need more information.
Daniel
Posted on Feb 01, 2011
  • 389 Answers
SOURCE: Can the bearings and seals be replaced on my Whirlpool Cabrio washing machine?
yes it can be repaired but I am not sure where you can bye the parts from not sure where you live usa / uk if you live in the uk I could tell you where to get them and how to do the job
Posted on Nov 30, 2011
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
Why do I have this Clicking Noise after bearing and seal replacement
  1. Ft. Cabrio Top Load Washer‎
    Adwww.sears.com/‎Black Friday Sale Save Over 40% on Select Appliance
    Hot Buys. Free Delivery Over $399.
  2. Appliance Hot Buys
    You'll Save More When You Shop Hot
    Appliance Buys on Select Products!
Search Results
    Whirlpool WTW6400SW Cabrio Washer Makes clicking ...
    www.fixya.com > ... > Whirlpool WTW6400SW Cabrio Washer
    Whirlpool WTW6400SW Cabrio Washer, makes clicking noise spin cycle related issues. Get free help, solutions & advice from top Whirlpool experts.
Nov 26, 2015 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool cabrio washing machine doesn't spin
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
Apr 05, 2014 | Whirlpool WTW6400SW Cabrio Washer
Making noise when spinning
bearing going bad, ride it until you cant stand the noise then get another machine, not worth changing the bearing
Jan 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio model wtw5500xw0 spins loud
The cabrio has a shaft that runs between the wash plate and the rotor located under the washer. The usual cause for noise during spin is something that has made it's way between the spin basket and tub. But it's best to try and determine if the noise is from under the washer or inside the washer, that way you aren't randomly taking things apart. See if you can pin point the location of the noise.
Oct 18, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washer makes a loud noise when it spins
The bearing is probably going bad, spin it with your hand if it makes noise or you feel a vibration its bad Parts for Whirlpool WTW6600SW2 Motor Basket and Tub Parts
May 27, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio WTW6200SW1; spin cycle loud roar
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 07, 2010 | Washing Machines
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
