Question about Radio Communications
3 Repeaters Can I operate 3 repeaters without interference and overlap area
  • 40 Answers
Not on the same frequency without "voting" receivers which pick the strongest signal an use that transmitter to talk back with.
Posted on Jan 04, 2009
Netgear wn2000 states mover closer to router?
This message means your extender is too far away from your wireless router to make a good connection. Repeaters must be within a good signal range for the connection to work properly.
If you have a wifi enabled phone, tablet, or laptop, you can walk around your home and see where the signal reaches and how well. Repeaters should be placed where you still receive full or close to full signal.
Repeaters may have issues if the wireless router is on another floor, behind metal, or too far away.
Jul 04, 2014 | NetGear WN2000RPT Repeater
How can I fix my network connection via the extender?
The password is wrong for the connection you are choosing.
Don't try and log into the router, just the extender, they should not overlap in wireless ranges, other wise this can cause problems.
Apr 25, 2014 | NetGear WN2000RPT Repeater
FRS 2Way Radio 14 Channel Conair Expedition MODEL FRS200SLV MANUAL
Here is some information that might help.
Range can vary due to topographical and atmospheric conditions. Voice transmissions on some channels are not permitted by law.
Use in DUPLEX mode, Repeater stations can re-transmit your signal over a wider area giving you extended range depending on the location, height and availability of the local repeater station.
For information on the locations of repeater sites in your area visit the manufactures website or look-up UHF channels and frequencies for your area.
Note: some channels / Frequency's are to be Avoided.
UHF Repeater operation is used when long distance communication is required, unless specifically needed use of the repeater channels is to be avoided. Some channels and emergency channels, some are calling channels for establishing communication and some are customary road vehicle channels.
You will need to look these channels up for your Area.
Other stuff on this subject on safety and safe operation.
Electromagnetic Interference/Compatibility
Nearly every electronic device is susceptible to electromagnetic interference (EMI). To avoid the possibility of electromagnetic interference and/or compatibility conflicts, turn off your radio in any location where posted notices instruct you to do so such as healthcaer facilities.
Feb 06, 2014 | Radio Communications
Ipad will connect with wifi in certain parts of house using comcast
Try relocating your wireless router to a central area and see if that fixes it. Also such things as water heaters and concrete structures will interfere with signal. There is always wi fi signal aplifiers or repeaters that can help get a better signal. Call comcast to to see if a firmware or better router.
Good luck
Chad Man
Nov 15, 2013 | Tablets & eReaders
Me tp-link give weak internet and some times dissconected but when i uesed by wire give excellant internet speed
Most probable cause is the materials used in the construction on the home/office or where ever you have the router. Your options would be to move the router to a more central location or you could invest in some repeaters/wireless extender to extend the range of the signal. IF you use wireless extenders please note you will need to make sure they all have the same SSID (name seen for your network) and make each device is on either channels 1,6 or 11. So your first device would be say 1 (Doesn't matter which you pick) the next device would be on 6 and then next on 11. If you had another device, hypothetically you would want it on 1. These three channels do not overlap enough to interfere with each other.
Apr 09, 2012 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
The signal will be fine for a while, then I get a "no signal" message...I usually get this after the radio has been on for a time
Please send me the model number of your Sirus Satellite Radio, and let me know whether can I place a solution before you. Ok.
Apr 02, 2011 | Sirius Satellite Radio Receiver
Connection of dlink range extender
I have this unit. Make sure that the network you are repeating is set to stay on a certain channel. The router I was repeating was set to dynamic channels so that it changed based on what channel had less interference. The dlink repeater does not like that and needs the channel to stay the same.
Apr 28, 2009 | D-Link AirPlus G Wireless Range Extender...
There are many different (possibly fun) ways to boost your routers signals. You can purchase better antennas (If you can disconnect your OEM ones, but those can be over priced). You can upgrade the firmware of your router (requires very good technical skill to properly and safely do that), then tweak those router settings then. You can make you own antennas. ( that requires some radio engineering skills to properly do). You can install an amplifier between the router and antennas (can be expensive). or any combination of the above, but be wary of FCC rules with any modification of RF equipment (don't make the signal too powerful, or cause interference to others in your area). :D
One more viable way is to use a repeater in another area of your home to repeat your routers signal where needed (repeaters are hard to find, can be expensive as well).
Jan 22, 2009 | Linksys Wireless-G WRT54G Router
Radio Communications Logo
57 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
