Question about Vacuums
No suction on my Hoover Dimension
There is no suction and it smells of something burning
    Top Expert:
  • Vacuums Master
  • 14,553 Answers
If you smell something burning unplug until problem is found and fixed, suspect if no suction hose is blocked and if brush wheel it or the belt may be causing the smell, a bad or failing motor is less likely but possible.
Posted on Nov 03, 2012
  • 45 Answers
SOURCE: Hayden Vac2400
Check the carbon brushes, they maybe worn out and need replacing.
Posted on Jan 06, 2008
  • 294 Answers
SOURCE: burned smell
If the motor slowed down this would indicate a bad motor. not cost effective on this model to replace unless under warranty. it is not uncommon these days to see a motor go bad every now and then.
What are the first 4 digits of your serial number? this would be the month and year of mfr. even without a receipt, a warranty service shop should be able to assist you.
Posted on Jan 19, 2009
  • 3 Answers
SOURCE: My Hoover bagless vacuum starts to smell like something's burning
What does it smell like? If it smells like burnt anything-it could be that the fan is broken and lodged in the motor. You can see if the fan is good just by looking into it.
Posted on Mar 15, 2009
carlsbiz
  • 1124 Answers
SOURCE: Hoover canister vacuum (windtunnel)- turned it on
Probably the belt..
Turn it over so the bottom is facing up..
Remove the plate that surounds the brush..
Check to se if brush is spinning frely and that the belt is on there poroper
Posted on Jul 14, 2009
sawdust46694
  • 398 Answers
SOURCE: Burning smell
the belt needs changed. its slipping. make sure its not clogged with carpet or string ect. first. if not buy a belt at walmart. in stock...
Posted on Sep 08, 2009
Testimonial: "Thank you very much for the information you gave me. I changed the belt on the vacuum and the burning smell was gone."
Why does my vax power 2 cylinder hoover make a noise and smell of burning rubber when I turn it on we have cleaned inside and out and all filters
That is the smell of perhaps burning insulation when there is excessive current going into motor. If something in unit is binding the motor will not spin fast enough, generate less back emf, use more current, overheat and burn out!!!!!!!!!!!
If it has a drive belt and that is rubbing up against something and not turning properly that will also cause the smell.
Do not use unit in this condition -you risk permanent damage.
Aug 31, 2015 | Hoover Vacuums
My hoover steam vac is making a horrible noise and smells like its burning
Something may have jammed the brush roller, preventing rotation. This causes the motor shaft to rotate in one spot on the belt, causing the burning rubber smell. Eventually, the belt will break. You need to find what caused the jam and remove it. It would be a good idea to replace the belt as a burned belt is unlikely to last much longer.
Dec 18, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
My vax hoover burning herself what can ido nw ?
Sounds like unit could be plugged some where. If the motor is over worked that will cause it to over heat hence the smell. If it keeps smelling like this you may burn the motor up. Also see if there is suction when you start it up. If not it may be plugged somewhere.
If it's not plugged could be a bad bearing. See if the belts are working ok as well
Jun 27, 2014 | Hoover U5753-900 WindTunnel Bagless...
Hoover Dimension has no suction and it smells of something burning
pets in house? check all hose passages for "hairball" clog...and check the drivebelt that spins the brush...(some have an electric motor to spin the brush, thus no belt)
Nov 02, 2012 | Hoover Bag Paper Microfilter Dimension...
MOTOR RUNS WITH NO VACUUM PRESSURE
Sounds like the belt should be replaced. It maybe turning the brush, but if you smell burning rubber, its slipping and not turning the brush with as much force as it should. Changed the belt. Check the air suction path. If the suction is reduced, something is blocking it. Check the bag (if it has one) and all filters. If the machine picks up any liquid, it will reduce the air flow through the filters and bag. Change the bag and filters. If this is an upright, you may find caked on dirt under or in the area of the brush.
Nov 28, 2011 | Hoover Vacuums
Hoover H3030-006 240 V Motor making a loud sound and burning smell
If you have little to no suction, that sound is happening because you most likely have a clog some were in the vacuum.
smell is probably your motor over working itself do to the clog.
also double check your belts on your brushes that they are moving with the motor. smell and sound could come from the brushes being jammed which would cause the belt to freeze and heat up and could burn the belt and or your motor.
if it is still running though your not in the red yetm so triple check that the machine is cleared off all clogs and jams in the belts and brushes.
Jul 02, 2011 | Hoover H3030 FloorMate SpinScrub 500...
When my dyson dc14 hoover is on it has a strange burning smell, and a noise like air popping, there seems to be suction from beater and it spins. and definitley suction from extension. Filters are clear...
It could be the belt. However, the popping sound does have me puzzled. The popping could be coming from a partially broken belt slapping against plastic.
Jim
Sep 09, 2010 | Vacuums
Hoover canister vacuum (windtunnel)- turned it on and it had good suction, then smoke came out and it smells like something is burning. Is it the motor burning up or something else?
Probably the belt..
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Rubber smell, Hoover
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
Jun 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
50 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
