Question about Cameras
How do you recharge lithium battery for SM digital LCD TV SMD-1150
5 Suggested Answers
neta
  • 852 Answers
SOURCE: Is the battery that comes with the camera rechargeable?
Yes, the battery that comes with the C-7000 can be recharged. This battery is the Olympus LI-12B Lithium Ion battery and it can be recharged using the LI-10C battery charger. Both the battery and charger are included with the camera.
Posted on Sep 04, 2005
Agent Allan
  • 480 Answers
SOURCE: Buying a Camara
Hey Dussan,
Three camera's that might work for you are the Nikon P80, Panasonic DMC-FZ50K, and the Sony DSC-H50. All three of theses camera's have a 12x optical zoom and up, they are all 9 mega pixel and up, they all have movie mode, they all use lithium-ion batteries, and they are all around the same price as the Canon. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 21, 2008
BillB-SA
  • 2761 Answers
SOURCE: My lithium ion battery will not recharge
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Posted on Nov 28, 2009
BillB-SA
  • 2761 Answers
SOURCE: can i use lithium plus 2900mAh rechargeable
Absolutely. The higher number just indicates that the batteries will last longer.
Posted on Jan 04, 2010
What is the difference between GLC-LH-SM and GLC-LH-SMD?
They are 1000BASE-LX/LH SFP for Both Multimode and Single-Mode Fibers, compatible with the IEEE 802.3z 1000BASE-LX standard, operates on standard single-mode fiber-optic link spans of up to 10 km and up to 550 m on any multimode fibers.
If one switch supports Cisco SFP GLC-LH-SM, then it can also support Cisco SFP GLC-LH-SMD.
The difference between GLC-LH-SM and SFP GLC-LH-SMD is the letter "D".
What does "D" mean?
"D" of GLC-LH-SMD transceiver has additional support for Digital Optical Monitoring (DOM) capability.
What is Digital Optical Monitoring(DOM)?
This feature gives the end user the ability to monitor real-time parameters of the SFP, such as optical output power, optical input power, temperature, laser bias current, and transceiver supply voltage.
The comparison between GLC-LH-SMD and GLC-LH-SM.
Related Source:
https://supportforums.cisco.com/document/75181/digital-optical-monitoring-dom
GLC LH SMD Overview
GLC LH SM LC Overview
Aug 18, 2017 | The Computers & Internet
Battery won't hold a charge
Buying recharable batteries will not solve the problem of the battery draining quickly but will help save $ by not having to purchase so many disposable batteries. Check your user guide to see what kind of batteries your camera will accept. Lithium ion rechargeable is the best if compatible. Lithium ion disposible (CRV3) will last a long time as a secondary choice if compatible. Some cameras drain batteries more quickly than others. Just a tip to help reduce the drain: don't use your LCD screen when unnecessary (such as scrolling through several of your pics in-between snapping pics).
Nov 25, 2008 | Olympus FE-230 Digital Camera
Digital still camera
Hey rolvnetr,
The Sony Cyber-shot DSC-S700 Digital Camera should be powered by 2 AA batteries. There are 3 main varieties of AA batteries which are Alkaline, Lithium, and rechargeable NiMH batteries. I prefer Lithium batteries, but rechargeable batteries are also nice but once they start losing their charge it goes fast so have a backup set. You should be able to buy any of these batteries at most retailers, and of course our Best Buy™ stores carry these batteries.
Sincerely,
Allan
Go Ahead. Use Us.
May 03, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Camera not operating - cannot take picture
alkaline batteries?
please try lithium crv3 or lithium aa's, it may really do that even with a new set of alkaline aa's
if you're using ni-mh, make sure it's recharged and if it is, and it's still doing the same thing.. note that most ni-mh's life span is 300 charging cycles. if you barely use the rechargeable batteries, they can still deteriorate through time. if the rechargeable batteries are new, or say 6 month's old - that means the cam actually needs a repair
Jan 15, 2008 | Kodak EasyShare C315 Digital Camera
Battery life?
Using the LCD viewfinder to compose images drains the power capacity of alkaline batteries very quickly. Instead, use the Optical viewfinder to compose your images. Under normal operating conditions using the Optical viewfinder, a set of AA-size alkaline batteries should last for about 35 images. Additional tips for extending battery life: * Use the AC adapter to review images on the LCD. * Use the AC adapter to review images on your TV. * Disable Quick Review mode. * For longer battery life, use one of the following types of batteries: o High capacity alkaline (a new product on the market as of Jan 2000) o Lithium o NiMh (Nickel Metal Hydride) rechargeable. o NiCd (Nickel-Cadium)
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Choosing Batteries
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
LB-01 CR-V3 lithium Batteries
The Olympus CR-V3 lithium batteries will provide approximately 500 shots with typical usage (half of the images shot with flash/half without flash and minimal use of the LCD monitor). These batteries are not rechargeable.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
LB-01 CR-V3 lithium batteries
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Cameras Logo
123 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
