Question about Keurig Platinum B70 Coffee Maker
Milky water coming out of keurig
Has an odor
  • 1,511 Answers
Too much Air in the line. Seals broken.
Posted on Jan 31, 2014
Water pump makes a lot of noise when pulling water from tank
You may need to descale the coffee machine... Use white vinegar and put into reservoir and run until reservoir is as empty as it will get. Fill with water and run to clear....I do this twice to make sure the vinegar odor is gone.
Oct 10, 2013 | Keurig Platinum B70 Coffee Maker
Keurig water/reservoir lid odor
Pull and Clean often. Ports are clogging up with debris.
Aug 31, 2012 | Keurig Platinum B70 Coffee Maker
My wife bought one of these coffee makers about one year ago. It worked fine until Wednesday. She turned it on and it popped. Then we smelled an odor like something electrical was burning. Of course, the...
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 24, 2011 | Keurig Elite B40 Coffee Maker
My keurig is brewing only alittle coffee and the rest of the water is being poured back into the water basin, at a very hot temp.
When is the last time it was cleaned? That's usually the issue & the quickest fix. If the Keurig gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off or keep making partial cups. However, I've not heard of your particular problem with it running the heated water back into the basin. Try cleaning it & see if that reduces or eliminates your problem. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup, also remove the carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir. Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected). If this eliminates your problem, it should be done every 2-3 mths.
If that does not work - call Keurig's Customer Service # at 1-866-901-BREW (2739) Good Luck.
Sep 06, 2011 | Coffee Makers & Espresso Machines
I have the Platinum keurig and the water is going back into the reservoir and not into the cup??? is it beyond repair?
Are you getting a message saying to "de-scale" it may need a good cleaning. That's usually the issue & the quickest fix. If the Keurig (or any other coffee maker) gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off, keep making partial cups & just not working properly. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup filters, also remove the reservoir carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir.Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This may eliminate your problem & should be done every 2-3 mths. If that doesn't solve it - your Keurig may already be too far gone. Good Luck.
Jul 09, 2011 | Vacuums
My keurig only dispenses half of a cup of coffee. Half the water comes through the kcup and the other half is despensed back into the water reservoir
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Nov 03, 2010 | Keurig B60 Coffee Maker
Bad odor when you open the doors of the refrigerator
The odor is coming from your drain pan under your evap coil. This is very ahrd to get to. They make a product that you can set in you fridge and let it run and it will take out odors. Google Refrigerator odors and it will take you the site that will ahve the product. rus
Nov 09, 2009 | Hotpoint HSS25GFP Side by Side...
Coffee tastes like rubber / plastic - brand new Keurig Platinum - any suggestions?
After getting in touch with the Keurig folks - I tried their solution. And... it worked! The coffee this morning tastes wonderful! Here is what they said:
To get rid of the "new brewer taste", we recommend you flush three reservoirs of water through the system. Please add 2 tablespoons of white vinegar to the first reservoir of water. To do this, follow these simple steps:
~ Open and close the handle to simulate a brew cycle (without a K-Cup)
~ Press the largest cup size and brew a cup of water.
~ Repeat the process (opening and closing the lid, then brewing) until the reservoir is empty.
~ Flush two more reservoirs of water through the brewer in the same way.
This process will clear any lingering odors or flavors and allow you to enjoy an unadulterated cup of coffee.
Aug 19, 2009 | Keurig B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
42 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
