Question about Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE PTS Router (RTP300-NA)
I want to connect another pc I have the internet on my primary pc but need to know how to add the other
  • 192 Answers
If it is wirless it is quite simple just lock for your wirless conection on the botom right corner of scren. Now you will need to right click on it and say view wirless networks. It then will pop up a list of available networks that are in range of your computer. Slect the one you own. It may ask for a WEP password which is located on the botom of rour router. I hope this helps and lock forward on helping you fix any other problems you may have with your router.
Posted on Jan 04, 2009
How to connect 80 pc desktops without internet for a primary school
Without wireless.. The easiest way would be to connect them to a network switch or hub. Will they need Internet access at some point in the future? Will they need to share data with each other?
I've seen people daisy chain several small hubs together, but I wouldn't advise that. I would just pick up a 100 port network switch, and not connect it to the Internet. That way the PCs would still be able to communicate with each other.
Apr 09, 2014 | Computers & Internet
My belkin n USB adapter (f5d8053) has been unable to access the wireless internet at my new place, through the mwn-apr150n medialink wireless n broadband router. My other devices connect fine, it's...
Please check the Network Range B/G/N Signal.
This could be the issue if other aplications are able to connect.
Also try to delete Wifi Profiles using the USB and add fresh wifi networks
If not in install & reinstall the the USB Software on ur pc / laptop
Lastly if this doesnt work try to use the USB Adapter on another network / other device and try to connect
If it doesnt then u have a USB Issue
Cheers
Eddie
Jul 02, 2017 | Belkin Computers & Internet
Won't load webpages
assign these static DNS address for your internet connection...
primary dns 8.8.8.8
secondary dns 4.2.2.3
Jul 25, 2010 | Dell Inspiron 9300 PC Notebook
Have re-installed win xp on an IBM T42 laptop, but can not access the internet to update drivers ect
1. if you have wireless, purchase or borrow an add on usb wireless stick. this will allow you to access the internet and add in your missing drivers. 2. or add in a pci card that has ethernet connection to get your drivers. 3. use someone elses computer and download the drivers from the IBM site, put them on a usb stick and then apply them to your unit, (ie more the ethernet driver as a primary and then you can download the remaining ones as you go after it is working. hope this helps.
Aug 25, 2009 | IBM Computers & Internet
Can't connect to internet with compaq d220
hi!,
try to add your internet explorer on add program it may not configured corrupted,click start, click add or remove pogram, click add/remove component,click box of internet explorer,click next until add to your windows, check your device connection of internet was configure and set by your internet server,click control panel,click internet option,than click connection,on connection you will find out the service provider of your internet, if nothing ,call your service provider have it report to install them to you.cheers have a nice a day,thanks
Apr 11, 2009 | Compaq D220M PC Desktop
Firefox refuses connection with ultrasurf's proxy
Well Ultrasurf obviously does not want to work with your internet connection (like mine)
For now you need to remove Ultrasurf. Go to Tools>>Add-ons>>UltraSurf Firefox Tool>>Disable OR Uninstall.
That should at least get your internet working...
As for a working proxy, try using a "Web based proxy"
Google it.
Thanks,
Ted
Mar 17, 2009 | Toshiba Equium 6200M (PV1026U-01A) PC...
Want to know how to connect another pc
Your specific model router RTP300-NA, doesn't have wireless capability- you'll need to run a cat5 or cat 6 cable to connect your pc. You may be able to share the connection from the primary pc using two wireless adapters, but it would be easier and cheaper to get a different router with wireless.
Hope that helps!
Jan 04, 2009 | Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE...
Net
hello there!
By using your phone as a modem, you can get Internet access via your PC. Before you can use your phone as a modem, your service provider must enable your data line. Once the data line is enabled, you must set up your PC.
You can connect your phone to your laptop via USB cable or bluetooth. then open the PC suite for sure there will be set up for this.
You will need the PC suite to do this.
Set up the Data account in the Sony Ericsson K750i:
  • Go to Menu
  • Select Connectivity > press Yes
  • Select Data Communication > press Yes
  • Select Data Accounts > press Yes
  • Select Add Account > press Yes
  • Select GPRS Data > press Yes
  • Enter Name as :mnet
    • APN : mnet
    • Give User name as: mnet
    • Give Password as: mnet
  • Select Save > press Yes
  • Connect your Sony Ericsson K750i with cable.
  • If you are using the USB cable or DSS-20, then
    • Double click Phone Connection link
    • Uncheck the USB prot.
  • Click Start > Programs
  • Select Sony Ericsson > Mobile networking wizard
  • Select Create new connection > GPRS
  • Select Install Modem > Add (install the modem on the same port of the USB)
  • Select Access point name as :
  • For Primary and Secondary DNS: leave blank
    • Give Password as:
  • To confirm select Done
  • Select Connect > Dial
With the Sony Ericsson PC Suite software installed on your PC, you'll be able to synchronise your phone contacts, calendar appointments, tasks, notes, emails and bookmarks between your phone and your PC at any time. You can synchronise using USB cable, Bluetooth™ or Infrared (IR), depending on phone model.
To be able to use Sony Ericsson PC Suite with your PC, there are some requirements on hard disk space and Windows version that must be met. Please see Software downloads on this site to download and for details on the requirements for your phone.
Oct 20, 2008 | Computers & Internet
Connect two computers together
Technically, yes. Both computers should have an Ethernet port (LAN), a crossover networking cable, peer to peer networking using static IP add, and Internet Connection Sharing on the PC with the Wireless Internet Connection. If by chance the PC with the Internet access is already using its Ethernet port, a second NIC could be installed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 28, 2008 | Computers & Internet
Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE PTS Router (RTP300-NA) Logo
83 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
