Question about Kenmore 73952 Gas Dryer
Kenmore 70 series electric dryer runs but won't heat up?
The dryer turns on but won't heat up.  the exhaust vent is clear.
  • 163 Answers
Hi!!! If the unit is electric your heating element needs to be replaced if its gas then replace the coil boosters located on top of the gas valve..Good luck..
Posted on Jan 04, 2009
Frigidaire Model FEQB2152FE1. Start dryer and after 5 minutes "Ad" code; lights blink dryer drum turns, but does not dry clothes
Check that exhaust air vent is venting air. If not, clear vent and retry.
Check that heating element is heating. if not, check overheat switch for continuity with power unplugged. If you don't have continuity get new switch. If it reads ontinuity then suspect the heating element.
Aug 20, 2013 | Maytag Clothes Dryer Almond Timer Knob...
Dryer does not dry well , an the turn knob does not turn while the dryer is on towards turnning off.
Lint Trap
The lint trap is a metal screen with a plastic handle that is located either near the corner at the top of your dryer, or inside the dryer door. In most cases, the lint trap is clearly marked. If your clothes are not drying properly, this is the first place to look because it is the easiest problem to solve. Remove the lint from your lint trap, and then see if your clothes get dry. If they do not, move to the next troubleshooting problem.
Vent Hose
To work properly, a dryer needs to be able to vent warm air. If the vent hose is clogged, bent or has a hole in it, your dryer will not work properly. Examine the vent hose to see if it is installed completely over the dryer exhaust vent, and to make sure it does not have a hole in it. Remove the vent hose to see if it is clogged. There are vent hose brushes you can purchase to clean the vent hose properly. Also check the exhaust vent on the dryer and the outside vent to make sure they are not clogged.
Thermal Fuse
If you have been running your dryer with a clogged vent hose for a while, you may burn out the thermal fuse. A burnt thermal fuse will allow the dryer drum to rotate, but the unit will not heat up. Your owner's manual will show you where the thermal fuse is and provide the part number you need to buy to replace it. Thermal fuses are available at most hardware stores and are easy to replace.
Heating Element
The heating element is the long, coiled wire in the dryer that heats up the air. Over time, the heating element can burn out or become defective. In some models, the heating element can be repaired; in other models, the heating element should be replaced. Refer to your user's manual to see where your heating element is and whether you can repair it or need to replace it.
Jan 09, 2013 | Dryers
Why won't my dryer heat up?
There are several reasons for no heating on a Tumble Dryer. The heating element could be faulty ( open circuit.) There are several thermal cut outs which can also go open circuit The only way to check is with a Multi Meter by a qualified service engineer.
May 26, 2012 | Kenmore Dryers
Dryer heats clothes but does not dry them
Check the following:
Since you said the dryer heats....
Make sure you have the dryer set to the correct cycle, and not delicate or air only.
Make sure the drying cycle time runs for the set period. If not, the timer may be faulty.
Make sure the dryer is tumbling (the drum is turning). If not, you may have a drive issue like a bad or broken belt, or some other mechanical drive issue.
Make sure the lint screen is clean and the dryer exhaust all the way to the outside of the dwelling is clear and not obstructed with lint or anything else. If you don't feel a pretty good beeze coming out of the wall discharge vent, start looking for a plugged vent.
There could also be an exhaust fan issue with the dryer if the vent line is clear. If this is plugged or not working, the back of the dryer will need to be removed and the cause(s) determined.
Make sure the dryer isn't overloaded and that the clothes aren't too wet when they are placed in the dryer, possibly pointing to a spin dry issue with your washing machine.
Jan 12, 2010 | Dryers
Dryer has water in exhaust pipe and not drying clothes
If you have water in the exhaust vent you have a clog somewhere in the line that needs to be cleared. When a dryer exhausts, moisture is included in the air that exits the dryer. This moisture will condensate and collect in the exhaust vent if it has no where to go. If too much moisture builds up this can back up into your dryer's heating circuits. In addition, a clogged dryer actually overheats and dries less efficiently. If the heating circuits continually overheat this can result in component failures and is a potential fire hazard. Inspect your dryer exhaust vent ducting thoroughly from where it leaves the back of the dryer, to where it exits your home. Make sure there are no bends, sags, kinks or clogs in the line. In addition, it is recommended that you use the semi-rigid metal type vent ducting. It resists kinking, is heat resistant and prevents rodent intrusion. If you have questions let me know. I hope this helps you.
PS If your heating circuits are no longer working, you may have a problem with the heating circuits now. The thermal cut-out (TCO) commonly fails. If this is the case, please let me know and I can advise you further.
Jul 02, 2009 | Dryers
My dryer is really hot when it is running, but is taking a really long time to dry the clothes
Make sure you check your exhaust hose. It shuld be clear of any lint , and properly exhausted to outside of the home . Try turning on the druer with no load and no heat , find your outside vent and check for air flow . If none is felt you suhld move your dryer away from wall ( if aplicable ) and disconnect the hose and check for any blockage , You can even try the above step with the vent hose disconnected to make sure that the dryer it self is properly venting ( feel for ALOT of air coming out of exhaust port ) . If only a miniscule amount of air ( or none at all ) is coming out of the back of the unit you may have to call a technician to come in and clear out the internal duct work .
Jun 09, 2009 | Kenmore 600 6962 Dryer
Dryer not heating up
Could be the heating element?
Jan 12, 2009 | Dryers
Clothes not drying
clean vents, including exhaust vent
Dec 16, 2008 | Roper Dryers
Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
Nov 23, 2008 | Frigidaire GLER642A Electric Dryer
Kenmore 73952 Gas Dryer Logo
252 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
