Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
WHY IS THE MACHINE SPINNING AND FILL WITH WATER AT THE SAME TIIME
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
This is a known control board issue with the Cabrio. If your unit still under warranty? If not, you will need to replace the control board. Be sure to purchase it new if you need to replace it so you can get a warranty on it. Here is the control board to order.
The part comes with a 365 day, any part, any reason return.
Posted on Nov 03, 2012
My Whirlpool wtw58esvw0 washer will not fill with water, it will only spin. What can it be?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 30, 2011 | Whirlpool Washing Machines
Washer will fill with water and agitate but won't drain and spin(rinse)
heatman101
Apr 29, 2011 | Washing Machines
Kenmore washer - model #22912 will not spin. It will fill, rinse, and soak...but it will not spin.Water remains.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 20, 2011 | Kenmore Washing Machines
Washing maching will not fill with water
heatman101
Apr 02, 2011 | Washing Machines
My GE washing Machine will fill with water and agitate but will not spin or drain
heatman101
Jan 06, 2011 | GE Washing Machines
Washing machine will not fill, is still draining and spinning??
Check to make sure the water valves are open. If they are, then you need to replace the "water inlet valve" on the machine.
Dec 26, 2010 | Hoover Washing Machines
Can I use cold water fill when installing this machine
No,
There are only a few dishwashers that have good enough heating elements to be able to use cold water.... most all of them need to fill with hot water and then the element just keeps the water hot...
heatman101
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Oct 10, 2010 | Dishwashers
Maytag MHW2000AWW will fill with water but not spin
heatman101
Sep 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
No spin
If anyhow the drain pump is blocked the spinning will be blocked. Check for a forrign object in the drain pump. If you can feel/hear it buzz (very quietly) while it should be pumping out it might be jammed up with something. That however is kind of rare with the angled tub the Neptune uses.
Are you sure the machine is actually not pumping out, or is it possible its just turning off in the rinses?
Reason I'm asking is the control will shut the machine down if its taking too long to fill up. Many times it will fill fine for the wash fill, but because the rinse takes twice the ammount of water it activates the system and shuts down while its half way filled. Look for a slow cold water fill for that problem.
Is the door locking in the spin? One very common problem on the older 3000 and 4000 series machines is the R11 resistor on the machine control board bruning out leaving the door lock inoperative. If the door won't lock, it won't spin. I do believe, however, the machine will still pump out. But many times what happens is the pump removes all the standing water, but without spinning everything in the tub stays soaked. The saturated clothing drains the water out and then leaves a few inches in the bottom of the tub.
If you have the newer style Neptune (with the control panel on the front of the machine) only the top paragraph applies.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Samsung silver care stopped spinning
could be (most likely)
motor brushes
belt off
motor wires disconnected
motor u/s
motor control pcb faulty/
Mar 16, 2009 | Samsung WF337AA Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
